Question about MTX Thunder 6500D Car Audio Amplifier
I have 2 MTX Thunder 6500D Car audio amps with similar problems. Most of the driver transistors are open or short circut They are marked with the Fairchild logo and numbers D007 D052 D024 D038 D007 and D052 appear to be interchangable D024 and D038 appear to be interchangable I have not been able to locate any information on what transistors these are , they are all surface mount transistors Can you help please ? Graham
  • 2 more comments
  • smithradio Mar 14, 2011
    YES THEY ARE ALL TRANSISTORS
    part numbers as in original question
    D007
    D052
    D024
    D038
    output transistors are ok
    these transistors are the driver transistors that preceed the output stage .
    from the place where the audio is fed from the preamp circutry through this transistor array to drive the output transistors .
  • smithradio Mar 15, 2011
    I NOW HAVE AT LEAST ONE OF THE TRANSISTORS IDENTIFIED WHICH GIVES ME MORE INFORMATION THAN I HAD , AND A STARTING POINT TO IDENTIFY THE BALANCE OF THE TRANSISTORS . THANK YOU
  • 2,098 Answers
Hi Smith,
Are you sure this is a transistor or a diode? What is a part no printed in this part?
Jdvillanueva
Posted on Mar 14, 2011
Every now and then it would work then go out
Check the ground wire and the power wire for a bad connection.
Jun 21, 2014 | MTX Thunder 6500D Car Audio Amplifier
My mtx thunder 6500d amp hums when connected light turns on but no output
Make sure you have a proper ground wire connection. The ground wire should be connected solidly to the vehicle chassis in a paint-free location. If it is loose or there is paint t the connection site, you will have problems with the amp output. Also check the speaker wires to see if they are touching the vehicle chassis. This will cause a short circuit and you will not have output from the amp. Finally, check the leads from the head unit. They should be RCA cables, and should have a good connection to the amp.
Feb 22, 2011 | MTX Thunder 6500D Car Audio Amplifier
When i hook the postive/negitive and remote wire my amp whines everthing is hooked up correctly but i get no output
there are coils inside the amp the power it an ur output input could be burned out . u can bring it to a pro to fix it . it would cost no more then $100 to fix it . i hope this was helpfull
Can you run two mtx 6500d amps in parallel for more power?
Not suggested to parallel the output of two amps. Instead take each amp, find out what the amps lowest impedance it can drive is and select your speakers based on that. According to MTX these are stable down to 2 ohms without a rated output power of 500Watts X 1. If you get two dual voice coil subwoofers with each coils characteristic impedance of 4 ohms, when you parallel the two coils you will get a 2 ohm load. Just maek sure the speaker can handle the 500 watts.
Jan 27, 2010 | MTX Thunder 6500D Car Audio Amplifier
Mtx thunder 1500 watt amp no sound
Even if there is no visible damage, it could be that one of the transistors is blown, Use a multimeter to check the resistance of the transistors.
Apr 09, 2009 | MTX Thunder 1501D Car Audio Amplifier
About 6 months ago i had installed the mtx thunder 6500d amp to run my 2 rockford fosgate power T1 12inch subs and every thing was great untill recently it stop puting out sound it still powers up and...
good morning and welcome to fixya. not a bad setup you have here at all, you ned to start by checking the speaker wires inside the box to the connector inside and then the wires from connector to amp on outside. if everything looks fine there, then you need to check the amp for power out of the rca plugs to make sure the channel is not dead. if you are looking for a new amp you can try several different ones from fosgates new line up to soundstream's. im running 4 polk momo 12's on the tarantula amp and love it. they are great amps. hifonics also has a new line up pretty cool stuff, heard really good things about there stuff to. good luck and let me know so i can help you out.
Mar 08, 2009 | MTX Thunder 6500D Car Audio Amplifier
Mtx thunder 4004
check for shorted output transistors
Jan 20, 2009 | MTX 4004 Car Audio Amplifier
MTX Thunder 6500D Car Audio Amplifier Logo
173 people viewed this question
Top MTX Car Audio & Video Experts
hoyzee1
Mark Skinner
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
