Question about Audio Technica ATW-RC1 3000 Series Foam-Fitted Carry Case for ATW-3110/3141 Systems
Audiotechnica atw 3110 with lavalier mic at 898 on wire instrument usualy works fine but on stage wery often sound form instrument with it start to transmit dirty sound some distorsion, like two untuned wire playing togather, we try everything (rescaning, reset all, remove mobiles phone from it and all that use wireless freq.) but no solution please help......
  • 604 Answers
Try changing frequencies, also make sure that the mic and the reciever are on the same frequency, what it sounds like to me is that it is set to the adjacent frequency, also be sure the batteries are fully charged.
Posted on Mar 14, 2011
Question about Peavey Escort 3000 300 watt portable PA, both right and left mains work fine, but the right speaker has distortion sound. Even if I change speakers the right out speaker circuit is dist
sounds like an internal connection problem. open access panel and check the solder connection is not broken or loose. Be sure the metal mesh jacket is not touching the lead wire as that would cause a scratchy noise and feedback, or maybe near the internal cable causing feedback
Aug 06, 2014 | Peavey Escort 3000 300 Watt Portable PA...
Lexicon alpha and gxl2200 microphone
Are you trying to use the mic input on the back or plugging it into the instrument input on the front? If you use a low impedance mic with a quarter inch instrument input cord, you would need a transformer adapter to make the mic work on high impedance. Even if you put it on line in, you would still have to convert it. Only the XLR socket on the back will work on a low impedance mic.
Mar 05, 2013 | Lexicon Alpha Personal Recording Studio
Low volume from Fishman Loudbox Mini mic input, using brand new XLR cable and dynamic mic. Mic works just fine on instrument input using a Hi-Z cable so problem is not mik
I have seen defective XLR cables so check it with an ohmmeter. It is possible the mic input preamp has been damaged. If that is the case, the unit will have to be repaired.
Aug 31, 2011 | Fishman Loudbox Mini Acoustic Amplifier...
My Tube PACS ( I have 2) channels short out. Either 1 or both. I got so tired of doing good takes that were destroyed by this, I just stopped using them. They are in my patchbay, but I've bypassed...
Check that you are using the CORRECT type of audio cables. Most interconnects require TRS (balanced) cables. Use of mono (TS) cables will often cause intermittent operation. When using TS cables, often a 6 Db loss is just the start of the problem.
Jun 27, 2011 | ART Tube-pac Studio & Stage Mic Pre & Comp...
The audio kept cutting in and out while using the Samson Stage 5T 3-in-1 Headset Wireless. It lost audio for about 30 seconds at a time. At the time, it was connected to a Samson MR 1064 Mixer that was...
The unit is SUBJECT to radio interference from other systems in the area such as high power taxicab radios for example and other services. 30 seconds might be about the time for a radio transmission. The system, while being interfered with, likely will NOT generate audible sounds and due to the squelch algorithm may MUTE the system.
Sorry, but you are a SECONDARY user per FCC definition and they are licensed and you are sharing bandwidth. You cannot interfere with them, but they can interfere with you. You should probablly get a UHF system that has less chance of interference. While recording, frankly I would be wired, not wireless. I am both an electrical engineer nd a HAM so I am aware of these problems.
Mar 28, 2011 | Samson Stage 5T 3in1 Guitar Lavalier and...
I have an american delux telecaster with noisless pickups and it started to produce and annoying buzz sound and i am getting electricuted everytime I play and touch the mic and i have a strong feeling its...
You are looking at the WRONG end of the guitar cable. You have a VERY unsafe guitar amplifier OR the mixer that is connected to that mic has an UNSAFE grounding condition.
If your guitar amp is an old one that has a two wire cord and a switch you change to reduce hum, take it in to have a three wire power cord installed IMMEDIATELY. Only plug into grounded receptacles. This is needed to reduce electrical noise and hum but MORE importantly is personel safety.
If the problem is with the mixer and the electrical service to the mixer, better get a professional in to analyze the problem before somebody is injured.
AS A START do this: VERIFY that ALL interconnected equipment INCLUDING your guitar amp iis powered from the same source or receptacle. This includes the venue power amps, mixer, any CD players, etc. Professionals run power back from the stage source to the mixer alongside their snake to avoid just the problem you are seeing. When they need more power at a venue, a power distribution box is used that conditions the building power and insures grounding.
Mar 25, 2011 | Fender American Deluxe Telecaster
Can not get any sound from my condenser mic through any channel on my new ProFX8 board. The Mic works throug other amps, the USB bypass allows me to play music files and all EQ/level functionality works...
When you get to page 13 of your user's manual, notably sections 6, 7 and 8, you'll find that Phantom power works on an XLR cable, not 1/4".
So, unless your Mic has batteries, you need a different cable.
Carl
Mar 05, 2011 | Mackie ProFX8 Professional Compact Mixer
I get little sound out of the microphone spots onm my DA-X10Pro. I have a karaoke THE SINGING MACHINE. When I use my karaokee machine mic plug in the mic works fine...but any voice into the mic...
The mics on the singing machine are very low end mics and MAY not work on your other unit. The Voco has very sensitvie inputs to use with "professional" type microphones. The Singing machine mics are going to be fairly high output and likely to overload the voco inputs. Procure some professional mics like Shure, AKG, Sennheiser or others and don't forget to use a balanced to unbalanced adapter or cable on the mics.
Jan 06, 2011 | Vocopro DaX10pro
Do phantom power only work for 3 4 mic input
Hello Aaron, I will need to have you clarify exactly what you are asking. The question could either mean the pin connectors on the sound board to the instrument / mics or can you connect 3 or 4 mics to a phantom power supply.
Nov 28, 2010 | Music
Audio Technica ATW-RC1  3000 Series Foam-Fitted Carry Case for ATW-3110/3141 Systems Logo
73 people viewed this question
Top Audio Technica Music Experts
Michial Gueffroy
Are you an Audio Technica Music Expert? Answer questions, earn points and help others
