Question about Samsung Refrigerators
I am from New Zealand and have a Samsung side by side fridge. Model no SRS585HDSS. The fridge compartment seems to have stopped refrigerating. I did notice it make louder than normal whirring sounds a couple days prior to it stopping. I was told that by pressing the power freeze buttons simultaneously for 10 seconds would force it into a diagnostic mode. I did that with the display turning off except for one lone flashing blue segment coming up. It beeped 29 times and then returned to normal operating mode. The evaporator coil fan is running and the freezer side works fine but the fridge side is not refrigerating at all. Before I start removing panels I would like to know if you have had others share similar issues and if there is an easy fix before I start to remove panels. A wiring diagram and/or a mechanical schematic would be fantastic. Regards Earl Ropata Christchurch New Zealand
fridgetech
  • 473 Answers
SOURCE: refrigerator compartment not cooling
If you are sure the fan in the freezer is running and you don't feel any air flow out of the top middle vent inside the fridge section, then the damper motor must be bad. The damper motor is behind that vent cover inside the fridge section.
Posted on Nov 16, 2007
Techsim
  • 59 Answers
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
  • 146 Answers
SOURCE: Evap fan stops running/low cooling, Unplug Frig Evap fan runs
Is there anything obstructing the fan area, ice build up ? It is normal for your freezer to get warm if evap fan is not working, it is essential for it to work :) A defrost cycle should kick on a timer or as needed (adaptive) and there should not be excessive frost buildup that it blocks your evap fan. I would have suggested you unplug your refrigerator for about 10 minutes and see if that resets your control board - if not, then you will need service - either replacing motor assembly or a faulty control board.
Posted on Aug 22, 2009
Testimonial: "Thanks for your help. The control board was faulty. This is what I suspected but I wanted a second opinion before buying the board. "
Sea Breeze
  • 4654 Answers
SOURCE: Compressor & Evap. Fan both work for 12 hours then evap stops
I believe that because defrost is done by the mother control board this is why this is happening the part of the board that controls defrost is malfunctioning and the only way to resolve the problem is to replace the mother board part number WR55X10656 You can find the replacement board at these places below. Sea Breeze
http://appliancepartsse.blogspot.com/
Posted on Aug 25, 2009
Testimonial: "You were right, thanks for your help. The control board was bad. That is what I suspected, but I wanted a second opinion."
tbreeze47
  • 3083 Answers
SOURCE: Sub-Zero Model 690 S Refrigerator
The following blog may be of help to you, and suggests that thermisters may be the problem:
http://www.applianceblog.com/mainforums/refrigerators-freezers/3937-sub-zero-model-690-refrigerator.html
This makes sense, especially since it's your last error code.
If the unit has a damper, it could be frozen or stuck, but that's the only other thing I can think of to check.
Good luck, and hope this helps.
Posted on Nov 27, 2010
Samsung sr-l3426bs fridge not getting cold
you would need your fridge defrost sensor replace, check for ice build up within the vents of fridge section,
best to a tec to come and replace it for you,you would need the sensor to be reset on your fridge computer board
cheers
Nov 04, 2012 | Frigidaire FRS26R4A Side by Side...
Will ice build up in the freezer compartment of a fridge cause the it to run eratically. It runs excessicely and the thermostat doesnt seem to be working ? If so how do I defrost it safely and quickly
You probably have a bad evap sensor. It tells your fridges heater to turn on. If it's not that sensor, it might be a bad heater, or a clogged drain. Take the food out and the back off to see. On Fisher and Paykel, I would highly recommend a servicer because the machine is made in New Zealand I think, but there is definitely something wrong.
Jan 23, 2012 | Fisher and Paykel Refrigerators
I have a samsung fridge freezer model no RSH1DTMH and the fridge will not go lower than 13degrees and the freezer and water dispenser seem ok. The fridge freezer is only 3 years old. Any ideas/
We had the same fault on our Samsung American style RSH1DBRS fridge freezer as lots of other people seem to be having. After doing lots of research, we found the best solution seemed to be to buy a repair kit from Appliance DIY Repairs. The instructions were fantastic and the installation was a doddle. Excellent service & well priced.
Jan 19, 2011 | Samsung RS2630SH Side by Side Refrigerator
I have a SRS585HDSS samsung which is making a rubbing sound when the fan is going?
Checking the fans will require pulling the unit out of it's space and removing the panels to inspect the fan blades. making sure there is not a dust build up or is the blade coming loose. May be a faulty motor mount.
Dec 17, 2010 | Samsung 24.8 Cu. Ft. Side-by-Side...
MODEL RSH1FTSW side by side f/f Freezer seems ok but fridge stopped working what Can I do please
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 17, 2010 | Samsung Refrigerators
Samsung side-by-side fridge freezer model RS21DCSV. Freezer is fine. Temperature keeps changing in fridge varying from 5-14 degrees and water has stopped coming out of dispenser. Have checked and...
these side by sides use an auger motor in the fridge to open and close according to the temp demand. If its eratic, either the auger is icing up at the outlet possibly due to product being to close to the outlet. On occation i have had to replace them due to being faulty.(to check, adjust the temp. and notice if there is any change on the auger.)
Sep 17, 2009 | Samsung RS2556 Side by Side Refrigerator
Warm refrigerator compartment
There is a fan that blows the cold air down from the freezer to the fridge compartment. It is usually called a freezer fan. Most of them are behind the plastic lining in the freezer. I just noticed that your fridge is a side by side. I have never wored on a side by side but I imagine there is fan in them as well.
Jul 06, 2009 | GE GSH25KGRWW Side by Side Refrigerator
FRIDGE NOT WORKING
Most side by side and other models of refrigerator freezer combinations are of one basic design. The freezer section does the cooling for both compartments. The refrigerator section gets it cold air from the freezer compartment. Therefore check for frost on the back wall of the freezer compartment. If frost is present there you have a defrost problem and it is cutting off the air that cools the refrigerator section.
I think this problem may already be resolved in some manor because of the date of post. Posts should expire after an unreasonable time period.
Mar 19, 2008 | Smeg FA561X Side by Side Refrigerator
SAMSUNG AMERICAN STYLE FRIDGE FREEZER MODEL RS21DCNS
Sounds like u need to replace fan motor
Check fan motor for continity IF none replace fan motor
Oct 12, 2007 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
37 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
