Question about D-Link DIR-300 Wireless Router
I am using d-link dir-300 router and lately i cannot connect to the internet. when i clicked the "view status', IPv6 has limited connectivity and only the power ligapsocoht is ON. pls help
  • 126 Answers
This can normally be fixed by restarting the router
Posted on Mar 14, 2011
I cant get a internet connection with dlink dir-300 (cable or wireless), pls help, it's working when i tried with different router...
Welcome to FixYa! In regards to your problem there are possible options you could follow. 1. Check first if your computer is detecting the router. Go to your Network Connections and see if its detecting a connection with the D-Link router that you have. 2. I suggest go to this site that has a manual for setting up a D-Link DIR-300 Wireless Router.Check if you missed any of the process. Steps: Go to Google.com then type "cant get a internet Problem with the D-Link DIR-300 Wireless Router" and then look for DIR 300 Wireless Router Manual. There you will find all that you need in setting up your router. Hope this helps! Thank you for using FixYa!
Jul 04, 2011 | D-Link DIR-300 Wireless Router
I have a DIR-600 router to connect my Cable modem and use wireless connection to connect to the internet. It was all working fine till my modem LAN port got damaged somehow.I have changed the modem and now...
Try following this order before you connect your computer to the router.
power off all your equipment (cable modem & router & your computer's wireless card)
first, power on the cable modem, give it some time to boot up and get an IP from the ISP, say 30 secs.
then, power on the router, again, give it some time to boot and obtain its internet IP from the cable modem
finally, enable wireless on you computer and connect to the router.
if this doesn't solve the problem try resetting the router to factory defaults by pressing the reset button at its back for about 10 seconds with the router powered on.
This your router's manual it may turn handy:
http://global.dlink.com.sg/site_support/DIR-600/Manual/DIR-600_B1_Manual_v2.pdf
good luck
Jun 12, 2011 | D-Link DIR-600 Router
I need to ask about my problem. I just bought a D-Link DES-1008D and a D-Link DIR-300 Wireless-G Router my problem is after I attach 7 computers on my switch hub. I only have limited local network...
Make sure you're using a crossover ethernet cable to connect the router to the switch. Also make sure that the router has it's DHCP server up and running.
Nov 03, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
Hi I cant configure my router D-link DIR-300
Hi! I will be more than glad to assist u in this concern..Please dont use the setup cd or setup wizard. you can access the setup page of the router by typing at the url:192.168.0.1 then it will ask for the user name and password, by default the username is admin and the password, leave it blank.. here are the things u need to check before u setup u router.. .. if you are using a cable modem from ur cable company provider- u need to do a mac clone on the router u have to clone the mac address of ur computer. normaly the mac of ur computer is the one register to your cable company and on the setup page of the router just selct on the internet setup, dhcp after clonning the mac address of your computer. u need to connect ur computer directly to the router and then after doing the process connect the router to the modem. if u are using a username and password, u have to use the pppoe settings on the router, if ur isp set a static ip , set it up to the router, to check the ip setting of your isp.. connect the computer directly to the modem and check if u have internet.. then click on start, run and type cmd,it will give u a dos prompt and from there type ipconfig/all and it will show u the ip address, subnetmask, default gateway, dns server.. I hope this will solve ur concern..
Jul 29, 2009 | D-Link DIR-300 Wireless Router
D-link dir-615 cannot connect to internt
it could be a problem with your internet connectivity. check with the isp.
Jul 26, 2009 | D-Link DIR-615 Wireless Router
Dlink DIR-625 permanently stopped working. Connected directly to internet with dsl cable through sympatico and internet works fine but doesn't work at all when connected through Dlink DIR-625
you may need to reset the router and reconfigure the settings. please follow the steps below if you have a username and pw from sympatico.
1. Press the reset button for 30 seconds
2. Plug the modem to the internet port of the router. Check the internight light if lit; otherwise, use another known working cable.
3. Plug the PCs to the numbered port at the back of the router. Check the lights on the port number if lit; otherwise, use another known working cable.
4. Open a web browser and enter http://192.168.0.1 and press Enter. When the login window appears, set the user name to Admin and leave the password box empty. Click Log In to continue.
5. Click on manual configuration when prompted.
6. Select PPPoE on My Internet Connection and enter the username and password provided by Sympatico. Select Dynamic IP and Always ON options. Click Save Settings.
7. Click on Status tab and verify WAN status if connected. You should see WAN IP address when connected.
8. Try to open a browser and verify your connection.
Hope this helps!
Jun 25, 2009 | D-Link DIR-625 (790069292637) Wireless...
No connection to DIR-625
Make sure the modem is connect to your router under the WAN
Access the configuration page of your router. using the address bar.
type in 192.168.0.1
Username : admin and leave password blank
Under WAN choose dynamic and click on clone mac address.
Click on Apply then click on continue.
Go to Status if you have IP address it means you can connect to the Internet.
Mar 23, 2009 | D-Link DIR-625 (790069292637) Wireless...
D-Link DIR-300 Wireless Router Logo
193 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
