Question about Logitech ClearChat Style Headset Headset
I have the same problem as magepower "My
  • 37 Answers
SOURCE: about headphone and microphone jack
try to double check the driver on the device manager(controlpanel>device manager) if theres a yellow exclamation point then you have to reinstall the driver by inserting the recovery disc on the computer and install the driver again, If you cant see the driver on the device manager  then you have to buy another sound card which is cheap nowadays
Posted on Sep 18, 2008
wealthwise
  • 111 Answers
SOURCE: Cannot use microphone.
Hi I have had a similar problem with a Mic, too things to try , first try it on a different appliance to rule out the appliance you are using, if it still doesn't work then it's most likely a short somewhere, tough to repair but worth a shot if you have the patience.
Hope this helps.
Posted on Dec 06, 2008
  • 8 Answers
SOURCE: mic not working when headphone plugged in
Try changing the Windows Default Audio devices
  1. Go to control Panel
  2. Sounds and audio devices
  3. The Audio tab
  4. Then change the Sound Recording Device to Logitech Headphone INPUT
Hopefully this will work
Posted on Apr 07, 2009
  • 23 Answers
SOURCE: Computer Does Not Detect Headset Microphone
Sound and Recording jacks stop working on the DV6000 series due to the ribbon cable running under the power button. when the power button is pushed it bends the flex cable and over time it breaks the connection rendering the front jacks useless you can buy a new upper button panel for about 20 dollars on ebay
Posted on Aug 02, 2009
  • 136 Answers
SOURCE: Microphone suddenly stopped working
Try uninstalling and reinstalling your sound card driver. Also do the same for any software that has anything to do with your sound card. If this diesn't work, try restoring to a point before you had the problem. If you is usb and one is standard then it has to be soundcard or software, more then likely it's a driver issue.
Posted on Aug 12, 2009
External microphone thinkpad t41
Control Panel, Sounds, look at Recording devices (depends on the OS you are using, you didn't mention, Vista, XP, 7,8?), Mic. Your Headphones jack, when in use, will cause the internal sound to disable, depending on OS the mic setup is a bit different but you should find it in sounds, recording devices.
Nov 12, 2012 | IBM ThinkPad T41 2373 Notebook
I have a Macbook Air with Microsoft Word Home and Student 2008 installed on it. I use the audio recording feature on in Word to take notes in lectures, but since the internal mic was not enough to capture...
In sound system preferences when the external mic is plugged in, there is a drop down menu in the input tab that says "Use the audio port for:" make sure it says input.
Mar 22, 2011 | Apple MacBook Air
How can i use headphone's mic on my acer aspire4720z?
there are some ports in the front side of your laptop...try with one headphone with mic....please connect the ports with the cables of the headphone...
Jul 15, 2009 | Computers & Internet
Hp pavillion dv6000 headphone mics don't work, external mics work
check external mic in another system.
update the bios of the sytem.
update drivers of sound cards
Apr 11, 2009 | HP Pavilion dv6000z Notebook
Mic not working when headphone plugged in
  3. The Audio tab
Apr 07, 2009 | Logitech Premium Headset
Mic
Try a different set of headphone, if it works, then it is the headphone set.
If you get same problem with all headphones, then
If you get no sound: ensure that you have sound from speaker, if you get sound from speakers and no headphone working, then there is a problem in the headphone connection.
If you have no sound at all , not even with speakers, then check audio settings in control panel, ensure audio is not muted. If audio settings are OK, then you need to reinstall audio driver, or you have a faulty audio card.
Additionally, if it is only the mic not working then do the following:
Go to control panel and open sound and audio device.
Open volume settings and find settings for mic.
Tick off the mute option.
The mic is muted by default in Windows, that is usually the reason why it is not working.
Sep 14, 2008 | Compaq Presario 700 470024-192 Notebook
Headphone and mic
my presario c700 has a built in mic try just connecting headphones in and using the built i mic
Jul 23, 2008 | Compaq Presario 700 470024-192 Notebook
Logitech ClearChat Style Headset Headset Logo
Top Logitech Radio Communications Experts
Bharat Das
Bharat Das
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
