Question about Hardware & Accessories
Saunier duval boiler Fault code F1 - Hardware & Accessories
2 Suggested Answers
SOURCE: will this item buy pass
It depends on wattage being controlled.
You posted under Woods 59200 timer which is a lightweight table lamp timer.
I suggest more robust 110V Intermatic HB113C appliance timer.
http://www.amazon.com/Intermatic-Hb113c/dp/B000GHKO6C
If you are not wanting a plug-in timer, add a comment with specific requirements.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Feb 27, 2011
SAUNIER DUVAL model 31-026. Where can I obtain a troubleshooting manual?
Boiler Manuals: Saunier Duval - Plumbase
https://www.plumbase.co.uk/documents/index/10000204
Boiler Manuals for the Saunier Duval range. ... Saunier Duval Thema Range · Saunier Combitek F23E · Saunier Duval Isomax F28E · Saunier Duval Sylva ..
Aug 20, 2015 | Heating & Cooling
Saunier duval parts
If you are talking about the damper flap on the flue pipe. You have to go to a heating supply and buy a new flue that is already attached to a section of new pipe and fit it together. I'm not sure if your flue is free flap type of arm driven. British gas is trying to make a buck off you . Call a regular boiler repair man if you don't feel comfortable doing it your self.. Mine came apart at the hinge. The pin came out..I replaced it with a wire brad (nail) and it works just fine.
Dec 12, 2017 | Water Heaters
Boiler pressure saunier duval
Appear to be corroded/plugged inlet valve. De-pressurize system and check inlet valves and line.
May 11, 2013 | Water Heaters
Low pressure Saunier Duval therma condens boiler
May need to replace valves (appear to be corroded and plugged with deposits) and install a water conditioner in the inlet line if you have hard water.
Will this item buy pass my original timer on my boiler?? i have a saunier duval f 30e!
Feb 26, 2011 | Woods 59200 Lamp and Appliance Timer with...
Hi, I have a Saunier Duval? Theilea twin 28e
You may want to check the Pressure Reducing Valve On the supply line to the building. Easiest way to check is get a guage that hooks up to your hose bib (usually found in the sprinkler section at your hardware store). If your pressure is getting above 80, you need a new PRV.
Feb 14, 2011 | Water Heaters
Low pressure for SAUNIER DUVAL TERMACLASSIC
there is a blue tap at the bottom of the boiler when you turn it and nothing happends the screw had broken off inside you can do 2 things here put a new filling tap on the boiler , or get a filling loop put some where else on the system and if you still get low pressure replace the low water pressure switch...
Jan 31, 2011 | Heating & Cooling
Hi, Got a Saunier Duval Thema F 23 E and need to repressurise it (currently at 0 bars). can you provide any help on how to do it? Thanks.
http://www.saunier-duval.co.uk/manuals/pdf/noncurrent_products/installation_ThemaF23e-SBF23e.pdf
Here are complete instructions for installation and service including purging air and refilling. One of the first suggestions is that service is to be referred to a competent technician.
Gary
Dec 18, 2010 | Water Heaters
I have a 11 year old Saunier Duval and the hot water hardly works
suggest you call a repair service. gas appliances are dangerous to DIY they explode when people do not use the proper safety precautions
Aug 31, 2017 | Combi Centre DX - Mango
Hardware & Accessories Logo
434 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
