Question about Mustek PowerMust 800 (POWERMUST800USB) UPS System
I take the 4 screws out of the bottom of the Powermust the unit opens but appears to be hinged at the back so I can't get access.
  • 3 Answers
You don't need back side.
The battery locates at the front.
Carefully get out forward case (with button), and you will get access to battery.
Posted on Aug 17, 2011
  • David Lesak May 29, 2013
    I have the same issue and need to change the battery, could you be more specific about how to remove the front panel please? I can see that there are two tabs beneath the panel - tried inserting a screw driver and levering, but it looks fragile and I don't want to damage the casing. Thank you.
Doorhandle
for passenger side:
1. unclip screw cover 'center flap' of inside door opener plastic cover, flap is 3/8"x 3/8" (center of plastic cover)
2. remove phillips screw now showing
3. push fabric panel (edge of door opener plastic cover-at hinged end of chrome handle) to allow uncliping of edge of plastic cover (top rt & lwr rt (for passenger side) of plastic cover)
4. open chrome inside door handle to allow plastic cover to be removed-slide plastic cover toward rear, free end of door to remove cover
5. remove switch panel-gently pry with wide non maring pry bar (cover wide blade screwdriver using cloth) do rear of sw panel 1st (don't pry front edge)
6. slide switch panel toward rear to allow removal
7. remove large phillips screw under sw panel
8. remove the 2 plastic covers near top, hinge edge -use plastic spoon handles to encourage caps to pop off. May also require small screwdriver approx 1/8" in to complete pop off
9. remove the 2 phillips screws w/ captive washers
10. remove 3 phillips/hex screws along the bottom inside of door panel
11. on outside/rear edge of panel push the 2 center pins of each in about 1/8"-this allows the clip to be pulled out w/ pin pushed in
12. remove plastic cover (REAR OF SIDE MIRROR)-pull window edge up and back.
13. lift rear of door panel (not hinge edge) up allow hinge edge to pivot around lower pin in door (hinge edge)
14. remove the 2 rt edge "L" brackets (gently pry center plastic pin out) (note the color and replace as removed)
15. slowly peel the clear plastc away from the non hinged end to expose the plastic panel with 3 phillips head screws
16. remove the 3 screws and panel for access to door handle.
17. using access area now available unlatch the rod attached to exterior door handle (unclip plastic to rotate clip up to allow rod to slide out-toward hinged edge)
18. using access area now available remove rod from ext door handle from inside door area
19. remove the 3 -10mm head bolts
20. remove the ext door handle (bottom edge out first)
reverse order to replace door handle
Mar 24, 2014 | 2003 Toyota Avalon
Freezer door wont shut straight
One of the two hinges on refrigerator doors is meant to be adjustable; on your freezer door, it may be underneath the cabinet. Use a mirror to see if that lower hinge appears to have an adjustment range. This can be as simple as over-sized holes through which the screws are placed. It may be necessary to slightly tilt and prop up the entire unit for access.
Jun 15, 2011 | Amana ARB9059CS Bottom Freezer...
I have preloaded the replacement hinge, but it appears that to remove the old hinge it must be unloaded. If that is true, how do you load the new hinge while it is on the door?
Ovens come in many varieties including freestanding units and stacked models that are inserted into a wall. Kitchen oven units that get a lot of use or are getting old may have problems develop, such as a loose or squeaky door which may require replacing the hinges. You can replace the hinges on the door to your oven by first removing the door from the rest of the oven.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Difficulty: Moderate Instructions Things You'll Need:
  • Screwdriver
  1. Step 1 Open the oven door and examine the hinges to see how the they are secured to the door. Some oven doors slide into the hinge assembly or have a locking mechanism that secures the door to a latch on the main unit.
  2. Step 2 Remove the door from the oven by disengaging the locking mechanism and then pull the oven door out. You may need to release a catch on the door or remove a pin from a hole in the hinge.
  3. Step 3 Place the door on a flat surface such as a table or the floor.
  4. Step 4 Remove the screws that hold the sections of the door together to access the hinges.
  5. Step 5 Remove the hinges from the door. The hinges may be attached to the door with screws or they may be held in place when the door sections are tightened or secured.
  6. Step 6 Insert the new hinges into the door and secure them with the screwdriver or place the section of door back on. Tighten all of the screws securing the sections together.
  7. Step 7 Place the oven door back into place by sliding it on the same way that it came off.
Regards
Iversh
Jul 24, 2010 | Ovens
Frigidaire over range microwave oven: Door hanging from only top hinge when opening/closing. Came off bottom hinge and can't figure out how to access to repair.
take 3 screws out to take bottom off then you can reach the hinge -I put a screw with a nut in the hole there above the hinge,
fixed mine
Feb 04, 2010 | Frigidaire Professional Series PHS68EJSB...
