Question about Ford 5000 Tractor
Cylider head torque specifications for ford 5000 tractor and valve clearance
c17hydro
  • 2984 Answers
SOURCE: torque specifications for 1998 ford ranger
Okay...here is a list since no motor size:
2.5L----- 56-64
3.0L----- 56-64
4.0L----- 59
5.0L----- 75-85
All in ft lbs.......this is for the flywheel.
Posted on Apr 05, 2009
  • 54 Answers
SOURCE: Need Valve clearance for '93 kh ford laser
0.10 - 0.15mm inlet
0.18 - 0.23mm exhaust
but you must be carefull because the top of the valve seat becomes concave from wear, a feeler guage will not give the most accurate reading, hope i have been of some hel
Posted on May 14, 2009
  • 54 Answers
SOURCE: Escort Mk2 1600 valve and torques settings what are they
cylinder bolt torque settings stage 1 15 ft pounds
stage 2 50 ft pounds
stage 3 85 ft pounds
valve clearences 0.15 - 0.20mm inlet
0.22 - 0.27mm exhaust
these are the figures i have been supplied with, you can also use
cylinder bolts stage 1 10 ft pounds
stage 3 + 90deg.
with my exp, i would use the first guide as the degree method has a tendancy to snap head bolts, especially on older vehicles.
  • 2841 Answers
SOURCE: FORD 351 W CYLINDER HEAD BOLT TORQUE
Torque is 85 ft/lbs of torque. Tighten the bolts starting in the center of the head and working your way out to the ends. Go very slowly and only tighten slightly each time you move from the center to the outside. You must pull the head down very slowly each time. Here is the sequence, a127595.png
Posted on Sep 30, 2009
Testimonial: "Just what I needed, thanks."
  • 244 Answers
SOURCE: How to adjust Ford 460 heads?
9 5 1 3 7 10 6 2 4 8 This is the head bolt sequence which should be torqued to 130-140 ft-lbs
Note: the numbers are represenative of the bolt location.
Mike...
Posted on Nov 24, 2009
Cylinder Head bolt torque and tappet settings to suit a , Ford Anglia 1964 105E Engine
Hi valve clearance inlet 0.010 in (0.254 mm). Exhaust 0.017 in (0.432 mm) normal running temperature .. Cylinder head bolts Torque 65 - 70 lb/ft.,.. Cheers
Jan 10, 2017 | Ford Cars & Trucks
How to torque the head on ford 5000 tractor
The manuals will tell you the head torque is 105 ft/lbs , but torque them to 115 ft/lbs. There was a bulletin a long time back dealing with this. Also make sure ALL head bolts have a hardened washer on them.Part # 377490S. As a rule I'll set the intakes at .017"cold on the intakes and .020" cold on the exhaust. It wouldn't hurt to retorque the head and reset the valves after 20-25 hrs.
Nov 06, 2013 | Ford 5000 Tractor
Please assist with Cylinder Head Torque and Valve Clearance Specs for Tata Indica 1.4 LXi
i need the head talk settings & valve clearance for tata indica lxi
Apr 20, 2013 | 2006 Tata Indica LXi
Torque settingsfor head on lister petter mini6 engine
I have just rebuilt one for our Westerly 21. This is from my Petter 'A' range workshop manual:-
The water cooled engines (AC1W etc.) are:cylinder head nuts: 30NM (22 lbft) except 32.5NM (24 lbft) for the one that also holds the rocker.
Valve clearances are 0.1mm (0.004") COLDReset valve clearance after one hours running since torquing the head.
Retorque head and set valve clearance after initial 20 hours running
I believe Mini-6 refers to the water cooled engines but just in case, the air cooled engines are 27N (20 lbft)
Mar 27, 2012 | Cars & Trucks
Hi we are rebuilding a ford 4600. Can anyone tell me the torque settings for the bigend, main and head bolts please? Any help would be great, Thanks bb
On the head, first tighten the bolts following the sequence to 40-50 ft-lbs, run through the sequence again and tighten to 70-80 ft-lbs, and again at 95-105 ft-lbs. The intake valve clearance to .017; exhaust is .021. Connecting rods torque 60-65 ft-lbs. Main caps torque to 115-125 ft-lbs.
Randy - TMS Stoller Tractor
Jul 05, 2011 | Ford Tractor Grill 2600 3600 4600 5600...
Cylider head torque specs ford windstar 1996 3,8 cylider V6
Position the cylinder head on the cylinder block. Tighten the cylinder head bolts in 2 steps following the proper torque sequence. The first step is 37 ft. lbs. (50 Nm) and the second step is 68 ft. lbs. (92 Nm).
Oct 21, 2010 | 1996 Ford Windstar
Need torque spec for head bolts on engine 10L902-0536-E2
150 in/lb or 12.5 ft / lb torque
other useful specs
oil is sae 30 0.6 litre or 600 mils
valve clearance is 0.005 thou and exhaust is 0.007"
cheers paul46
Sep 12, 2010 | Garden
What do i need to torque ford 4000 cyl head bolts down to
my ford 3600 head bolt torque settings are a 3 step tensioning sequence. 90 ft lbs then 100 ft lbs then 110 ft lbs final torque value.
Mar 22, 2010 | RTO Ford Tractor 2000 3000 4000 5000 Water...
Ford 5000 Tractor Logo
639 people viewed this question
Top Ford Toys Experts
D. E. Hev
Are you a Ford Toy Expert? Answer questions, earn points and help others
