Question about Bosch Washing Machines
My Bosch Maxx 1000 is leaking water slowly underneath when it is running. I have checked all the connections and they appear to be fine. There is definetly detergent in the leaky water . The machine is sometimes making some squeaking sounds when running - but not always Machine is 5 years old
  • 3 more comments
  • msa783 Mar 14, 2011
    Daniel i did clean out the drain pump assembly but it makes no difference, The drain pump is working fine
    drain pump assembly was cleaned out and makes no difference cleaning. The drain pump is working fine
    Yes, very loud - sounds liike it is going to explode
    Thanks for your help
    I did notice that water commences leaking very soon after startiing the machine
    Also its only noisy on the spin cyscle
    Does this support your view?
    Sergeant:
    Novelist:
  • 196 Answers
Is the machine noisy on a spin cycle?
Posted on Mar 14, 2011
  • Michael Crozier Mar 14, 2011
    Its your bearings that are faulty. When they collapse the can start letting the wash water leak out. I'm afraid its terminal. It needs a new drum rear unless you can get a bearing kit but need the model number. If a kit is available then you will still need an engineer to do it as its about a 2 hour job. Expect to pay around 100 still. If its a new drum rear then Expect 200 plus. Sorry its not better news
  • 4,323 Answers
Hi
The issue is with the drain pump assembly that requires cleaning, it is locates inside the bottom front panel and this access panel comes out to clean. After cleaning if the issue returns and the drain pump are working then replace the impeller assembly, if the drain pump is not working and you still hear the sound then the drain pump assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
  • Daniel Scott
    Daniel Scott Mar 14, 2011
    If the belt is fine then the issue is with motor that is bad
I have a bosch wfo2460 1200 maxx, it is leaking underneath front, it is not the filters, can you help please?
google the brand and the model # with the error code you are getting for the answer.
Jul 29, 2015 | Bosch Washing Machines
Bosch maxx 1000 - when finished cycle, leaves central fabric conditioner drawer full of water + trace of condtioner.
Check that the hose that connects the drawer to the tub is clean, fabric conditioner normally gunks up especially on colder wash cycles.
Apr 01, 2015 | Bosch Washing Machines
Bosch avantixx front loader leaking underneath machine? machine only 2 years old
  • You will find a small door on the front bottom of the washing machine.
  • Open it.
  • Unscrew the filter and rinse it with running water.
  • Put it back in place and repeat the above steps in reverse order.
This should solve your leakage problem.
Aug 03, 2014 | Bosch Washing Machines
Our Bosch washer leaks but only during the spin cycle.It is a Classixx.
Try cleaning the detergent draw somtimes this can cause water to spill out and ofcourse check the filter and exit pipe :)
Hope this helps
TalkAppliance.co.uk
Apr 12, 2012 | Bosch Washing Machines
Does anyone know how to check a fuse in my Bosch Maxx 1000 washing machine??
Try it in a different socket as it may not be the machine. The machine would have been factory fitted with a moulded plug, lift out the middle section and try a new fuse. If the unit failed after filling then possibly you have a short on the wash heater..you could verify this if you get power by setting a cold cycle or rinse and see if if completes it. Please also check that the consumer unit (main fuse box) has not been triggered.
Nov 26, 2011 | Bosch Washing Machines
I unclogged the GD by removing the pipes underneath and replaced them tightly. GD seems to be working fine now, but water is slowly leaking from underneath the GD! It appears to be leaking from the...
The leak comes from above where water comes out.
Turn off power before touching wet electrical appliance.
Put stopper in disposal.
Fill sink with water.
Check if water is getting through the putty seal at sink connection.
Next, check if water leaks only when dishwasher runs. Dishwasher drains into garbage disposal.
Last, check tailpiece where it attaches to side of garbage disposal. The tailpiece is usually sealed with a rubber washer. When washer is old, it gets deformed, and then it doesn't seal perfectly when put back.
I use rectorseal on all tubular pipe joints under the sink.
Works on both plastic and rubber washers.
It is gooey and sticky.
Brush it all over the washer, use plenty, then assemble pipes.
The rectorseal assures that joint will not leak.
Oct 25, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Maxx 1000 wo;nt spin
check brushes in motor 6 years quite good.
Sep 14, 2009 | Bosch Washing Machines
Bosch Maxx WFL 2060
connect at random. put on a rinse cycle. if cold water comes in then pipes are correct. if hot water comes in then pipes are wrong way round and just swap them
Sep 13, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
867 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
