Question about Dell Axim X50 Pocket PC
X51 powers off and wont boot after disconnecting from USB sync/charging cable. Doesn't matter if I unplug cable from power/usb end first, and doesn't matter if Axim is on or off after disconnecting. I don't want to Have to pop battery out and back in every time I charge or sync this device. Any fix?
  • tomxypdq Mar 14, 2011
    I have many batteries, and swapping them out does not help. I have many different USB/sync dongles attached to different power supplies as well. I know someone selling 4 devices with this problem (common Dell Axim issue it seems) - so I'd like to fix mine first and then buy the 4 I will be able to fix - if possible.
  • Dell Master
  • 13,433 Answers
Hi
if the pda works again just be removing the battery for a moment and then re attaching it, it seems like a hardware problem. What you could try is a hard reset to restore the unit into factory defaults but its unlikely to solve the problem.
Either the charger is not working properly or your unit is malfunctioning. Only hope of actually fixing the problem would be to send the dell to repair, dell will most likely replace the entire mainboard of the unit. as the components are too small to be replaced by hand.
reset instructions available at
http://www.hardreset.eu/dell_axim_x51_hard_reset_soft_reset_en.html
Posted on Mar 14, 2011
    Problem Solver:
  • 12 Answers
To me this sounds like a faulty battery which can easily be replace. Try searching for a new battery online and im sure this problem will fix itself.
Tt099 fone wont charge tried new battery
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Oct 31, 2012 | Cell Phones
Tt099 fone wont charge up
First Option:
Second Option:
My galaxy S wont charge
First Option:
Second Option:
Oct 15, 2012 | Samsung SGH-E316
My c3050 wont charge
First Option:
Second Option:
Oct 01, 2012 | Samsung C3050 Cell Phone
Toshiba camileo s10 wont charge
First Option:
Second Option:
Sep 11, 2012 | Sony Ericsson Hazel J20i GreenHeart...
My casio rock wont charge
First Option:
Second Option:
Aug 31, 2012 | Casio G'zOne Rock Cell Phone
My phone wont charge and where you put the charge it wont work
First Option:
Second Option:
Jul 28, 2012 | Cell Phones
0xc19a0035
The ink system failure is a pain to troubleshoot. It could mean that the ink cartridges are not communicating with the print head, the print head is bad or the entire printer needs service.
Try resetting the printer to clear the error from memory:
First with the printer on, unplug the USB cable (if using one) from the printer (and the computer).. Then remove all of the ink cartridges from the printer (lift the scanner unit as if to change the ink). Wait for the printer to indicate "Insert ink cartridge). Then unplug the power cord from the back of the printer. (Note: do not turn off the printer just disconnect the power cord.) I also disconnect the power cord from the outlet and the power adapter (this resets the adapter). Wait 60 seconds or longer. Then reconnect the power cord to the printer, the adapter and then the outlet. Turn on the printer if it doesn't turn on on its own. Reinsert the ink cartridges and close the printer. Print a calibration page if prompted to do so. Finally reconnect the USB cable. Try printing again.
If the message repeats, the unit needs service. This printer doesn't allow the user to service the print head so the cost for servicing is variable. If the printer is under warranty, contact HP for service. Otherwise decide if it is worth the cost of service (expect a minimum charge of $50 just to determine the problem.)
I hope this helps.
May 16, 2012 | HP Photosmart C8180 All-in-one -...
Print error 0xc19a0023
Hi
  • Try disconnecting the USB cable but don't turn off the printer.
  • Access and remove the cartridges by opening the cover.
  • Cover it back and wait for the insert ink cartridges message to display.
  • Disconnect the printer from power completely by unplugging power cord from supply[socket].Wait a few minutes[2-3]
  • Reconnect the power cord and then press power button if it doesn't automatically power on.
  • Open the cover and re-insert the ink cartridges.
  • Close the cover.Sometimes it will prompt you to print a calibration page,please do.
Reconnect the USB cable now and try printing.
Hope it helps.Thanks!
Ken
Feb 29, 2012 | HP Photosmart D7560 InkJet Printer
USB Sync Cable
I dont' think so. No other PDA does - it would be quite a drain on the USB port. It isn't like powering the tiny LED in an optical mouse.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Dell Axim X50 Pocket PC Logo
21 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
