Question about Husqvarna Garden
Sash cord is stuck - was rotary hoeing the back and all of sudden it stopped and can not pull out to start
    Problem Solver:
  • 17 Answers
It sounds like you seized the motor, the motor was more then likely a 2 stroke and needed to have oil mixed with the gas and maybe the mixture was off and caused it to lean-out and seized the motor. You can pull out the spark plug and put 3 ounces of engine oil in the cylinder and let it sit for a couple of days to see if it will free up, if it does then tip it upside down to drain the oil back out,put plug back in and start it up. If you found this info help full then please click on the thumbs up button. Thanks, Bob
Posted on Mar 14, 2011
Pull Cord Stops...
could be valve needs set. if it isn't opening at the right time it wont release compression for it to start. it may be the shear key in the flywheel has sheared if you have hit something like a big rock or log or something causing it to die suddenly.
May 17, 2016 | Craftsman Garden
Masport rotary hoe wont start after hitting a post
Make sure you still have an air gap for the coil in case they were jarred.
Oct 01, 2014 | Garden
5hp rotary hoe , blades under engine.Hoe does not want to move foward,seems to just dig it self a hole,and you must either try to push it forward,or rock it side to side to get it moving,it makes it very...
My rotary hoe has a steel rod that you can adjust for the depth and if that rod is set too far in the ground it will just sit and spin. my rod has holes in it and you set it with a pin that makes it less deeper if you want.
Feb 15, 2018 | Garden
How to thread pull cord on my Talon rotary mower
remove THE COVER THAT HOUSE THE PULL CORD pully. TURN THE WHEEL IN THE direction THAT IT GOES WHEN cord is pulled ( THIS TIGHTENS THE RETURN SPRING) hold this wheel tight..every turm it could spin back rapidly. turn wheel 6 complete turns. align the hole in the housing with the cord hole in the pully wheel. thread cord through both tie a double knot . slowly release now install cover. try it if too loose pull out to max , hold pully, remove knot , cord and turn 2 or 3 more turns, replace cord, double knots , slowly release. replace cover, crank it and cut that grass.
Dec 04, 2011 | Talon Rotary Lawn Mower
My Dremel sijmply stopped working suddenly. Where do I begin? Brushes?
If you have a volt/ohms meter It is a process of elimination. First unplug tool and remove the brushes turn the switch on and check for continuity to the brush holders and if none work backwards start with the cord and then the switch etc until the problem is found.
Jun 24, 2011 | Dremel Variable - Speed Multipro Rotary...
I operate a 32cc Weed Wacker from Craftsman. It was working just fine, but all of a sudden stopped running and somehow I cannot pull the start cord, it got stuck. Where should I look first before opening...
The first thing I would do is remove the housing for the pull cord and spring to find out why it isn't pulling. That may be the same reason as to why it stopped and appeared to lock up.
Jun 19, 2011 | Craftsman Garden
MTD Yard Machines 22'' mower, pull cord won't extend
From what you describe it sounds like the line may be tangled, remove the rewind housing in order to inspect the line up close.
Jun 03, 2010 | Mtd 22" Yard Machine Push Mower
is it flooding or is it second hand , some people cut the cord and dont fit it back properly , if it is flooding you will get hydraulic lock , answer to your question is carby service and over haul
Jun 03, 2010 | Garden
Pull cord getting stuck
Pull starter rope wheel is Jamming against casing usually some lube n check for ware will fix it
Mar 21, 2010 | Karcher 2500 PSI Pressure Washer
Garden Logo
201 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
