Question about Pioneer VSX-815-K Receiver
Disply showing only 5.1 how chaing 7.1? remot option not working (in dvd key)
  • 604 Answers
You have to have a 7.1 sound on the DVD in order for it to be detected. make sure to buy or rent a DVD that indicates on the back that it is recoreded in HD(X) sound or 7.1 sound. I hate to tell you, but there are not many that are recorded that way, there are a few that are 6.1 but the majority are 5.1 sound. you may be able to purchase a test DVD that will have various types of sounds on it as well as differnet videos to try, these disks are made to help people set up their HD sets and sound systems. big box stores like Best Buy etc may have one., or you could order online through a google search good luck
Posted on Mar 14, 2011
How to turn off car mode on HTC Cha Cha?
1) To enable / disable Cardock go to an empty screen where you can add
icons/shortcuts
2) Press the bottom "Menu" key
3) Choose + (Add to Home)
4) Choose "shortcut"
5) Choose "settings"
6) Choose "car dock"
7) Press car dock
8) check or uncheck car dock as you please CAR MODE Android Forum AndroidPIT
Aug 16, 2016 | HTC Cha Cha A810e Android 2.3 Unlocked...
Not playing NTSC DVDs
I can see if there is an unlock code for your device
Apr 21, 2008 | Yamaha DVR-S150 DVD Player
How can I change my Sony RDR-VX530 to a multi region DVD planer?
Follow the below instructions closely;
1. In order for this hack to work, you will have to send an infra-red code to your player with a OneForAll remote such as the OneForAll 6 (or URC7560) or OneForAll 4 (or URC7740) or OneForAll 4 Digital, or One For All 5 Digital (or URC 7555) with the following instructions:
* Press the DVD button
* Hold down the Magic button until the unit performs a double LED flash
* Configure your remote using the setup code 0 5 3 3
2. On your DVD recorder, using the official Sony remote, select the System-Menu option
3. On your DVD recorder, using the official Sony remote, select the Setup option
4. On your DVD recorder, using the official Sony remote, select the Options option
5. On your DVD recorder, using the official Sony remote, select the Command-Mode option
6. On your DVD recorder, using the official Sony remote, select the DVD1 option
7. On the official Sony remote, set the DVD1 option for the Command-Mode switch, under the sliding cover
8. Verify that both the official Sony remote control and your OneForAll remote control can power off and on your DVD player
9. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 9 9 4 or 0 0 9 9 4 if your remote only accepts 5 digit codes
* Press the Magic button once
* Configure your remote using the setup code 1 8 9 or 0 0 1 8 9 if your remote only accepts 5 digit codes
* Press the 1 button once, a double LED flash should occur
10. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 2 5 5 or 0 0 2 5 5 if your remote only accepts 5 digit codes
* Press the 2 button once, a double LED flash should occur
11. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 0 9 5 or 0 0 0 9 5 if your remote only accepts 5 digit codes
* Press the 3 button once, a double LED flash should occur
12. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 2 2 1 or 0 0 2 2 1 if your remote only accepts 5 digit codes
* Press the 4 button once, a double LED flash should occur
13. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 0 7 9 or 0 0 0 7 9 if your remote only accepts 5 digit codes
* Press the 5 button once, a double LED flash should occur
14. Place your DVD player into Standby mode
15. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time
16. Your DVD player should show the words TIMER OK
17. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time
18. Your DVD player should return itself to Standby mode
19. Remove the batteries for significant period of time to wipe the programmed codes on your OneForAll remote
Good luck.
Jan 14, 2011 | Sony RDR-VX530 DVD Recorder/VCR
Viore 7 tv no picture and tv disply
it is possibly you have put it into Cable mode or Video mode or even channel 3. also check and see if the remote has vcr/tv or tv/video you might have pressed this and that is why your tv is blank.
Feb 11, 2010 | Televison & Video
Samsung dvd-85k unlock code
Samsung DVD-V8500K
1. The player should be powered on, the tray closed without any disc inside, the logo "DVD Video Samsung" visble on screen and the message No Disc must have already appeared.
2. Press the "Subtitle" key on the remote - "No Disc" should disappear.
3. Using the remote control, key in the code
"5, 3, 8, 1, 4"
4. A number should appear - this is the player's region number that was last programmed.
5. Press the number of the region you require, or 9 for region-free.
6. Press the "Subtitle" key on the remote - region number should disappear.
7. Press Standby on the remote control.
NOTE:
Origin of this player is Region 5 so it`s a default setting
If code "5, 3, 8, 1, 4" doesnt work try this codes:
Region 1 - 2, 9, 3, 3, 4
Region 2 - 3, 8, 7, 6, 7
Region 3 - 5, 6, 7, 3, 2
Region 4 - 7, 6, 8, 8, 4
Region 5 - 5, 3, 8, 1, 4
Region 6 - 2, 4, 4, 6, 2
please rate me. its most helpful
Nov 07, 2009 | Samsung DVD-V85K DVD Player / VCR Combo
I want the code to play Zone 2 DVDs on my DVD which is set for 4
1) Turn on the player with no disc in the tray
2) Press the Open/Close button to open the tray
3) Press the info button, the firmware version shows up (
4) After the version info disappears, close the tray again by pressing the Open/Close button
5) At this point, it will show "no disc" at the top. Press the Info button again, and this will disappear. If the "no disc" does not disappear then try again by using the REPEAT button
6) Now type the code that applies for your region (R2 is 57538). A '2' will briefly show up at the top left corner
7) Now press 9, and 9 will show up in the top left corner
8) Power off the player, and turn it on again. You'll have a multi region player
I've found the following codes at the 1080P7 hack:
R1 - 29334
R2 - 57538
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
This worked on my dvd1080p9 R2 DVD player
Oct 17, 2009 | Samsung DVD-1080P9 DVD Player
Is this dvd player a multi region dvd player?
