Hi, I have a computer that has crashed (it had the blue screen, related to hardware or software installations). Now I can't get it to fire up. I don't know how to use safe mode. It won't start on "normally" or "last known good configuration" . I tried safe mode with command prompts but it would not open. I have a legitamite copy of windows xp but no disk as the computer was purchased 2nd hand. Is there any hope for me and the computer? Thanks for looking at the situation!
  • 13 more comments
  • Darryl Traves Mar 14, 2011
    Hi, Thanks for replying. I am actually on another computer at the moment. How do I get the other one to start up before I do anything else. Can you tell me what to do if I get the safemode option, safe mode with prompts, last known good configuration, normally. etc. Thanks, Darryl.
    Thanks, I will give it a go! Can I create a bootable disk with this other computer that works, even though it is windows xp home and the broken one is windows xp professional,? And by the way we don't have a disk for either of them.
    I couldn't get it to start in safe mode but I have got it working in debugging mode . It is asking me to change the screen resolution to 12something to 10something it came on the screen so fast that I didn't quite catch it. How do I adjust that? Everything is bigger!
    It just froze and went to the blue screen again.
    Hi again, it bounced back and I am swiftly uninstalling some recent downloads. VLC media player was the most recent it has been very good in the past, what do you think ? Windows media player has not worked in a long time so it is going to go. ( I tried updating but it failed in the past , we can't play dvd's with windows media player.) and some other windows update extras. I keep you informed of how I go . Thanks. Darryl.
    I have purchased nero 9 and it won't play some of the childrens dvd's from another region, Vlc media player played almost anything, Windows media player has not been able to play any thing for a long time. I have been told by friends that windows media player can cause conflict with other media players like Itunes, nero etc. I don't know the facts but if it doesn't work I may as well remove it which I have. What do you recommend for a free media player or have you suggestions for nero 9 which I have paid for? What is a codec pack and could it be part of my problem? Thanks again for all of your time.
    Thanks, I will jump back on to the other computer to see if I can download it , so far the other computer is running ok, I will keep you informed. About the bootable disk that you suggested that I burn, is it as good as an original window xp and do you need a rewritable disk or is a normal one fine? Is the cd format the best to use? Thanks again, Darryl. Soon I will go back and click on accept this solution.
    Hi, I am on the computer that was broken, I clicked on the link that you suggested but I don't know what to click on to download the media player; there are ads about registry fixes and other things and a write up about k-lite but no clear download point.
    Thank you very much for your time and patience. There are a lot of things that I would not even dream of doing but with a bit of support and encouragement from experts I am willing to have a go. Many thanks once again for bailing me out of trouble. Darryl.
    I am back on the spare computer now. I think I found it on the file forum page, ie. the download of k-lite.
    That was what you call a garden path, it was only an update, all the options I seem to click on lead you to another product.
    Is that the avs video converter download?
    Thanks for your help, I am going to call it a night now and I will return tomorrow. I am sorry but you will have to spell it out to me because when I click download all the files or programs I have tried have a different name, none have K-lite written in the file name at all.
  • Darryl Traves Apr 10, 2011
    Hi, Just a note to let you know. Our computer that crashed with the blue screen, could not be saved on safe mode. I took it to a friend of ours who has a windows xp disk, he tried to fix it without wiping the system! He found a problem code but did not know what it was, so he googled it. It was a bad update from our security software and they suggested to uninstall which he could not do because it required a mouse operation not keyboard controls and our computer would not cooperate; so he saved everything he could and wiped the system. I think he had to connect to his computer, I am not sure but it is fixed now. The update that was the problem, was causing the cpu to run at 100% and nothing else could move so it froze. Thank you for your help. The computer would not co operate with us. It has been going good for about 3 weeks now with only a couple of hiccups. Thanks again. Darryl
  • 2,574 Answers
Make a windows xp Bootable disk ..and use it to reinstall windows xp into your computer.
1.If you don't have a windows xp iso image ...you can download one using bitTorrent.
Navigate here to download biTtorrent,install the app.
Click here and select open(windows xp torrent file) ..click OK.
Next download CdBurnerXP -->click here,install the app.
