Question about Kicker Car Audio & Video
Car speaker are popping when turn up louder - Kicker Car Audio & Video
    Problem Solver:
  • 13 Answers
This is probably clipping from gains being set improperly. Use the proper method for your amplifier and a test tone cd and multimeter to set the gains at the proper level.
Posted on Mar 15, 2011
Makes large thumping/chirping noise when turned on. Its not even connected to the receiver
Since you have said the speakers make this sound when "turned on", I'm going to assume there's some form of power amplifier attached (internal, external or otherwise). Based on the minimal information provided here, this simply sounds like the normal reaction of a speaker when the amplifier is turned on. In short, an audio speaker is a type of "transducer" and when power is applied (thru some form of amplifier), the cone reacts to the power surge and causes a thump, pop or other noise. Turn on your TV for example and you'll usually hear a small pop from the speakers...and a larger/more powerful amplifier is likely to make a louder noise. Without further information, in most cases this is quite normal.
Assuming there is an external power amplifier, my advice would be to turn the volume on the amp (regardless of whether there's a receiver connected) to 0 before turning the power on. If it still makes such a noise, it's possible the volume control of the amp may require cleaning.
Good Luck!
Apr 01, 2016 | Audio Players & Recorders
I have a big pop on the speakers when i turn on my engine
The HU you removed may have had a circuit to prevent turn-on/turn-off pop. The nav system may not have it.
Jan 15, 2014 | Car Audio & Video
Amp is connected to speakers but the volume coming out of the speakers is very very quiet. Speakers have been tested seperately and are known to work. Have turned the input sensitivity to max, this makes...
sounds like you need to turn up your gain and bass. while amp is on and your favourite music playing, turn up the diles on your amp until you get the sound you want one by one.
Feb 28, 2011 | Kenwood KAC-529S Car Audio Amplifier
"pop" in speaker when turned up
more likely your deck is just running out of power. another cause is the speaker leads could be hitting the metal of the car with the bass, check for clearance.
May 19, 2010 | Alpine SPS-609 Car Subwoofer
My door speakers arent working but my sub is and when i turn on my car a noise comes on from the sub and it gets louder if i step on the gas. it wusnt doing that until i unpluged the power cable from the...
the RFI suppression is gone... It is normally a small capacitor that conducts the AC noise from the ignition to ground.
You probably "popped" the coil on the speakers - or atleast the pass through coil on the subwoofer.
Remember, your sub take all the audio, filters out the high stuff and amplifies the low freqs.... the high stuff is passed onto the other speakers....
if you have distroyed the pass through coil - speakers don't work...
First, try connecting the speakers directly. (leave the sub out of the system)... do they work? If yes, then the pass through on the sub is shot and must be replaced before any further troubleshooting can be done.
-Jim
Oct 23, 2009 | Car Audio & Video
Stops playing if i turn im up louder if i restart than he plays and wen i turn up the volume everything stps even the licht goes out
Disconnect speakers and test. Crank up the volume and see if it still cuts out. Then re connect one speaker at a time and test. if it cuts out, check for a short in a speaker wire or a bad speaker (blown or shorted coil) Hope this helps
Aug 08, 2009 | Lightning Audio S2.500 2CH 500W Amplifier...
Getting a loud " POPPING" sound
Switch the wires on the two speakers at the box and see if the problem moves to the other speaker. If the second speaker starts popping and the first one stops, the problem is in your amplifier. If the same speaker keeps popping then you probably have a blown sub.
Mar 01, 2007 | Rockwood XR-1712 Car Subwoofer
Car Audio & Video Logo
110 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
