Eclipse radio model number cd3422 say help when turned on diplays 7a201418
  • 2,071 Answers
It is a loose connection or cold solder and cleaning problem this is the main caused of no sound..Cold solder issues - each component is soldered into small holes on the printed circuit board which in turn connects said component to the other components. Due to time, heat, use, some solder joints would be cracked or loose. It is possible that the cold solder is still minimally connected (hanging by a thread). When the receiver turns on heat would be generated which would be sufficient to further loosen up the solder joint to the point it no longer provides electrical contact. Jarring the unit creates movement inside enough to re establish the contact, sometime good enough sometimes not enough.
Again, since the unit still operates (sometimes) then it is highly probable that there are no defective components. As you have surmised, it is possibly a loose connection, solder joints are "connections" except that molten soldering lead is used to attach/connect the component to the board, "loose connection" in this sense is equal to "cold solder".
Again on the assumption of no defective parts, then seeking a more experienced buddy for the soldering might be to your advantage. This is of course in addition to the possible electrical hazards when repairing....
Good luck:
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Aug 07, 2008
How do I find a manual for an Eclipse Stereo model #CD3422 Date June 2002
Hello there.
Closest I could track down is CD3424 Looks like it MUST be pretty close to 3422.
Downloads are on this page
http://www.eclipse-web.com/us/download/manual/manual/index.html
Sep 22, 2014 | Eclipse CD3422 CD Player
I need a user's manual
I can help you source an Eclipse CD player manual.
The eclipse website has no reference to a CD3421 unit. Perhaps I have the model number wrong?
Hopefully one of these two manuals will be close enough to your model to answer your questions:
Eclipse CD3424 Manual Download
Eclipse CD3434 Manual Download
I hope that helps.
Apr 03, 2010 | Eclipse CD3422 CD Player
Need manual for Eclipse 4422 head unit.
Try Google'in for a PDF doc using the model number
Mar 15, 2010 | Eclipse CD3422 CD Player
Eclipse cd3422 not working only shows 7AB00025
You need to enter the code or the Cd that you chose to be your key. The unit is security locked.
Aug 25, 2009 | Eclipse CD3422 CD Player
How to unlock a eclipse cd5423 stereo
ATTN: All AVN units do not have an Electronic serial number, will need
to physically pull out unit to get serial number and make sure unit is
registered
Please have the following information before calling the Service
Department at (1-888-557-8278):
• Dealer account number {Applies to Eclipse Dealers ONLY}
• Customer First and Last name.
• Model Number.
• Serial Number
They charge $25.00 for security code good luck..
Jan 09, 2009 | Eclipse CD3422 CD Player
Error codes
unplug radio to run antenna now radio screen display's SEC help then numbers come up at the bottom of SEC . This is for a eclipse3000
Oct 02, 2008 | Eclipse CD3422 CD Player
Eclipse CD3422
When you first set up the stereo, you inserted a security CD which was a CD of your choice. You need to just place that same CD in and it should restart your radio
Aug 12, 2007 | Eclipse CD3422 CD Player
Set up problem on eclipse cd3422
call 1-800-233-2216 (Fujitsu ten) and they will assist you in the removal of the security code for a $25 charge. the number being displayed is probably the serial number of your unit. If you can remove your radio the SN will be on a tag.
Dec 31, 2006 | Eclipse CD3422 CD Player
Eclipse CD3422
The microprocessor has gone bad and needs to be replaced. Take it to an authorized repair center and they'll help you out ;)
Jul 29, 2006 | Eclipse CD3422 CD Player
23 people viewed this question
 Grubhead
Grubhead
