Question about Air Tools & Compressors
Please tell me common problems of air compressers
  • 48 Answers
The biggest problem is water in the airlines. This can be avoided by adding an air dryer along with good filters and draining the tank daily. Other than this one should do regular maintenance like changing the oil in the compressor crank case as per manufacturers recommendations of more often if used in a dirty environment. Air filters should also be changed often as when they get dirty the restrict the air intake and the compressor will work harder than it needs to and there will be less usable compressed air available.
Posted on Mar 14, 2011
I have 97 dodge stratus that only blows cold air please tell me why
Hi lil..... The most common cause of the cold air problem is a stuck thermostat under the hood. Replace the thermostat and your problem will be solved. Joe
Dec 19, 2010 | Dodge Stratus Cars & Trucks
Looking at a 2001 XL800, is there any specific thing I should be looking for, common problems ect.?
Notorious for broken power valves, simple compression check should tell you unless both are broken, if there is a 15 to 25 psi difference between the 2 cyl chances are the one with higher comp is bad. Those valves change the port timing and are controled by the ECM. In short, the higher the EX port the lower the comp and vice versa IE the lower the port the higher the....
Sep 05, 2010 | Yamaha 12V Air Pump
My air compressor won't compress more than 40 lbs what can I do?
Your compressor is worn or dirty or both. Disassemble the head and inspect it. Look for dirt in the reed valves ... look for excess sloppyness in the piston (worn rings)
You may be able to repair this, expect to pay $50.00 for a kit (you dont ID the unit so I cannot make a recommendation) ... It may be cheaper to replace the unit rather than have it repaired professionally.
May 31, 2010 | Air Tools & Compressors
Not starting
Hi there
  • Low compression, and lots of blow-by forcing oil into the air filter via the the crankcase breather. Sounds like you need a top end rebuild. If you can get your hands on a compression tester, then check it. If it comes in under 120, then certainly time for a tear down and top end rebuild.
  • If you put a quick squirt of oil down the spark plug hole and if the compression pressure goes up on a second compression test, then rings/piston/bore are worn. If it does not come back up, then it may be leaky valves, or a blown head gasket.
  • do the compression test first. That will tell you where to start. Or, if you have the tools, tear the top end down and inspect. A motor re conditioner/machine shop will help to measure up and tell you if piston, and bore are ok. May just need new rings to freshen up.
Happy to answer any questions that you may have.
regards robotek
Apr 25, 2010 | 2005 Honda CRF 250 R
Will crank but won't fire
To run, the engine needs fuel/air mix, compression, and a spark. See if you can narrow your problem down to one of these. Remove the plug, then connect the plug wire and set (or carefully hold) the base of the plug against the cylinder head. Crank the engine and see if there is a spark. If not, the problem is in the ignition system.
If you see a spark, replace the spark plug. Remove the air filter and pour about a tablespoon of gasoline down the carburetor throat. Crank the engine, being careful to stay away from the carburetor in case it backfires. If the engine fires and runs, then it probably is not getting gas (fuel system problem), or not getting enough gas (carburetor or choke problem).
Compression problems are less common, unless the engine has been abused somehow. You can check for compression with a compression gage. Remove the spark plug, install the compression gage in the spark plug hole, then crank the engine with the throttle open and the choke off. If you get at least 60 or 70 psi when you do this test, the compression is probably not the problem.
Apr 18, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Compressed air tool Usage
Craftsmen often prefer a compressed air tool over an electric power tool for certain jobs. Drywall and trim work are both made easier and accomplished more quickly with pneumatic tools. The most commonly purchased compressed air tool duo for homeowners is the pneumatic drill and nail gun. If you are a homeowner shopping for compressed air tools, be sure you understand how different models work and how the power is supplied. Read the manufacturer’s directions for use and maintenance, and be sure to have the proper sized hoses, fittings, and air compressor.
Aug 27, 2008 | Campbell Manufacturing Campbell Hausfeld...
Cooling system
first check if the outdor unit turns on if it does it consist of 2 parts fan and compresser the compresser has a distinct sound if thats not starting you will not get cooled that problem could be one of 2 things it could be your capacitor of wich you are lucky or it cold be your compressor of wich you are not lucky if machine is over ten years of age and the compresor went recomend replacing entire machine if machine is under five years of age it may be covered under warantie hope i helped you
Jul 16, 2008 | Ruud UBHC Air Conditioner
Turbo kicks in better
Cold air is more dense, so that makes perfect sense. Also, a turbo compresses the air, which heats it up, so you lose some of the power gains, which is why intercoolers are so common.
May 15, 2008 | 2007 Subaru Impreza WRX STI Limited Sedan
Won't turn on
You can try to clean it out..you do this by following these steps: 1. Clean the inside of your camera by opening the back and then blowing the dust out with a can of compressed air, or with a bulb tool that blows air when you squeeze. 2. Clean the lens by blowing any dust off with compressed air. Use a special lens cleaner and lens cloth to thoroughly clean the surface. 3. Wet a cloth and wring out as much water as possible. Use this cloth to clean dirt off the camera casing, making sure no water seeps into the camera's interior. 4. Use a dry soft-bristle toothbrush to clean out the crevices of your camera's casing. 5. Rub dirty battery contacts with a pencil eraser. Although, this is not a common problem..if cleaning it out does not work you are better off going back to the store and either returning this item or demanding a repair service.
Sep 17, 2006 | Nikon COOLPIX L4 Digital Camera
Air Tools & Compressors Logo
55 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