1) Open the program CDburnXP (start/programs / click on CDburnXP)
click on burn ISO buttonNext you will see this input console screen: (click on the "browse" button and navigate to the ISO file you wish to burn; then click on "burn")
The iso file is the file that you downloaded with biTtorrent ..(Microsoft.Windows.XP.Professional.SP3.Integrated.February.2011.SATA)
Once you finished ,insert the disk into CD-Rom and you will see a message "Press any key to boot from CD/DVD ."
If you don't see this message boot manually,press F11 or F8 and select your CD Drive.
If you still need assistance, You can reply to this message at any time.
Posted on Mar 14, 2011
  • 6 more comments
  • Reparatii PC - Service IT
    Restart your computer and press F8 , choose Safe Mode and press ENTER. Windows XP attempts to start in Safe Mode, which does not automatically start programs and hardware, and displays very primitive graphics. If Windows XP starts successfully in Safe Mode, you can remove any programs or updates you have recently installed. Then, restart your computer normally.
    If safe mode fails then you need to use a windows xp disk in order to repair your computer.
    You don't have a CD/DVD RW? Yes you can create a bootable disk using this computer.
    You will need a blank CD for this operation.
    If you have problems with Windows Media Player you can easily install a codec pack ..
    I use K-lite Codec (Media player Classic ).Click here to download the app .
    This is a free player ..(can play any video format you want ...e.q .avi ,.mpeg,.flv ...)
    The application will reset your video players to default.
    Copy/paste this link ->http://ftp.freenet.de/pub/filepilot/fpt/...
    Into your browser
Acer computer keeps crashing
Best thing to try before anything is to run your computer in safe mode.
Make sure the computer is off and not in sleep or in hibernate.
Power the computer on and click the F8 key till you see below image.
Image is from a Windows 7 - Most versions of windows will be the same Or similar. Screen defaults to 640 X 480 in safe-mode!
Choose safe mode with networking. If while running your computer in safe mode and it never blue screens - Then chances are, you have a software, driver or virus issue - Most cases. If your computer continues to crash in safe mode. Your system most likely has a hardware issue. Common: Computer Memory and/or hard drive.
Jun 14, 2013 | Computers & Internet
Laptop crashes several times a day then get message "caused Windows to shut down unexpectedly and restart". Microsoft Windows Error reporting states a serious problem and is "Stop Error or...
Hi and welcome to Fixya
Stop or blue screen error are caused by recent software installation or hardware modification. If you installed software recently, try to uninstall the software and observed the problem. If you modify something o the hardware. I recommend to revert the modification and observe the issue.
Let me know if you have questions.
Have a good one!
Feb 25, 2011 | Packard Bell Computers & Internet
What cause freezing and hanging in computer systems?
hi
freezing up of a computer system is typically caused by incompatible software to hardware or a hardware not recognised by the operating system (OS) . usually a conflict like this is illustrated by error message of blue screen , if its video or memory related.
i would say you may have a corrupt OS installed , in which case, i would reinstall the fresh OS
and work your way up to installing the peripheral drivers.
what is your computer model and what OS are you using ? i can further assist you
God's speed !
Nov 10, 2010 | Computers & Internet
My computer alway show blue screen and then it restart. It happen when I used my Nokia N95 as a modem for my computer to surf internet. Why and what the problem?
this problem may be because of hardware or software crash.
1. CHECK OUT IF YOUR HARDWARE ARE PROPERLY INSTALLED.
2. RE-PAIR OR RE-INSTALL YOUR OPERATING SYSTEM. IF NEED THEN FORMAT YOUR SYSTEM..
Oct 04, 2010 | Computers & Internet
My computer has crashed and I don't know what to do. All I get is a blue screen..
if you are using win xp a device failure can cause these blue screen, such as memory or vga problems, have your computer check by a qualified tech to see if these crashes are device related or not
Nov 20, 2009 | Computers & Internet
COMPUTER CRASHES BLUE SCREEN MESSAGE SAYS IRQL NOT LESS OR EQUAL
reinstall your windows and if the problem still persists, in this case it's a hardware problem
Oct 08, 2009 | HP Computers & Internet
PC crashes repeatedly, sometimes comes back on, screen says this!
this problem is cause by some hardware components. just make sure all of your hardware components are fixed correctly with mainboard. or else, if you installed any new hardware options to your computer, just remove that & try to start the computer.
if you still have that problem, just let me know!!
Mar 08, 2009 | E-Machines T2200 PC Desktop
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
