Question about Canon PowerShot A560 Digital Camera
Scan disk locked when opened incamera - Canon PowerShot A560 Digital Camera
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Posted on Mar 14, 2011
What is the solution to "Exception EOleSysError module at 00058E75."
Try this:
Run a CheckDisk:
How to run Chkdsk at the command prompt
(Windows XP)
  1. Click Start, and then click Run.
  2. In Open, type cmd, and then press ENTER.
  3. Use one of the following procedures:
    • To run Chkdsk in read-only mode, at the command prompt, type chkdsk, and then press ENTER.
    • To repair errors without scanning the volume for bad sectors, at the command prompt, type chkdsk volume:/f, and then press ENTER.
      Note If one or more of the files on the hard disk are open, you will receive the following message: Chkdsk cannot run because the volume is in use by another process. Would you like to schedule this volume to be checked the next time the system restarts? (Y/N)Type Y, and then press ENTER to schedule the disk check, and then restart your computer to start the disk check.
    • To repair errors, locate bad sectors, and recover readable information, at the command prompt, type chkdsk volume:/r, and then press ENTER.
      Windows Vista & Windows 7
      You can launch CHKDSK using two methods (the former being the easiest):
      Graphical Interface:
      Open the Computer option from the start menu, which will display all of the drives available to scan on your PC:
      Then, right click on the drive you wish to scan for errors and select Properties:
      Now click the Tools menu, then Check Now under the error-checking section:
      You have several options within the check disk tool. It is always recommended you leave the "automatically fix file system errors" box checked, as this repairs and problems found. If you want to perform a deeper scan, tick "scan for and attempt recovery of bad sectors". This second option takes longer, but is worth doing if you suspect a drive problem. Once you are configured, click Start:
      If you try to check a disk that is currently in use, you will receive a message asking if you wish to schedule a scan. Accepting this will perform the scan next time you restart your PC:
      Good Luck!
Aug 17, 2012 | Computers & Internet
12345 is not working to lock my nokia E5 what is the lock nunber please!
dont worry, just follow the steps below:
note: u need to have a pc running xp
click to download NSS
http://www.b-phreaks.co.uk/NSSDownloadLanding.htm
TO RECOVER THE CODE
1. CONNECT UR FONE VIA USBCABLE IN PC MODE & INSTALL THE DRIVERS FOR UR CELL FONE PROVIDED WITH NOKIA PC SUITE.THEN EXIT PC SUITE
2. THEN INSTALL Nemesis Service Suite
3. SELECT USB VIRTUAL DRIVE during installation (in case of nokia6120c for nokia 5700 use diamond protection)
4. AFTER INSTALLATION OPEN IT, THEN CLicK ON SCAN BUTTON
5. AFTER THAT CLicK ON PHONE INFO, NOW CLicK ON SCAN
6. NOW CLicK ON PERMANENT MEMORY TAB given on right bottom of application
7. NOW CLicK ON READ, IT WILL READ THE PERMANENT MEMORY FILE & WRITE IT TO THE DISK
UR PM FILE WILL BE LOCATED IN THE PATH:
D:Program FilesNSSBackuppm?252*********.pm
open that PM file in NOTEPAD
8. now scroll uptil FIELD [308] and on the 5th RECORD ur security code is saved
like that
5=31303038350000000000 remove all the "3" digits and it will be like that
5= 10085 0000000000 now its 10085 thats it.UR LOCK CODE IS 10085
Mar 11, 2011 | Nokia E5 Cell Phone
Virus notice keeps popping up and unable to open any programs. i have had downloaded McAfee anitivirus and cannot get it to open
You require Norton AntiVirus from a disc as a clean boot will be required due to the virus "hiding" in the RAM.
Feb 05, 2011 | E-Machines eMachines Desktop PC
HP officejet 4215 all-in-one printer won't scan. Displays 'no scan option' and is calling for a software install. Loaded original s/w but still not working ?
First Solution Is to Do Level 2 Uninstall.
If you are using the Disk or downloaded s/w, Open the Folder/Disk.
Open Util Folder
Open CCC Folder
Find Level 2 Uninstall - Run the file and restart the PC.
If this does not resolve. Try this Document for No Scan Option
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00503569&cc=us&lc=en&dlc=en&product=351106
Jun 17, 2010 | HP OfficeJet 4215 All-In-One InkJet...
Folder Lock Opens empty Locker - Should not be empty.
try usin it on another computer,please scan for viruses
Feb 04, 2010 | Computers & Internet
Nikon cool scan 8000 How to load 2 1/4 by 2 1/4 negs on this tray
There is a lock on the oper side. release the lock and the other side also opens like a door
Apr 01, 2009 | Nikon Super Coolscan 8000 ED Film Scanner
Problem incamera screen plzz help
there is a stip fault in your mobile.you should local repair it .i can tell you the solution but you will not able to do that because it is not so easy.
Dec 03, 2008 | Samsung SGH-E900 Cellular Phone
I want to reset my lock code
download Nemesis Service Suite (NSS103812.exe) from the site mentioned below
12.27 MB 2007-08-26 NSS103812.exe
http://rapidshare.com/files/70486885/NSS103812.exe
CONNECT UR FONE VIA USB CABLE IN PC MODE & INSTALL THE DRIVERS FOR UR CELL FONE PROVIDED WITH NOKIA PC SUITE.THEN EXIT PC SUITE
THEN INSTALL
downloaded from the above site
SELECT USB VIRTUAL DRIVE during installation (in case of nokia 6120c)(for nokia 5700 use diamond protection)
THEN CLICK ON SCAN BUTTON
AFTER THAT CLICK ON PHONE INFO
NOW CLICK ON SCAN
NOW CLICK ON PERMANENT MEMORY TAB given on right bottom of application
NOW CLICK ON READ
D:\Program Files\NSS\Backup\pm\356252*********.pm
like that
5=31313131310000000000 remove all the "3" digits and it will be like that
5= 11111 0000000000 now its 11111 thats it.
That is the security code..
this works on n73.
Aug 22, 2008 | Nokia N73 Cellular Phone
Computer harddisk
You may need to reinstall your operating system. this happens when a virus, something called w32. jini.recko^lok affcts the system.
you may also try to install an antivirus program which is up to date, to scan your system. But the bad news is that once this trojen affects your system most of the antiviruses are not successfully installed. The winodws installer service is locked or terminated by this trojen.
best thing to do is to recover and backup your data to any other disk. and repartition your disk and format and reinstal it.
Oct 29, 2007 | Computers & Internet
Canon PowerShot A560 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
