Question about Cobra Sport & Outdoor - Others
Hi got zd cobra rear mount vdrive totally snaped drive tail shaft and destroyed chrome surrounds need to know why and where to get replacement parts also need prop shaft as this also sheered of at vdrive at coupling cheers
  • sentaperley Mar 15, 2011
    hi do u know where i could get replacement parts from need tailshaft,prop shaft,shaft coupling,chrome tailshaft surrounds
    Guru:
  • 1,833 Answers
Hi, You may visit this site http://www.airgunsbbguns.com/
It has all kind of services for Cobra Sports and outdoor.
Posted on Mar 15, 2011
  • 2,926 Answers
The cayse may be related to an internal bearing that failed, causing the shafts and gears not to align, which then placed stress on the internal components. I'll be very honest, even if you did replace the tail shaft, the bearings and shims will need to be replaced also. You will need a dial indicator to measure the end shaft play and be exact on all tolernances when re-assembling. This procedure is not done without special tools and expertise. At this point, it is better to purchase a complete unit that is assembled by a Professional Tech to factory specs, otherwise it will just break apart again.
Posted on Mar 14, 2011
Is a 2004 ford f-150 2wd carrier bearing.. ( mid-mount bearing ) on driveshaft replaceable, or do i have to replace entire driveshaft?
it is replaceable
normally it comes complete in the rubber mount
you will have to undo the drive shaft flange at the bearing
remove the drive shaft and take it to an accredited drive shaft repair shop or take the vehicle to an accredited drive line specialist shop
the repair will require that you place the flange back on the shaft after the bearing replacement in exactly the right position or you will get harmonic vibration after the job so talk with the experts first if you want to diy
May 09, 2017 | Gateway Cars & Trucks
Car will start but will not move.
is it stick shift or auto box???
for stick shift check the clutch is working and the drive shafts are good
if the half shaft if snaped the prop shaft will turn but the car wont move!
if its an auto box check it is full of oil as well and then check the gear shift is working some times they just fall off,,,,,if the prop shaft is turning and the car wont move the fault is in the rear axle (drive shafts snaped)
Aug 08, 2010 | 1999 Ford Taurus
The brake lights that we need 2 fix r on the trunk /hood.( what holds the spoiler if there was 1) looked all over. either cant find or see or get 2 it?
This is right out of the manual. Hope it is what you are looking for. Cobra. :-) Lamp, Rear Hi-Mount Removal
  1. Slide rear hi-mount lamp cover (13A656) away from back window glass (42006) and remove rear hi-mount lamp cover.
  1. Remove one screw retaining rear hi-mount lamp (13A613).
  1. Lift edge of rear hi-mount lamp and pull away from back window glass.
Installation
  1. Follow removal procedure in reverse order.
  1. Slide rear hi-mount lamp cover onto rear hi-mount lamp to engage retainers.
    Hi-Mount Rear Lamp
    Item Part Number Description 1 921 Bulb 2 56929-S2 Screw 3 13A613 Rear Hi-Mount Lamp 4 13A656 Rear Hi-Mount Lamp Cover 5 15A442 Rear Hi-Mount Lamp Wiring
Jun 05, 2010 | 1997 Ford Thunderbird LX
I have a 2000 all-wheel-drive, the rear drive shaft is broken. I can't find the manual that covers Chrysler all-wheel-drive, it looks like the ABS monitor in it, and something from the transmission...
place a jack under the transmission and raise it a bit unbolt (the transmission mount) "i think thats what u mean its all i know that above the transmission holding it in place. You'll need a rachet wrench for this and a long onbe at that,, if not you can use a piece of pipe,, you'll want the extra power.. Unbolt it and lift it off,, if its still too tight jack the transmission up a bit.That providing your refering to the transmissing mounting rubber Which is all i can think you man its the only thing above the transmission. The ABS is 2 parts ,, its a mastercylinder and a booster. Its mounted on the firewall (its the thing you pour brake fluid in.) Unjack any wire or hoses by unscrewiung them and pluging them with something.. DUCT TAAPE or rescue tape works.. Unbloth both the mastercylinder and booster from the firewall... unmounting the drive shat.. well you'll see where it bolts ,, front and back.. Thats the easir part.. you will heed o happer, pull and tug the shaft until it pops out.. Hope I was helpful.. if you need more help please feel free to ask.
Mar 08, 2010 | Chrysler Town and Country Cars & Trucks
Is the motor from a 2004 Cobra an easy swap into a 1996 Cobra?
no you will need to change the exhaust, engine mounts, transmission mounts, tail shaft, trans cross member, wiring loom and computer if not more stuff i am shore it can be done but the expense will be huge
Oct 01, 2009 | 1996 Ford Mustang
How we mount the image in a virtual drive
If you already have VDRIVE or similar installed then select the image
right click and select MOUNT or INSTALL IMAGE (it may vary depending on the program you used to set up a virtual drive
Most of those programs integrate with the right click tool-bar.
Sep 08, 2009 | Computers & Internet
Rear transmission leak
it sounds like you have a tail shaft seal gone in the transmission it's not a difficult fix if you are handy. Remove the drive shaft and remove the tail stock seal(there are install and removal tools but a hammer and a screwdriver will remove it nicely)then replace with new seal (if you don't have the install tool a 5" long piece of 2x4 and a hammer works BE GENTLE!!!!)and reinstall drive shaft..........these seals are available at your local auto parts store and are usually no more tan $10.00
hope this helps!.........good luck!
Jan 11, 2009 | 2001 Ford Expedition
Violent vibration
i had same prob, it quit after alignment and balance tires
Aug 07, 2008 | 2000 Jeep Grand Cherokee
How to replace the on/off voulume switch?
Big, hi; I'll try to help out. I haven't had that model radio totally apart but on most radios, if you remove the top and bottom cover, on the sides you should see 2 screws per side that holds the chrome bezel to the chassis of the radio. Be careful removing the knobs so you don't destroy a pot in the process. Hope this helps you out, let us know,, Mechanic
Feb 18, 2008 | Cobra 200 GTL DX 4-Channels Base CB Radio
Sport & Outdoor - Others Logo
51 people viewed this question
Top Cobra Sport & Outdoor - Others Experts
Bill Eager
Are you a Cobra Sport and Outdoor - Other Expert? Answer questions, earn points and help others
