Question about Garmin nuvi 250W GPS Receiver
I need mapps for my garmin - Garmin nuvi 250W GPS Receiver
  • 2,335 Answers
There are many sources of free maps for your Garmin Nuvi.
Try here, or here or here.
Posted on Mar 14, 2011
2003 dodge caravan runs rough floods it self out trying to start cold will not go over 40 mph let it warm up runs drives like new no engine lights on
Sounds like a sensor. Cars in general, at least for the past 15 yrs or so, have 5-7 basic sensors, in common. Mostly due to fuel injection. I would remove a sensor after U have had it running for 20 mins. Start with Fast Idle Sensor, Cold Start Sensor, Air Speed Sensor, Air Temp Sensor, MAPP sensor, (actualy it wont run without the MAPP. But U can get it Tested. Even the people at Auto Zone, or Checkers Can test most of the basic sensors. And if U R familiar with a Volt Meter, U can too
Mar 17, 2014 | Cars & Trucks
Can't loosen tension pulley to put on belt
I really like pb blaster. May take a while to soak in well worth a try. If that fails Terry to heat the nut with a torch. You don't need an ixy acetelyne set up a propane or mapp gas set up should do the trick. Propane is lower in heat than mapp gas and keep an extinguisher handy.
Nov 23, 2013 | Kubota Garden
Codes are reading low tps voltage, mapps high voltage ignition on low voltage at idle. Idle surges sputers and stalls when driving. Replaceed mapp and tps with no improvment?
Have you consider to check the battery power. I believe the main problem you have is either the battery or the alternator. Due to these two things with low voltage the brain ( ECU ) does not have the enough power to work. Good Luck.
Aug 15, 2012 | 1992 Chevrolet S-10 Blazer
Check engine light is on need a mapp sensor
go to a auto parts store. or dealer and buy one. good-day !
Sep 23, 2011 | 2005 Ford Five Hundred
Not enough heat using natural gas and oxygen
Try mapp gas.........I have a small torch with mapp gas and works well for small stuff. Hardware store/Home Depo.............
Dec 20, 2009 | Smith LITTLE TORCH 23-1001D JEWELER'S...
Starten des Dienstes... fehlgeschlagen. Error 0x80070002
Follow these steps...
Klicken Sie Anfang.
Wählen Sie Lauf.
Im Lauf-Kasten, Typ services.msc.
OK klicken.
Richtiger Klick der Automatische Aktualisierungsdienst.
Klicken Sie Halt.
Das Aufhören des Dienstes wird einen Moment nehmen.
Löschen Sie den Inhalt der DataStore Mappe
Klicken Sie Anfang.
Wählen Sie Lauf.
Im Lauf-Kasten, Typ %windir %\SoftwareDistribution
OK klicken.
öffnen Sie die DataStore Mappe.
Löschen Sie den ganzen Inhalt der DataStore Mappe.
Schließen Sie das Fenster.
Fangen Sie den Automatischen Aktualisierungsdienst an
Klicken Sie Anfang.
Wählen Sie Lauf.
OK klicken.
Recht
Schizoic
Jan 07, 2009 | Edirol UA-4FX External Sound System
4.9 liter will idle but wont accelerate have to start with ether
yes checked fuel pressure and replaced the fuel filter, checked the mapp sensor,tested throttle position sensor, has strong spark, 50psi fuel pressure, fresh tune up, runs real rich and rough idle but wont rev up like fuel injectors arent speeding up, also checked exhaust. thanks julius
Oct 09, 2008 | 1990 Ford F150
87 ford bronco
I had a similar issue with my 88 XLT w/351w. It was the beginning of a problem with my MAPP sensor. After a wjile I could hardly keep the truck running at all. I changed the MAPP sensor and made sure the timing was still on and now it runs fine.
Aug 26, 2008 | 1995 Ford Bronco
Garmin nuvi 250W GPS Receiver Logo
222 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
