Question about Microwave Ovens
Does not get hot or take very long to heat food
    Problem Solver:
  • 17 Answers
Hi, the problem that your having with your microwave is one that is not cost effective to fix unless yours is a high-end microwave if its not, i would just purchase a new microwave. Also the heating element is whats wrong with it, and it is only recommended that a service professional replace it because of the danger of radiation. I hope that this has help you with your problem.Thanks, and good luck.
Posted on Mar 14, 2011
MAYTAG MICROWAVE OVEN ARCING FOOD ON PLATE, HEATS EXTREMLY FAST. PUT BABY FOOD (SWEET POTATOES ON A PLATE AND WITHIN 5 SECS THE FOODS BEGINGS TO ARC AND BURN
The magnetron is getting to hot and will eventually fail, especially when it is arcing, "a safety issue convern" the cause is the part mentioned above, or there is exposed metal on the inside cavity.
May 07, 2012 | Maytag 1.6 Cu. Ft. Over-the-Range...
Our new microwave heats the containers but not the food. Container is too hot to touch. Food "looks" hot, usually boiling - but food isn't even warm.
Check on the material the containers are made of. If they are not microwave friendly then they will cause problems.
Some materials are designed to "Roast" the contents by absorbing the energy.
Check with a Pyrex glass container and water. The glass should stay fairly cool.
Feb 01, 2011 | Whirlpool MH2175XS Microwave Oven
Take long time to Mack hot food
your magnetron is the heating element. it sends out microwaves that jiggle the water molecules inside the food causing them to heat. this is whats malfunctioning causing your problem. youll have to have a technician replace it
Jan 29, 2011 | Panasonic NN-T990SA Microwave Oven
Our emerson microwave will not make anything hot.put in time for something to cook it runs fine but it will not make the food hot HELP!!!!! the sides and top and bottom of microwave are warm but food is...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 14, 2010 | Emerson Microwave Ovens
Microwave Won't Heat
Check the door safety interlock switches. Be careful of the capacitor, potentially dangerous.
If the switches dont make a connection, the magnetron will not energize ... no heat
Apr 19, 2010 | Microwave Ovens
The Microwave is heating up and appears to function normally. But food is not getting heated or cooked up despite any tempearture and power setting. Even water is not getting heated up and butter not...
If you can't get the food warm or hot, the problem is usually that the magnetron has gone bad. It's an expensive part to replace compared to the price of a new oven.
Jan 04, 2010 | LG Microwave Ovens
My ifb microwave oven is getting hot outside while
Normally when u cook food in microwave the fod is cooked by microwaves, which means the heat is generated with in food. The temperature inside is never too hot and all the heat produced is absorbed with in the food.
On the other hand when the grill is switched on, a separate heatting element gets switched on. You can see this red hot element on the top side of inside of microwave. the heat from this element gets transferred to food through air circulation. But partof heat also gets transferred to the walls of microwave oven. This is the reason the wall feel hot during use of grill.
As i see ther is no problem with the microwave itself. Jut kep delicate thngs a bit away from the microwave.
Oct 17, 2009 | LG Microwave Ovens
Kenmore Microwave Won't Heat Food
The service manual is here.
Unless there's a bad connection at a magnetron terminal, I would say you have a failing magnetron.
It is part number 2B71165R and you can get it from the Pros here for $68.59 (subject to change).
For more free DIY and other help & advice, feel free to contact me via my site.
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 15, 2017 | Microwave Ovens
Microwave does not heat food placed in the center of the turntable. Leaves a cold spot in the middle of the food.
This is normal. That's why I always recommend to my customers that the food be placed slightly off-center on the turntable. An analogy I refer to is stirring paint: If you stir paint with a stick by simply rotating the stick in the center of the can, it's far less effective than pulling the stick around an imaginary circle halfway bewteen the center and the edge.
Jun 09, 2006 | Whirlpool MH6150XMS Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
