Question about Acer Aspire One Netbook 8.9" Notebook
Yes I have an Acer One model AO532h that when I turn it on I get the following message..."Check cable connection! PXE-M0F: Exiting Intenl PXE ROM. No bootable device -- insert boot disk and press any key". I have checked the hdd several times to make sure that there is a good connection and there was. I run this netbook with a dual boot os. Linux Ubuntu 10.10 and Windows 7 Starter are the two. When I boot into Linux with my thumb drive I can see the hdd and the partitions on it. Heck the other day just for grins I installed another version of Linux on it but still could not get to it because again we are back to my question...where is my hdd? BIOS says there is not a hdd and even when I remove the hdd I get the very same message. Is there anything I can do to fix this problem?
  • Acer Master
  • 11,800 Answers
The message is generated because the southbridge is no longer in communication with the hdd - the hard disk itself is failing - the electronics board to be exact. You will have to replace it.
Posted on Mar 14, 2011
No bootable device PXE-M0F
You need to disable booting from the device in the Bios. It will be under the Boot options menu. Uncheck it from the list of devices to boot from.
Aug 22, 2012 | Acer Aspire 9300-5349 Notebook
When I click F2 -want password : I get the following error message: Check cable connection! PXE-M0F: Exiting Intel PXE ROM No bootable device -- insert boot disk and press any key
I hope that you have the DVD Recovery Disks because your operating system is malfunctioning.
If you have the disks, you'll have to use an external CD/DVD Player.
In the alternative, you'll have to install XP/Vista/7. Please connect me if you need detailed instructions.
May 23, 2012 | Acer Aspire One D260 Netbook
My acer notebook is giving the following message PXE-E61: Media Test Failure, check cable PXE-M0F: Exiting Broadcom PXE ROM. No bootable device -- insert boot disk and press any key I tried eRecovery...
From working for Acer Repair centre this message means your hard drive or SSD drive depending on model has a fault with it and is broken the only way around this is to buy a new one or if its in warranty you will need to send it in for repair usually free if its covered. Kronoguy.
Jun 29, 2011 | Acer Aspire One Netbook 8.9" Notebook
I get an error message on startup on my Acer Aspire 5100, it says Realtek RTL8139(x)/8130/810x PCI Fast Ethernet Controller v2.13 (020326) PXE-E61: Media test failure, check cable PXE-M0F: Exiting PXE...
It is beacuse your Hard drive is not detected on the computer properly.
Try resetting BIOS.
If that doesnt work, Check whether your hard drive is good.
Nov 28, 2010 | Acer Aspire 5100 Notebook
When I turn my laptop on a black screen appears with: PXE-E61: Media test faliure, check cable PXE-M0F: Exiting Broadcom PXE ROM. No bootable device -- insert boot disk and press any key I do this and...
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. Please click on this link and follow my instructions :- http://www.fixya.com/support/r4377704-pxe_e61_error
May 29, 2010 | Acer Aspire 5720-6661 Notebook PC
When I turn on my Acer minilaptop it say: Check cable connection..! PXE-E63: Error while initializing the NIC PXE-M0F: Exiting Intel PXE ROM No bootable device--insert boot disk and press any key
Your BIOS setting or boot order was changed to enable network booting (Intel's PXE).
reboot,tap F2 to enter BIOS and navigate menu to disable network booting.
Mar 20, 2010 | Acer Aspire One PC Notebook
Keep getting the following message when I turn on my Acer Aspire 5050 laptop: PXE-E61: Media test faulire, check cable PXE-M0F: Exiting PXE ROM Operating System not found
PXE bootup means the computer does not boot up from an operating system installed on a hard disk drive. PXE bootup uses a server on a network to boot up the computer.
It will not start without being connected the network that it was programmed to run on
Nov 16, 2009 | Acer Aspire 5050-3242 Notebook
Media test failure,check cable, exiting bordcom pxe rom os not found
check connections of hard drive. 2nd check boot order in Bios, remove Lan or network boot from top order. 3rd choice if not solved reset bios by removing cmos battery and putting back in to clear it.
Char S.
May 24, 2009 | Computers & Internet
your e-machine is set to boot from the network (PXE = Netboot)
go to your BIOS and make sure you boot from your hard drive
Aug 31, 2008 | Acer Aspire 3680 Laptop
PXE-E61:Media Test Failure
you got that error message because your harddrive isnot detected so it try to boot from network and you don't have OS in the network.
Most of the time is your hdd is dead. In some cases the motherboard is dead.
You can replace your hdd.
for OS (vista vs XP), if you have enough rams and high cpu, you should install vista, but for me, I prefer XP.
for the price, you should call microsoft seller.
Jul 05, 2008 | Acer Aspire 5050-3242 Notebook
Acer Aspire One Netbook 8.9" Notebook Logo
108 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