Its Not But you Can Make It.
Just Take Out The Dvd And
1.Power Off The Unit
2.On The Remote And Hit Display, Top Menu, Clear, Power A Menu Will appear on The Screen.
3.Select option 2 (Drive Manual Operation),
than option 4 (Tray Aging Mode). The screen will show two input lines, each with 5 digits
4. Change The Top Line To 12450
5. Then 00000 On The Second Line And Press Enter
6. The Disk Door Will Open And Close A Couple Times
7. Repeat Steps 3-5 and enter both Codes As All 00000
A Long Process But It Works.
Hope This Helps.
Sincerely,
Michael Scott
Jul 14, 2009 | Sony DVP-NS575P DVD Player
I can,t play my dvd
Hehehe heres something I can help you with^^ Let me know if it works^^
1. Turn on the unit
2. Open the loading tray
3. Press the "Setup" button on the remote
4. Navigate to the "Preferences" page using the right arrow key
5. Enter 138931
6. You will now see the current region code displayed
7. Use the Up/Down arrow keys to select the region required or "0" for all regions
8. Press the "Play" button on the remote
That's it.
If you find that the player did not save your region setting. after step 7, switch the player off and back on again. but let's first see if it works like that^^
Mar 24, 2009 | Philips DVP5140 DVD Player
Onkyo DV Sp500 DVD player set for US region but i Have DVDs from Australia - is there a code to unlock the player or do i need to purchse a new one?
icon_minipost.gifRegion code hack posted by Victor Lazlo, July 14 2003:
Steps to change Region code:
1. open setup menu (with setup key)
2. select menu point 'General' (dt. 'Allgemein')
3. select sup-menu point 'Setup-Menu Mode' (dt.Setup-Menü-Modus)
4. at 'Setup-Menu Mode' select 'basic' (dt. Einsteiger)
5. confirm 'Basic' sellection with 'Enter' key
6. now push 'Display' key at your remote control, the present regent code will be displaid
7. to change the region code push 'Condition Memory' key (COND.M) at your remote control, afterwards a number key representing the region code you want to select
8. after a successful change, the disply of ther regional code will disappear
9. if pressing the 'Disply' key again the changed regional code will be shown.
Remark: Macrovision copyguard in gerneral will be switched off after that modification
refer to:http://www.videohelp.com/dvdhacks
Jan 25, 2009 | Onkyo DV-SP500 DVD Player
Is it multiregional
Sony are probably the most protective manufacturer of this kind of information. All manufacturers carrying a DVD logo are obliged to say "no" but will normally intentionally leak this to boost sales, particularly in non-US areas.
But try this:
  • Press the DVD button
  • Hold down the Magic button until the unit performs a double LED flash
  • Configure your remote using the setup code 0 5 3 3
2. On your DVD recorder, using the official Sony remote, select the System-Menu option 3. On your DVD recorder, using the official Sony remote, select the Setup option 4. On your DVD recorder, using the official Sony remote, select the Options option 5. On your DVD recorder, using the official Sony remote, select the Command-Mode option 6. On your DVD recorder, using the official Sony remote, select the DVD1 option 7. On the official Sony remote, set the DVD1 option for the Command-Mode switch, under the sliding cover 8. Verify that both the official Sony remote control and your OneForAll remote control can power off and on your DVD player 9. Program your OneForAll remote with the following instructions:
  • Configure your remote using the setup code 9 9 4 or 0 0 9 9 4 if your remote only accepts 5 digit codes
  • Press the Magic button once
  • Configure your remote using the setup code 1 8 9 or 0 0 1 8 9 if your remote only accepts 5 digit codes
  • Press the 1 button once, a double LED flash should occur
  • Configure your remote using the setup code 2 5 5 or 0 0 2 5 5 if your remote only accepts 5 digit codes
  • Press the 2 button once, a double LED flash should occur
  • Configure your remote using the setup code 0 9 5 or 0 0 0 9 5 if your remote only accepts 5 digit codes
  • Press the 3 button once, a double LED flash should occur
  • Configure your remote using the setup code 2 2 1 or 0 0 2 2 1 if your remote only accepts 5 digit codes
  • Press the 4 button once, a double LED flash should occur
  • Configure your remote using the setup code 0 7 9 or 0 0 0 7 9 if your remote only accepts 5 digit codes
  • Press the 5 button once, a double LED flash should occur
14. Place your DVD player into Standby mode 15. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time 16. Your DVD player should show the words TIMER OK 17. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time 18. Your DVD player should return itself to Standby mode 19. Remove the batteries for significant period of time to wipe the programmed codes on your OneForAll remote
Nov 27, 2007 | Sony DAV-S500 System
Pioneer VSX-815-K Receiver Logo
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
