Question about NAD T751 Receiver
I have a NAD T 751 and volume of channel 1 and 2 differ substantially. Have DSTV connected on channel 1 and when I switch to DVD Player, the volume blows me away if I forget to turn down volume before switching. I have alternated the channels, but the problem obviously lies with the differing output levels of DSTV and DVD. How can I adjust the channels internally to balance the volume levels please?
  • 1 more comment
  • Dave Mar 14, 2011
    This sounds like a better solution. Will you supply full details please?
  • Dave Mar 15, 2011
    Currently I use a normal RCA audio and video connection, but will most probably buy a new Samsung Blue Ray player over the week end. This uses HDMI plug and I will probably switch to a coaxial connection to get digital audio into my NAD digital input no 2.
  • Dave Mar 18, 2011
    Thanks, will one of those small variable resisters also work?
    President:
  • 1,961 Answers
Hello!
There is nothing to adjust internally on your receiver... I'm sorry to say that!
However, there is a way to modify the receiver, by adding a resistor at the input signal selector to where the DVD player is. If that is what you want.
Let me know if you want to modify and I will instruct you
Posted on Mar 14, 2011
  • 1 more comment
  • Danilo Baraquiel
    Danilo Baraquiel Mar 15, 2011
    hi. sir may I ask you what type of connector you are using to connect your DVD player to the reciever?pls post back thank you!
  • Danilo Baraquiel
    Danilo Baraquiel Mar 17, 2011
    at the auxiliary input of your receiver,to where your DVD player is hooked up cut the positive line of the RCA jack then install a 1/2 watt 600 ohms resistor to lessen the signal input.
  • Danilo Baraquiel
    Danilo Baraquiel Mar 18, 2011
    yes sir that will work.
  • 5,807 Answers
To balance the volume level, you may need to lower first the volume of the DVD audio output
level,
DVD player has it own volume level control, trim down a little to match with the level
on the DSTV using the DVD remote.
refer to the DVD manufacturer web site for adjusting the volume control, or post the
model of the DVD player so I can assist you to where to download one.
Or alternately if you have at least 4 channel Audio Mixer , you can use these
as volume control for adjusting the audio level on each.
Or have an audio compressor/limiter , it tends to limit the audio output at a certain level.
so it will not blow you away.
These unit is inserted on the input of the amplifier.
how to use a compressor :
http://www.pcmus.com/compressors.htm
some images can be found here:
http://www.tweakheadz.com/compressors.htm
http://www.mercenary.com/dynproc1.html
you tube video of an audio compressor
http://www.youtube.com/watch?v=dmJQRjBtuE4
But if you need to DIY , here is a simple compressor circuit
http://graffiti.virgin.net/ljmayes.mal/comp/comp.htm
Although some professional amplifiers like Crown have built in compressor/
limiter
Posted on Mar 15, 2011
  • 1,591 Answers
I had a buddy with a similar issue, but your situation might be different.
If your DSTV remote is capable of altering the volume, DON'T. Max it out (or close to it) and use the NAD to control yout TV volume as well as the DVD, and it should be fine.
If this is NOT your situation, click REPLY here and I'll advise you further.
  • Norman Skinner
    Norman Skinner Mar 14, 2011
    Just an aside, my buddy's line out didn't adjust when he adjusted the volume on his TV...A BIG problem when connecting to his surround unit. I eventually built him a line level attenuator, and he's real happy with it.
NAD C320. Only one channel sounds. Problem with the volume control?
Did you try to switch the loudspeakers? Before changing anything always lover the volume and switch off the amplifier.
Assuming you tested already different inputs, you can be sure no cable from signal source is out or defect. (or did you nit check that first?).
When the amp is switched off, disconnect the speakers and switch left to right and right to the left output.. If the other speaker is quiet now, you are sure it is in the amp. Still his can be anything.
