Question about Toshiba Televison & Video
I need an instruction manual for a Toshiba Cinema Series T.V
  • 2,335 Answers
Toshiba Cinema Series TV manuals can be found at Toshiba's website here.
Posted on Mar 14, 2011
Reboot sony ericsson w380 i
Posted on Sep 17, 2012
2 Suggested Answers
  • 142 Answers
SOURCE: I have a toshiba cinema series. Tried to put
rabbit ears wont work on any tv anymore,you need a converter box,its all digital now,call your local cable company,they did this a few months back(government).
Posted on Oct 25, 2009
Toshiba tv cinema series problem doing the software upgrade when the upgrade starts to download after a couple of minutes it gives me a error msg saying it couldnt download. I am using the download via...
Check the settings on the wifi portion of the television. If you have a cat5 connection try using that to connnect to internet. If you still have the problem, activate the factory reset process on the television and then use setup again. Then try the update.
Mar 02, 2014 | Toshiba 55WX800U Cinema Series 55 class...
I have a 65 inch toshiba cinema series it's says
if a large rear projection set that just says HD, it likely is HD ready which means it needs a set top box connected to the Colorstream input marked 1080 on the rear of the set--It will only likely be 1080i and not p---owner manual would confirm this.
May 28, 2012 | Toshiba Televison & Video
Toshiba 62" DLP Cinema Series
Could be the cooling fan. Is it under warranty?
-Kevin
Jan 04, 2011 | Toshiba 62HMX95 62" HDTV
My Toshiba cinema series HD separates the red & blue color.
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 18, 2010 | Toshiba 57H82 57" Rear Projection...
Oct 25, 2009 | Televison & Video
Our tv is 10 years old toshiba cinema series it has blue and red
It will be 11 years next month that I've had my Toshiba 55H55 Cinema Series and have the same problem every now and then, if you haven't already done so, go to the picture settings and scrolling down to conversion and it will take you through 3 steps of adjustments,there is a white cross in the middle of the screen line up the red first and then the blue, it will then take you to a screen with numbers, ID the clearest number and exit out, you should have a clear picture again. I hope this helps.
Jan 06, 2009 | Toshiba 50H81 50" Rear Projection...
TOSHIBA TV- HCN4226W convergence PROBLEM
I charge 285.00 at my shop ,so if you cannot fix it your self you are looking at repair anywhere from that price or more .You have 2 STK ics these are your convergence Chips .You would need to replace both of them.If you can solder you have it made.
Dec 17, 2008 | Samsung HCN4226W 42" Rear Projection...
Toshiba cinema series convergence problem
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Convergence adjustment procedure to many brands of projection TVs are given in detail.
Jul 10, 2017 | Toshiba CX36F84 TV
RE: Toshiba 27" Cinema Series
your problem is in the high voltage circuit.change your flyback it has a short.also check around for open diode in the same circuit.good luck
Aug 04, 2007 | Toshiba 27A34 27" TV
Televison & Video Logo
660 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
