Dont know what rca jack goes where or how to wire up unit.
  • 604 Answers
If you could be more specific on the model of amplifier/reciever you have I might be able to help you. also tell me what your are tyring to plug into it.
Posted on Mar 14, 2011
Bare wire sub to single RCA jack receiver
Yes you can modify RCA cables to make bare wire tails.
If the unit has a sub o/p then you just connect up your sub bass unit to whatever the amp needs.
An RCA cable is 2 wire which is all you would normally need for sub bass speaker level signal.
It may be a good idea to eventually upgrade the wire size if you want really good sub bass as lower frequencies draw more current and so require more copper.
Please let me know if this any help, thanks for using FixYa.
Sep 20, 2009 | JVC RX-554V Receiver
Hdmi Port .
If the laptop has no HDMI port, the forget the whole HDMI thing cause getting it through that port when the laptop or desktop is not made for it will end up costing as much as a new computer altogether. You need to find out if the laptop has any Composite or Component outputs. Those are relatively easy to spot. a Composite output is usually a RCA jack and also usually colored yellow, and goes into the yellow RCA port on your TV next to the red and white RCA ports which are the left and right sound channels. The Component outputs are also RCA jacks, but are usually red green and blue cause each wire sends its own color to make up the TV's image. They will also go on the back of your TV near all the other RCA ports. Wether your TV has just HDMI and no other porte or not, or if it has either Composite or Component inputs or both, that i don't know cause i don't know what your TV is. As for the sound, if you also want it on the TV, you just need to go to the local electronics store and buy an adapter/wire that goes from a 1/8 stereo headphone jack to 2 RCA jacks on the other side, one being white and the other being red. See where i'm going with that?:P Plug the 2 RCA jacks from the wire you bought into the TV in the corresponding inputs that go with the input you plugged the image in, and the 1/8 stereo jack into the headphone output of your laptop.
Jul 08, 2009 | HP Pavilion dv6000z Notebook
Connecting iPod to Panasonic CQ-C5310U
I'm pretty sure that there are RCA jacks in the back of the unit for the aux input. Don't have my owners manual so can't really say, but if there is an aux input, there is sure to be some RCA jacks in the back. So if you take the stereo out, look for those jacks then attach a 1/8 "Y" connector. Then route that wire to the front. Then you'll have something to connect your mp3 player to. =)
Feb 23, 2009 | Panasonic CQ-C5310U CD Player
Car amp
seems like the rca jacks are loose on the inside of the amp
Jul 04, 2008 | Car Audio & Video
No Rca Jacks
RUN REAR SPEAKER WIRES INTO AMP USING LOW INPUT WIRES FROM AMP
Jun 29, 2008 | Car Audio & Video
Pioneer DEH-P2900MP head unit
There is no power from the rca jacks. Option 1; connect the speaker wires directly. Any aftermarket auto manual (Hayes, Clymer) with wiring schematics will let you know what wire is what in the dash. Option 2; RCA jacks output to an amplifier. There is no power coming from the RCA jacks. They have to be used with the amp. If you chose to use the normal speaker wires, be aware that these radios do not like stock speakers or wire. If you take the time and money to replace all of it, the head unit will last much longer. If you choose to use an amplifier, it will burn out fast unless you replace the speakers and wires immediately.
Mar 04, 2008 | Pioneer DEH-P2900MP CD Receiver...
Fitting car speakers
direct to front s out from sterio have to match up know were your old ones go a wire harness for your car says all labeled nice were to go weird colers in such ok get that match it up to back of head unit wireing it direct ok postive on + negitive on - ok its notto hard if u dont know colers u call deler they tell u the coler codes for your car write it down ok
Jan 22, 2008 | Denon AVR-3805 Receiver
I cant instsall the whole system, does anyone have any ideas??
bagman Fat Red wire from batter + to Fuse. Fat Red wire From Fuse to Amp +. Amp- Fat Black wire to body Ground. RCA cable run from Head unit RCA jacks down opposite side opf car from power wires. To Amp RCA inputs. Wire Speaker REd terminal to Plus on Amp. Balck Terminal to Minus on amp. Blue Wire is REmote, and wires to Blue on head Unit. Remote on Amp.
Oct 03, 2007 | Fusion FEW12PK Car Subwoofer
How do you connect a pioneer d2 navigation system to a 2006 ford expedition entertainment system
You need to identify the four wires that carry the DVD audio in the factory plug, and re-wire them to RCA plugs that can be used with the Auxiliary input RCA jacks on your Pioneer unit. The four wires should be: Left (+) light green Left (-) white Right (+) red Right (-) black The easiest way is to purchase some inexpensive RCA cables (or better yet, speaker wire with RCA ends). Cut the cables and wire the center pin conductor wires to the (+) audio wires in the stock plugs, and connect the outer shield conductors to the (-) wires. Then connect the RCA plugs to your head unit's auxiliary input jacks.
Aug 08, 2007 | Pioneer AVIC-D2 DVD Nav/6.5"...
Jensen LXA400
I have this same amplifier. I have noticed several ways it will "not work" during my ownership of it. I have it connected to a seperate battery to save my alternator, battery, etc as it is a power hungry beast for how low the output wattage is. Test the input voltage to see if you have enough, one way to see this is to check the "jensen" emblem that lights up. If you dont have enough power it will appear dim and only the right side lights up. Also the amplifier will not work if your speakers are "blown" even a little bit. Ive taken speakers that wont work on my lxa400 and connected them to a higher power amp and they will work (although they will sound horrible) If youre smart you will keep the gain under 3/4 on this amp, I see some people have found out the hard way that full gain fries the amplifier circuitry. Not an expert on electronics but it smells somewhat like melting glue or plastic. Ive noticed a lot of people have problems with the RCA jacks as well. There are 8 jacks, in two clusters. The first one is A+B and the second is C+D. Note: You do not NEED Y connectors on this amp! Connect your output rcas from the deck to top left and bottom left jacks of the left cluster. This will give you left and right (a+b) output from the first set of speaker outs. Then connect an rca patch cord from the top right and bottom right jacks of the first cluster and connect the other end to the top left and bottom left of the second cluster. This will give you output from the second set of speaker outs. Remember that this is in 4 channel mode. I dont remember the set ups for 3 channel but two channel I believe is the left deck rca goes to top left of the first cluster and the right deck rca goes to the top left of the second cluster. Then you just wire the speaker outs according to the picture on the amplifier. something like this: _________________________ |(+) - (-) +| ~~~~~~~~~~~~~~~~~~~~~~~~~ Speaker + goes to (+) and speaker - goes to (-) Also addressing another issue if you want to increase the wattage to your speakers you just use a lower resistance speaker (2ohm instead of 4) I would not recommend using anything over 4 ohms. As for the high level inputs, I dont recommend using them unless you have the plugs that go with them, its a lot easier to wire your deck rears to a line converter (changes straight speaker wire to RCA jacks) or to just buy a new deck with RCA outs. Last item, common knowledge: 400 watts does NOT mean 400 watts!!! This amplifier puts out very little actual wattage (50 or 83 per channel depending on the load) Hope all this helps someone out there.. Anyone who knows the 3 channel setups I would appreciate it.
Apr 12, 2007 | Jensen LXA400 Car Audio Amplifier
12 people viewed this question
 Grubhead
Grubhead