You can check the connections between the pre and main amplifier on the back side. When you have an extra set of interlink cables, perhaps you can cross the in and output there too. Take care every time you change something, lower the voltage and switch off the amplifier. Sudden clicks when switching on or changing anything can damage the amp and or the speakers.
Perhaps when you checked this you can locate where the problem is? Speaker, speaker cable, power amp, pre amp, (only a part of the pre amp.
Nov 12, 2013 | NAD C320 2-Channel Amplifier
NAD C740 Chanel B Speakers not working The speaker output A is working properly, then the output B is completely silent. I install differents speakers and even the same speakers. no sound from the B...
possibly the causes are: 1. defective channel B power amp board. But try operating first with the built in tuner, if it's ok the RCA cable from your other sources(DVD player, etc...) might have broken internal conductor.
2. if it has the speaker switch(A, B, A+B) try toggling it, might also just loose contacts.
if the trouble is #1, leave everything to your trusted qualified technician, he knows what to do, unless you want to tweak/repair it by yourself...hope this helps ;-)
Feb 03, 2011 | NAD C740 Receiver
I want to couple my DSTV Decoder through my new THT-3017HDMI Home Theatre System to the TV. How do I do that? I am very much technology disatvantaged.
THT-3017HDMI to hook with TV.
Get RCA Cables, red and white from your DSTV straight to your DVD.
The Yellow (Video) Straight from your DSTV to your TV yellow input.
Set your TV to Input 1 or 2 depending on the port you used. PLease but your volume will be only controlled via DVD, if you switch your TV off it will still sound the TV channels via DVD speakers,
Sep 03, 2010 | Televison & Video
The volume keeps disappearing on the left speaker but will return with a crack if the volume is increased substantially
Sounds like there is might be dirty contacts inside the volume potentiometer I would suggest spaying the control with a contact spay which will clean and lubricate the control.
Nov 28, 2009 | NAD C352 2-Channel Amplifier
Connecting an outdoor MP3 player to an NAD C352 Amp
you could get a bluetooth dock and cables or just get a saeltech bluetooth speaker and run it off your computer .It will let you run your i tunes or media player and go thru your playlist or artist songlisting can also be operated remotely on the speaker unit ! Volume And tracks!!! swamp ratt!!! AAEE!!!!
Jun 02, 2009 | NAD C352 2-Channel Amplifier
No volume control
lower the volume of the cd player
May 08, 2009 | NAD C320 2-Channel Amplifier
BLACK AND WHITE
Hello.
1. Have you tried to switch channel to AV or RGB on your TV?
2. Some DVD Players have internal settings for the output mode if you go into the menu and settings on the DVD.
3. If its connected to the TV via a scart cable make sure the connectors are fitted all the way into the socket on both TV and DVD
Hope this will help you with your problem.
Thanks for using FixYa
Feb 10, 2009 | NAD T562 DVD Player
Is there a reset button for the NAD Surround Sound Receiver T 751
The only reset that i know of is to unplug it for 15 to 20 minutes. Hope this helps.
Dec 03, 2008 | NAD T751 Receiver
Nad 310 amplifier VERY QUIET
take audio out from tv and insert it in aux in in your amp.
Jul 15, 2008 | NAD C320 2-Channel Amplifier
NAD 7155 with one speaker channel not working
In my case, if I push in on the balance knob, I can get the channel that quits to work for a while.
This leads me to believe that the pot is dirty as opposed to a circuit or component failure.
A couple of years ago, I sprayed circuit cleaner into the pot as best I could and the problem disappeared but, it has returned.
My next attempt will be with one of the newer cleaner/lubricators that are available now.
I don't know if this will solve your problem but, it might be worth a try.
BTW, getting access to the volume/balance pots takes some doing. As long as you are there treat both pots.
Greydog(1)
G
Jun 08, 2008 | NAD 712
Open Questions:
NAD T751 Receiver Logo
205 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Larry Stiles
Larry Stiles
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
