Question about Fujitsu Heating & Cooling
Blades wont open when aircon is turned on! - Fujitsu Heating & Cooling
    Genius:
  • 1,157 Answers
Hi lib5,
If your having problem with the fan blade it might be the condenser fan motor have a bad bearing or the motor is already burned out. There are several ways on how to check this issue, either you turn off the machine and try to check if the fan blade can move freely or check if the contractor is pulled in. Please follow the steps below for additional guidelines on how to check the fan blade.
1. Turn off the system completely.
2. You can use a long screwdriver to check the fan. Now try to turn the fan blades. If you noticed that it's difficult to spin, you need a new fan motor. But if fan blades can move freely that doesn't mean that the motor is working, it means that the bearings are ok.
3. Now please check the contractor. Contractor is a type of switch located in the outdoor unit. Please check if it is "pulled in". If it is pulled in, the motor doesn't spin, so you need to replace the motor.
Please leave the power off until the unit is repaired.
Hope it helps.
Thank you for using FixYa.
Posted on Mar 14, 2011
My pajero v6 3.5 usually when i turn the aircon on then i shift the gear to drive the rpm just drop and turn off the engine, but withou turning on the aircon the engine wont stop what seems to be the...
the engine doesn't like the extra stress of the air con unit being run _ there is no way of fixing this _ unless you get a full engine overhaul or a secondhand engine and installed _ the engine is old and the extra pressure on it with the aircon it just cant handle it
May 27, 2014 | 2000 Mitsubishi Montero
How do i take apart my 3206 international disc mower the three outside blades dont engage
The above comments do not apply to a 3206 disc mower.This is a hay mower not a lawn mower.If the three outside blades aren't turning you more than likely have a broken drive shaft.
Jun 06, 2012 | Garden
Once you turn on aircon with fan with high speed, the air blown doesn't get cold even after a while. The fan makes some wierd high pitch sound as if like metal against each other. The fan stops once in a...
Your AC needs a good overhauling as the fan seems struck on the bearings or the blades are rubbing the sides. Also the compressor fails to cool as there can be low gas, low pumping pressure or a blocked condenser.
You need to remove clean the coils and lubricate the fan to be set back. Check the capacitor to the fan and compressor as a low value will reduce the speed and so reduce pumping pressure.
Apr 11, 2011 | Heating & Cooling
It wont clip. sounds like it is working but the blade wont move. thanks
Open and clean the blades well use some light oil to clean . it is possible that the cut hair had entangled into the moving parts and joints. You must always clean the blades with the given brush after the shaving is done. If the blades are not moving then the gear drive from the motor is defective or worn out. you will need to open out the assmebly to confirm on thisbut replcement will be difficult. Hope you try. Good day
Aug 14, 2010 | Health & Beauty
My samsung ac wont turn on at all. according to the wall plug its getting power but when i press the buttons nothing happens, this just started a few days ago
Ok, for the, start if this is a box type aircon, electronic control and solid state thermostat.For the sake of reference.
The problem could be your power outlet lack the other line. Its should be two wire that is completing the power source. Check this first, maybe a troublesome outlet or power plug or the power chord.
Next could be the aircon unit itself, defective power section, or controller section. Blown fuse,lizard insect mouse are common cause.Also bloated or defective capacitor.
But if you are not inclined or do not have any background to electrical and aircon troubleshooting the much safer and practical way is to call an aircon technician. To do the checking for you.
Regards
Jul 09, 2009 | Samsung AW1203B Air Conditioner
Timer green light flashing when turned on but aircon isn't workn
reset the unit by disconnecting the power supply for 10 sec. then "on" again and start the unit. If it wont work you need a qualified tech. to solve the problem.Some of your safety device might be defective.
Jan 31, 2009 | Heating & Cooling
Not turning on
Hi
Try to reset the unit by disconnecting the power supply for 10sec. and operate the unit. If it wont work replace your Room Air and Coil Thersmistor or test the thersmistor with mulitester. The resistance reading of thermistor is 10 kilo ohms @25deg. C room temp. If it is shorted or open the unit wont operate.
Hope this can help :)
Dec 30, 2008 | Carrier 36KCARMS Air Conditioner
Heating & Cooling Logo
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Donni Steen
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
