Question about Casio Watches
Hi I am the proud owner of an early 1980s G Shock watch, model DW-5700. The plastic cover surrounding the watch body is broken and i require a new one. Any tips would be appreciated! Cheers Mike
    President:
  • 2,501 Answers
The only place to go to get a new replacement is back to Timex. They may not be able to replace it as it is rather old but you never know your luck.
Go to Timex.com and at the bottom of the page is "contact us". Send them your question and hope for a positive reply.
Good luck.
Posted on Mar 14, 2011
Dw-6600 need a manual for my watch, where to find one on-line
Hi.
Please click on the link below to open the manual for your Casio G-Shock (DW-6600 module 1199):
Casio owners manual.
Regards.
Ginko
Sep 08, 2011 | Casio Watches
I changed the batt. in my casio g shock dw 5600e and the screen will not light up.
you had to reset it by shorting it, it is located inside your watch. or push all the buttons at the same time. i hope i had been helped you.
Jul 21, 2011 | Casio DW-5600E-1VCT Wrist Watch
My g-shock watch model# DW 5700 displays a rectangular nox in the upper right corner with the letters "REM" below it. I've installed a new battery and this is all I get. None of the function buttons...
Rem is the reminder function of the watch , you can turn it off and on by holding down the bottom right button usually on casio watches. You can also find the online manual here http://world.casio.com/wat/download/en/manual/
please rate solution
Oct 18, 2010 | Casio G-Shock GW300CA-1V Wrist Watch
Does the g-shock illuminator dw-9052 have the option to light up if you flick your wrist fast...instead of pushing the button ?
I don't think your watch has this sort of option. You can find out yourself by finding CASIO watch manual link in my tips.
Feb 02, 2010 | Casio G-Shock GW300CA-1V Wrist Watch
Spring poppedout on dw 6900 g shock. need a
This happened to mine, couldn't get a spring anywhere. But managed to fix it by using a staple which I cut to size, Works fine now.
Oct 23, 2009 | Casio G-Shock G7000D-8V Wrist Watch
I've changed my battery on my casio g-shock dw 003 but the illuminator no longer works! why?
Did the same with my DW-003 and thought I'd broken the Illuminator (and the alarm didn't work). Next battery change was via a shop and the illuminator worked again (as did the alarm). This was just a battery cahnge, rather than a repair job - One of those things, I guess
Sep 30, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
New watch strap
I got mine from ebay. Its tough to install but I used a pen knife and a very small sdrewdriver. you can do it.
Good luck,
Techjoel
Feb 17, 2009 | Casio G-Shock G3110-1V Wrist Watch
Casio G-Shock alarm not working
The alarm should be sounding. (broken?) To turn hourly chime on and off, go to alarm screen and select SIG. Then top left button turns it on and off.
A -- B
( ) Button reference
C __D
6) Hourly Chime (SIG):
Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG).
Press D to select hourly chime (SIG). Press A to toggle chime on and off.
Press C to return to Timekeeping mode.
Good luck,
Techjoel
Feb 04, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
Model & spring issue with an ol casio G-Shock when replacing batt
This spring is connector to caseback for transmitting sound. Get an eyeglass and find out on movement backplate written SPRING COIL and put it back. If there is no marking SPRING COIL then check for the hole with approx. same diameter as spring (must easy fit in). The hole shoud be empty with contact spot at the bottom. Put the spring in and close the caseback. Check alarm sound. If it works, you did find the right hole- if not, try again till you find the right one.
Good luck
Arthur
Dec 13, 2008 | Casio DW290 1V Classic Alarm Chronograph...
Watches Logo
47 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
