Question about Compaq Presario F572US Notebook PC
Presario f572us-all lights on as they should black screen and tries and tries to reboot but nothing but the fan will run for a sec. or 2does this tell you turn it off
  • 784 Answers
1. Problems with hardware - memori module
or
2. Video chip problems.
Posted on Mar 14, 2011
Acer-E1-510. Why is screen blank and system reboots but nothing?
remove the battery and replace it and try again if that does not work it could be you boot files are damaged and you will need to do a system restore
Feb 20, 2016 | Computers & Internet
My compaq presario cq60 wont turn on
Does the laptop boot? Sound? Do you see a "ghost Image" in the monitor in a bright light? If so, Could be backlighting, Inverter, on/off switch that shuts the monitor on/off when you open and close the lid. Can you boot to safe mode with networking? If so, Open the Device Manager, Uninstall the Graphics Adapter, reboot, the software will apply a generic driver, If the Graphics adapter has not failed completely.
Jan 24, 2013 | Compaq Presario CQ60-220US PC Laptop
My compaq presario notebook model 500 does not start up
Remove main battery and try again, if no! sub out the ram one at a time, and test, if no change! the DC jack in the laptop has broken free from the motherboard, if that is the case! you will need a professional to take this further.
Mar 19, 2012 | Compaq Presario F572US Notebook PC
I have a Compaq Presario F572US to which turns off on occasion and tries to reboot but fails. I then take a blow dryer to the heat sink side for a couple of minutes and will come on and work again for...
If your computer occasionally shuts off it may be due to overheating. As a safety precaution your computer will shutdown upon reaching a certain temperature. If you are using your laptop in bed, and it is resting on a blanket or some other object is blocking the fan it may cause the laptop to overheat. Try elevating the laptop or getting a laptop mat with built in fan to help keep it cool. If there is an issue with the Nvida card changing the BIOS will not help.
Mar 16, 2011 | Compaq Presario F572US Notebook PC
Compaq Presario F572us will not stay powered up. It starts and then screen goes black and shuts down. When I press the power button again it lights up but the computer powers off again.
Here's what you can try.
1. Remove the battery and try turning the laptop just from AC adapter. Maybe the battery is bad and shorting the system.
2. Try turning it on just on battery power (with AC adapter removed). Maybe the AC adapter is bad and shorting the system.
3. Try removing memory modules one by one. Maybe your failure somehow related to memory. Test the laptop with only one memory module installed. Try either one.
If nothing helps, the laptop still turns on and off by itself, most likely this is motherboard related failure.
Jan 19, 2011 | Compaq Presario F572US Notebook PC
My laptop wont boot led lights come on but no boot and black screen
Hi,try checking the Memory by swapping them,if you still have issues take to an expert,but be prepared you might have to change your board.
Jan 08, 2011 | Compaq Presario F572US Notebook PC
When i start my HP f572us laptop up i get a black screen, continously restarting with no error codes.
there or two cause of this problem .. 1 VGA and 2 Bios 1st heat the vga card with professional reworksation or if u can't arrange u can use hair dryair...with max heat.. if same then u need to update the bios if u have programmer u can do it .. and if u need bios file u can contact me ...Thanks sim4182@yahoo.com
Sep 14, 2010 | Compaq Presario F572US Notebook PC
My Compaq presario f572us notebook screen turns black upon normal startup. The screen does not turn black if I start-up in the safe mode. It only when i attempt to start windows normally. Everything loads...
i also have a compaq presario f572us that's been having similar problems. when i went onto the hp website i saw that apparently they've been having similar problems with this type of computer as they offer free repairs for 2 years after you bought it. you should probably check if this works for you too
Oct 23, 2009 | Compaq Presario F572US Notebook PC
Compaq HP Presario F572US just turned off.
Remove the battery and plug laptop power into the wall (or power strip).
Turn ON laptop without battery.
It should start.
After Windows has settled, put battery back in and let it charge up.
Hope this helps!
Sep 08, 2009 | Compaq Presario F572US Notebook PC
Presario f572us
Is the battery fully charged?
Jul 27, 2009 | HP Compaq Presario V2000 Notebook
Compaq Presario F572US Notebook PC Logo
180 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
