Question about Sony Playstation 3 (PS3) Console
Every time I turn on the unit, the display on the TV always asking to restore.Now when I follow the instruction,to restore it,nothing happens,it is still the same, what seems to be a problem? My unit is a 250G. PS3 Slim.
    Novelist:
    Sniper:
  • 51 Answers
Hi airwin,
If you are getting this error it is called the no display error.
Cause:
The reason that it happens is because the GPU which deals with all of your graphics has overheated. You just need to stop the heat build up in order to make it work again.
Solution:
The first way you can fix the No Display Error is by sending it in but bear in mind for this problem there is a $150 charge for the repair which is pretty steep!
Alternative Solution That Is Faster:
If you want to get the problem fixed EVEN FASTER than the option for you is a good PS3 Repair Guide.
NOTE: MAKE SURE You Check Out A Complete Review Of The Top PS3 Repair Guides First!
You can find them all here:
Click Here For A Closer Look At All The PS3 Repair Guides On Offer And How They Work
Posted on Mar 30, 2011
Followed turn on instructions in manual.CO display 2 days. continually. Unit gets Very warm & fan runs if turned off. Have to unplug to stop. Unit used approx.3 mo in '14 & just restartd this week.
could you be mistaking the room humidity indicator for the time? reason I ask is on these one display units this happens more frequently than Id care it too , the one display shows both time and room humidity also set point humidity , the only way one can tell is on some models there is a tiny light that shows up next to labeled function , easy to miss It , also if your machine is sort of new (last few years) it has been decided that it's more efficient to let the circulation fan run all the time , regardless of room humidity . this makes it a little annoying (noise) but they do cycle the compressor to regulate the room humidity
May 28, 2015 | Dehumidifiers
Inverted image crystal eye
It may happen if the WebCam position is upside down. Was it dropped or open by any chance?
You can follow the below mentioned steps:
You can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key
& keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow on screen instruction.
NOTE: This will erase all the data on the computer.
Thanks and regards,
Jitha
Nov 23, 2011 | Acer Aspire 5515-5187 Notebook
I have followed on-screen instructions to run intial set-up...auto tuning etc. Yet when I turn TV on again it asks me to run through it all again. How can I stop this happening over and over again?
there is a function called "plug & play" in your tv. try to find out in the remote control of your tv. press menu & go to tunning section & u will find that function. put that feature off. if it is on then it will always ask you to tune channels when powered on.
Sep 13, 2011 | Televison & Video
We just moved into a house with a MS150 Mr steam. I turn it on and the display reads 110 for 10 mins then comes up with H2O on the display. What do I have to do? Nothing seems to happen.
Hi my name is Mike with Mr. Steam please give me a call at 1-800-767-8326 and ask for tech support. We will need you model # and SN # that is listed on your unit if you can be by your unit when you call and we will help troubleshoot your unit. In the mean time check the following 1) water is on 2) drain valve closed even if you have a auto flush close manuel valve for testing
Thanks
Mike Nail
Mr. Steam
Sep 18, 2010 | Mr Steam MrSteam MS150E Steam Generator
My calibration page will not open - i tried following the instructions about 20 times and nothing. Process says: power off, power on and hold for 30 seconds - follow on screen instructions. On Screen...
my calibration page will not open - i tried following the instructions about 20 times and nothing. Process says: power off, power on and hold for 30 seconds - follow on screen instructions. On Screen instructions never come the unit either turns off or loads maps.
Jun 30, 2010 | Garmin nuvi 1450 GPS Receiver
It is stuck in standby mode and will not come on......please help!
Ok perform a system restore, press F8 at bootup and choose safe mode desktop, when you are asked if you want the safe mode desktop or system restore, choose restore, and when asked if you want restore or desktop choose restore, restore to a time BEFORE the problems happened, and follow instructions and reboot, you should be back where you were.
Apr 08, 2010 | HP Compaq Presario SR1303wm PC Desktop
Iphone hank only apple icon comes on screen after press home+on
You may need to restore your iphone. Connect to your pc, then hold the power and home buttons for exactly 10 seconds, then release the power button keeping the home button pressed until iTunes says "iphone in recovery mode detected" then release.
Follow the instructions in itunes to restore your iphone, then re-sync to get your data back
Jul 14, 2009 | Apple iPhone Smartphone
Printer flashes lights when ask to print
You probably have a bad scanner unit. It's not economical to have it repaired.
Dec 19, 2008 | HP Officejet 7130 All-In-One InkJet...
AKAI LCT3201AD
Find and replace the following caps, Ec18, 19, 20 / 1000uf/16v,
Ec9, 10 / 1000uf/35v, Ec14, 25 / 470uf/35v should resolve the problem. You can get the caps at almost any electronics supply.
This is a common problem in this unit.
Good Luck!
Happy Thanksgiving!
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
premtech@willapabay.org
Nov 27, 2008 | Akai LCT2715 27 in. LCD Television
Plasma Display Starting Up
Could be heat build up in the Plasma display unit. Make sure it has the correct space around it for proper ventilation. Also count the number of blinks on the power indicator it is a code for the reason the unit shut down. On the Pioneer PDP-5060HD I have I was getting 12 blinks on the indicator which indicated a tuner issue. Check your instruction book for info on the over heating problem if it continues. You may have a fan out.
Apr 29, 2008 | Pioneer PDP-5060HD 50 in. Plasma...
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
