Sharp DX-C381 printer,copier,scanner,fax comes up with an error relating to a Code:L4-16 error - it's also louder than normal and will sometimes make a clicking sound
SOURCE: Error Remove and check cartridge on
does it print with the color cartridge
Posted on May 29, 2009
Benimur
  • 6966 Answers
SOURCE: AL1644 Sharp
For a Sharp AL1644, pls start here. Clicking on the Click here under "Drivers and Software Downloads" would open another window, pls enterxx in the box provided for the "Select a Product Code :" and click on "Search" button. Select driver appropriate for your Operating System.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 05, 2008
007tech
  • 95 Answers
SOURCE: Sharp Copier AR -407 Error code H3-00
H3-00 means there was a problem in the fuser unit of the copier - a temperature problem. The correct temperature is not reached within a certain time.
It could be a thermostat or thermistor problem - both monitor temperature. you could remove the fuser unit and make sure these items are clean - no build up on them. there should be a center and side thermistor.
You can reset the error code in SIM mode by pressing the following keys one after the other "P" "interupt" "C" "interupt" then 14 and start/copy key. confirm if required. make sure the copier is restarted afterwards.
If the error persists then you may need new thermistors.
Hope this helps.
Posted on Apr 12, 2009
SOURCE: Sharp AR-M450 can't scan to e-mail
Check your primary and secondary dns entry.Also a return admin address is required.
Regards Ed
Posted on Apr 20, 2009
  • 169 Answers
SOURCE: My problem is with the HP PSC 950 series printer,
faxing,scanning and copying use the same mechanism,thts the scanner,if its doing it intermittently you can try a reset on the printer.see if tht works.
Posted on Jun 24, 2009
What does error code h3-00 indicate?
Sharp ARM 550/620/700 Reset Machine with Error Code ...
? 1:26
www.youtube.com/watch?v=BXs8PmMXFtk
May 5, 2011 - Uploaded by Thomas Trumpler hi thmas please tell me how to clear sharp mx-m620n copiermemory chip to use it ... How do I clear error code h3-00 on mysharp mx--453.
Sep 30, 2015 | Sharp DX-C401 Color Copier, Printer,...
What does code: H4-00 mean
The H4-00 is a low temp error in the fuser. This can normally be reset by doing the following at the machine:
On the button panel hit
pound, star, C, star
then enter 14, hit start, then execute on the screen.
This should clear any one-off errors
www.equipmybiz.com EquipMyBiz
Aug 04, 2014 | Sharp MX-4101N Multifunction Printer Color...
Firmware sharp
Firmware is normally updated by your local servicing sharp dealer. there were SEVERAL updates for that model being that it was 1st generation color in it's speed range.
Copier Collin Houston TX Copier and Imaging Expert
Jul 23, 2014 | Sharp Mx-4501n 4501...
Error code c4-oo
This is normally an authentication error when scanning to email.
Take a look at this walkthrough, it will show you how to utilize Gmail's SMTP servers using any gmail mail account. Setup Scanning to Email on Sharp Printer using GMail SMTP Servers
Feb 17, 2014 | Sharp Mx-2610n Color Copier, Printer,...
Error code F6-10 on Sharp AR-M236 how do i remedy
This indicates to me that there is a Fax module fitted to your machine. If this is the case it may have developed a fault. Do you use the fax? If not you could try removing it so that you can use your copier as normal.
Good luck
Follow me on Twitter @CDOS_Service
Jan 10, 2014 | Sharp AR-M237 Copier
I have a Sharp AR-M550N; It's giving me a code Network error CE -02? How can i solve that error?
CE 02 is rarely a machine problem, It normally is an addressing problem between the machine and the network. That code indicates a communication problem, normally relating to scanning.
Often times it is a wrong character in an address.
Feb 01, 2011 | Sharp AR-M550N Copier
Error code f9-10 and f6-80
while printing showing error 10
Mar 23, 2010 | Office Equipment & Supplies
303 people viewed this question
jasbo
jasbo
