Dear sir i always facing the same problem at the starting of my desktop that your cmos setting wrong press f1 to run set up and f2 to fix the default values.please help me in this regard. thanks biswajit
  • 20 Answers
It looks like your CMOS battery is running out. Try to replace the new one, enter the CMOS setup and save.
Posted on Mar 14, 2011
Gateway gt5220 has cmos checksum error - defaults loaded
Open the cpu cabinet cover then pull cmos cell from motherboard for 10 minutes then all settings defaults.Then when you power up the computer press F1 or F2 or del or ALT+F2 key to enter in bios then set bios settings.Let me know if you need further assistance.Thanks for using FixYa
Nov 18, 2011 | Gateway GT5220 PC Desktop
When i switch off power and restart the pc i get error 'cmos/gpnv checksum bad' and sometime 'cmos setting wrong press f1 to set defaults or press f2 to enter cmos setup'. I replace the...
sir have you tried clearing the jumper settings. if it still persist remove power supply of board and cmos battery for 5 mins. Then try to startup.
Sep 14, 2011 | Asrock P4I45GV...
Start-up and shut down problems, When starting up it says, press f1 to continue, f2 to run set-up.... F1 works but I am getting tired of doing this. Now when the computer starts, it stops at...
Hi names Rui,
For your problem the computer may display a prompt to press F1/F2 or any other key to enter setup each time the computer boots as a reminder on how to enter CMOS. However, if the computer asks to press F1/F2 (or another key) to enter setup and does not continue, this may be caused by any of the below reasons.
  1. New hardware has been recently installed.
  2. Error or confliction with settings in CMOS.
  3. CMOS battery is bad or failing.
Solution:
If new hardware has been recently installed into the computer, it is likely that you are receiving the prompt "Press F1 or F2 to enter setup" because CMOS needs to verify that the new detected hardware is properly being setup in CMOS. Enter CMOS setup and save the settings and exit. If you continue to get errors continue to the next step.
If no new hardware has been added or you continue to get this prompt verify no error or conflictions exist in CMOS. Press the key to enter setup and verify that all settings are correct.
If your time and date are not set correctly, your battery is more than likely bad. Try setting the correct time and date, save the settings and then reboot. If after turning off the computer the time and date get reset again replace the battery.
If the time and date are correct and everything else appears to be correct try resetting the CMOS values to the defaults.
If you continue to receive the prompt to enter setup each time the computer boots up and you have attempted to follow the above suggestions, your CMOS battery is bad. We recommended that the CMOS battery be replaced.
hope this will help you.
Jul 20, 2011 | Dell Dimension 2400 PC Desktop
CMOS checksum bad Press f1 to run setup Press f2 to load default values and settinss Keeps comming up on star up
Your CMOS battery may be dead. That is the watch style battery on your motherboard. Choose f2. If the problem persists, change the battery
Feb 28, 2011 | E-Machines eMachines Desktop PC
As i turned on the monitor the screen shows CMOS WRONG PRESS F1 TO SETUP PRESS F2 TO LAOD DEFAULT VALUE
hi,
first of all check the main battery back of ur machine by unplugging from the mains power supply. if machine shuts off, then u have to replace the battery.and then set the date time etc by pressing F1. and then save it and exit set up. next it will not ask for F1 or F2.
if the main back up battery is ok, then another possibility is the CMOS backup battery of ur machine have some problem. that's why it loosed all the seted parameters. then u have to replace the CMOS battery of ur machine. normally 3V battery. then set the date time etc by pressing F1. and then save it and exit set up. next it will not ask for F1 or F2.
ok
Jan 13, 2011 | Dmm UT4000F Multi-Parameter Patient...
Hi, I really need your help, please help me. I get this CMOS Settings Wrong CMOS Memory Size Wrong Press F1 to Run SETUP Press F2 to load default values and continue ... and my keyboard doesn't work ...
press delete during boot up process enter BIOS then f1 for general help then run chkdsk/r/f which will automatically fix any corrupt files on your hard drive
hope this helps good luck
Oct 04, 2010 | Asrock P4I45GV R5 Motherboard
Cant get 4600i started. powers up but will not get past intro screen. screen shows F1 to continue and when i press F1 it tells me to press it again to retry reboot, F2 for setup options.
you need to go to cmos or bios setup, set all the date and time and proper boot setting there save and exit, it is a cmos or bios failure that causes these problems try replacing the cmos battery if the message still continues
Nov 22, 2009 | Dell Dimension 4600 PC Desktop
After post screen system ask to press f1 or f2
Is there another message besides the F1 or F2 prompt?
Does it happen to mention CMOS settings at all? Usually this will happen if your CMOS battery has died, and will be fixed upon replacement. It is normally a CR2032 lithium battery, easily obtained at radio shack, walmart, etc. and super easy to replace.
Jun 22, 2009 | Dell Dimension C521 PC Desktop
Cmos
You need to press F1 and go into the BIOS to setup and detect everything. You will need to set the date, verify it detects your hard drive and memory, and enable/disable items as you need for your system.
Once it looks good, do a Save and Exit.
Jan 16, 2009 | Computers & Internet
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
