Question about LG Refrigerators
SOURCE: Freezer defrost LG american style
Defrost the unit for two days with the doors open...I know you're going to lose your contents. You may have ice on the coils internally. Next make sure you've cleaned the external coils under the unit. Leaving liquids open inside the unit or setting it colder than required will both cause issues like the ones you've got. Also, be sure all air vents inside the unit are unblocked and the door closes tightly all around.
Posted on Mar 09, 2008
SOURCE: Maytag side by side refridgerator
the drain tube is clogged or maybe frozen, remove the restriction and you will have no more problem
Posted on Apr 10, 2008
SOURCE: ice collects in bottom of freezer
ive just actually just fixed our fridge freezer, pull all draws out take out two screw on back panel then remove then pull out the other panel with fan connected.
At the bottom under the coil you will see a shelf all this will be ice pour boiling water on ice and remove when it starts breaking up, you will then see a small hole on the left of the shelf pour hot water down every minute or so and if you have a syringe take excess water out before pouring more boiling water down after a while the hole will a clear up and the ice gone.
Posted on Mar 13, 2009
SOURCE: Build up of ice on bottom of LG fridge freezer
Is it supposed to be self defrost? If so then either underneath the freezer needs to be cleaned. coils if dirty will cause freezer not to work well. I that doesn't help you might have a freon leak which would make it under charged and would ice up like that.
Posted on Mar 15, 2009
SOURCE: LG fridge freezer GR-L207QVJA.
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Posted on Jul 01, 2009
Sep 01, 2013 | Refrigerators
Sep 13, 2011 | LG Refrigerators
Nov 03, 2010 | LG Refrigerators
Jul 29, 2010 | Hotpoint RFA60 Bottom Freezer Refrigerator
Feb 28, 2010 | LG Refrigerators
Sep 16, 2009 | Refrigerators
Jul 02, 2009 | Freezers
Jan 08, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
Jun 01, 2008 | Refrigerators
Mar 09, 2008 | Refrigerators
120 people viewed this question
