Question about Xerox WorkCentre C2424DN All-In-One Laser Printer
Scanner is putting blue **** all over documents.
  • DBSJT Aug 01, 2008
    Sorry - I didn't know **** was a really bad word. Anyway, the scanner problem goes away if you wait half an hour or so between scans.
    Novelist:
  • Xerox Expert
  • 297 Answers
Sounds like you need to calibrate the scanner.
1. On the control panel, press the System Setup button.
2. Select the Information menu.
3. In the menu, select Troubleshooting, and then press the Enter button.
4. Select Service Tools, and then press the Enter button.
5. Select Calibrate Scanner, and then press the Enter button.
You will need a scanner calibration sheet,
Part Number: 109K01910
Posted on Jan 17, 2009
What should I do to scan a document from a printer using my lenovo laptop?
You can not scan a document by a printer you have to use a scanner put or document in the scanner and in your pc you have the program related to the scanner chose the auto scan button in it and its done if you don't have a scanner take your cell phone and just click a photo of the document
Feb 19, 2015 | Lenovo Computers & Internet
Everytime i try to scan any document using my Fujitsu ScanSnap S510, the blue light on the front-right side of the device blinks 3 or 4 times and nothing else happens (the document, therefore, is NOT...
I had a similar problem. All I did was unplug the USB cable from the scanner and reattach it. Sometimes I would have to close scansnap (blue "S" icon in the sys tray at the bottom right), and then power on the scanner.
Nov 28, 2011 | Fujitsu ScanSnap S510
I am trying to send a fax on my parents fax machine but do not know which way to insert the paper. It is a brother MFC-7860DW
  • if you are going to fax from the glass or scanner bed you should put your document face down on the glass
  • if you are going to fax from the feeder (on the top of the machine) then you should load your document face up in the feeder
How to send a fax?
  • when you want to send a fax ,press the FAX key to illuminate it in blue
  • put the document either in the feeder or on the glass
  • enter the fax number using the dial pad
  • press START
Jul 29, 2011 | Brother Office Equipment & Supplies
I want to scan documents but i don't know how to do it. please give me the steps to operate the scanner
Title: Scanning a document
Hi, at first connect your scanner with your pc then-
?? Install your driver
?? After installation restart your computer.
?? When your computer start, go to "Start " and see the new installed software, open it and choose "Ulead photo Express" any thing which is your scanner supported.
?? Then open your scanner and put document into the scanner.
?? Close the cover.
?? In scanner a scan button is there , just push it.
?? Scanning will be start automatically.
Thanks!
May 13, 2011 | Computers & Internet
The automatic document feeder keeps grabbing the paper on one side and therefore creasing the paper so that it does not go through
Lift up on the ADF roller cover and look for a piece of paper. Remove the blue guide bar and the end where the paper flips under. If you can't find paper put the blue bar back and close the ADF (automatic document fee) lid. Lift up the flatbed scanner cover and look at the far left side to see a piece of obstruction. Clear that and try making a copy.
Nov 19, 2009 | HP Scanjet 5590 Flatbed Scanner
I need to scan both sides of a document. How is
How to fix my Personal Computer when it show blue page , I want to know what cause it is.
Nov 11, 2009 | Xerox DOCUMATE 510 Flatbed Scanner
I want to copy a document
How often do you need to "copy" documents. Do you have a document scanner?  Your Epson is a printer.  You'll need a scanner to scan a document into your PC then you can print it out on your Epson.  If you only need a copy once in a blue moon, and you don't have a scanner, save yourself a few bucks and just go to Kinko's or maybe even your local grocery store or library and run your copies there.  They probably cost about 25 cents a page.  A new scanner will run you about $100 bucks.  If you decide that you need a scanner, you might even want to consider investing in a multi function printer which will scan-print-copy-fax.  Hope this helps.  If so, please remember to rate my solution.  Thanks.
Mar 14, 2009 | Epson Stylus Color 600 InkJet Printer
When scanning color document, blue tone is present as background shade
Have long experince with PixEdit program using Kodaks. PixEdit usually comes around it after a firmware upgrade on the scanner. Not sure about this specific model but at least OK on other models of Kodak.
Sep 25, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
All scanned documents have blue background.
You have to take the machine to service partner who can be found on the brother homepage of your country.(www.brother.com)
The scanner needs calibration which can only be done by service personel.
Dec 25, 2007 | Brother MFC 210C All-In-One InkJet Printer
Xerox WorkCentre C2424DN All-In-One Laser Printer Logo
135 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