Kleenmaid Stainless Steel oven door will not close properly.
The door hinge is probaly broken or could just be the spring. Open the door to the 45 degree position (halfway) and pull on the door. It should come off the hinge assembly. Slide out the oven a little to access the screws for the hinge to see what is broken or wore out.
Aug 10, 2009 | Ovens
How do I open my Kenmore Whispertone 12.0 to get to the cord reel
The motor / cord compartment cover must be removed to access the cord reel. There are four screws that hold the cover to the chassis. Two of the screws are found under the cord-retractor-foot-pedal on the top back of the canister. To access these screws the pedal must be removed. To do this, press the pedal down and look (from the top) for the four plastic clips that attach/hold the pedal hinges to the cover. There are two at the end corners and two in the middle. Using a long, thin flat-head screw driver (or similar instrument) press each clip to unhook/popout the hinges. Note: the foot pedal spring will also come out when the pedal is removed.
The other two screws are found under the curved hinges of the vaccum bag compartment cover. To access these, lift the cover as if accessing the vacuum bag. Keep pulling the cover back until the hinges release from the motor cover. Don't worry, it is disigned to do this and will not break but it may require a little force. A long phillip-head screw driver will be needed to access and remove each screw. Good luck. - Gary
Mar 30, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Very simple I thought- Cleaning the inside of the glass on oven.
Don't have one here at home to look at, but the best way to go about that would be to remove the door from the range to work on in on a table, allowing access to any screws at the bottom of the door for disassembly and easier reassembly. To remove door: open oven door. Use a small screwdriver to poke in the small rectangular hole on the hinge and flip down the little lever toward the door. It is mostly hidden at the top of the rectangular hinge opening in the range frame. (do both hinges) Now with the levers down (locking the door hinge) you can lift and pull the door a bit, removing the door and hinge in one unit from the range body. Sounds more difficult than it is. It really only takes 10 seconds. To replace the door, just reverse procedure, remembering to flip the little levers back up after attaching door to range frame.
Nov 30, 2008 | LG LRE30451 Electric Kitchen Range
Broken hinge
Take the scanner lid off by squeezing the plastic hinges inserted into the back of the cabinet.
Take the top hinge of the cartridge door off with the 2 tork screws holding it, using a small screw driver.
Go to a hardware store & pick up a pair of cabinet hinges no more than 2". (You need to buy a pair because they do not come separate)
Place the new cabinet hinge on the back to the right of the bottom hinge of the base cabinet. Mark holes, drill one top, in the door, & 1 bottom cabinet, pilot holes. Check alignment & insert screws.
Tighten the bottom screws. Leave a little slack in the top screws as they have to be a little off set to close completely. You will only need to open this Cartridge door to change cartriges, so, no sweat.
My cost was under $5 for a pair of brass hinges, & my time, about an hour, taking my time.
It's too bad HP won't supply their offset hinges. They are inexpensive & easy to replace.
I've had my unit for exactly 4 years now, so this fix is a lot cheaper than buying a new one. Besides, I have ink already purchased that does not fit new printers.....go figure....
Aloha.
May 31, 2008 | HP Officejet 6310 All-In-One InkJet...
I have a Maytag Neptune dryer that has one of the agitators? that have come loose and am trying to figure out how to get to it to tighten it back up. It's an MDE5500AYW. Thanks
THE FRONT OF THE DRYER IS REMOVED BY OPENING THE DOOR AND REMOVING THE TWO SCREWS HOLDING THE HINGES TO THE FRONT PANEL. ALSO, REMOVE THE TWO SCREWS ON THE OPPOSITE SIDE OF THE OPENING. PULL THE FRONT PANEL TOWARD YOU AT THE TOP. IT WILL BE HINGED AT THE BOTTOM. ONCE YOU HAVE IT TILTED TOWARD YOU, PICK IT UP OFF THE BOTTOM HINGES.
THERE ARE TWO RETAINING CLIPS HOLDING THE TOP DOWN AT THE FRONT CORNERS. THESE CLIPS ARE HELD ON BY A 5/16TH HEX HEAD SCREW. REMOVE THE SCREW AND CLIP AND YOU CAN LIFT THE TOP. IT IS HINGED AT THE BACK AND YOU CAN RAISE IT UP AND BACK OUT OF THE WAY. YOUY NOW HAVE ACCESS TO THE OUTER SIDE OF THE DRUM. ROTATE EACH OF THE BAFFLES TO THE TOP AND TIGHTEN EACH SCREW AS THEY COME TO THE TOP.
Apr 22, 2008 | Dryers
Mustek PowerMust 800 (POWERMUST800USB) UPS System Logo
157 people viewed this question
Top Mustek Computers & Internet Experts
David Payne
David Payne
Are you a Mustek Computer and Internet Expert? Answer questions, earn points and help others
