Question about Lexmark X5470 All-In-One InkJet Printer
Lexma all in one 5400
I want to know when printing a document, statement and the page displayed on the screen prints is there a way if you want some of the page displayed cut or removed which only what you want selected on that page can be printed like cut and paste
  • 39 Answers
That has to be done from within the program you're printing from. So if you're in Microsoft Word, for example, you can dclick and drag the mouse to highlight just what you want to print, and then when you go to print, you should be able to change from 'Whole document' to 'Selection' and it will only print what you had highlighted. Not all programs will let you do that, though.
If you want to print just part of a picture, you'd have to load it in an image editor (Paint is the only one that comes free with Windows) and actually erase what you don't want, or copy and paste just what you do want into a new picture, and then print it.
Posted on Aug 08, 2008
How to shrink document to fit screen size when printing
Scaled Printing
The procedure for specifying a scaling value and printing a document with pages enlarged or reduced to match the document to the paper size is as follows:
1. Open the printer driver setup window, and select Scaled Printing from the Page Layout list on the Page Setup tab.
figure:Select Scaled Printing for Page Layout on the Page Setup tab
2. Using Page Size, select the page size that was set with your application.
3. Do either of the following to set a scaling factor:
Select a Printer Paper Size.
Select a printer paper size, which is different from the Page Size, from the Printer Paper Size list. If the printer paper size is smaller than the Page Size, the page image will be reduced. If the printer paper size is larger than the page size, the page image will be enlarged.6c3578e0-f243-44b0-aa8e-f7bb7752ed56.jpg
figure:Printer Paper Size on the Page Setup tab
Specify a scaling factor.
Directly type in a value into the Scaling box.
figure:Scaling on the Page Setup tab
The current settings are displayed in the Settings Preview on the left side of the printer driver.
4. Click OK.
When you execute print, the document will be printed with the specified scale.
Note
If the application software with which you created the original has the scaled printing function, configure the settings on your application software. You do not need to also configure the same setting in the printer driver. When Scaled Printing is selected, the Staple Side list box appears grayed out and is unavailable (when Duplex Printing is not selected). When Borderless Printing check box is checked for the Page Layout list, Scaled Printing cannot be selected.
Tip
Selecting Scaled Printing changes the printable area.
Hope this helps
Mark
Sep 13, 2014 | Canon PIXMA MX310 All-In-One Printer
HP PhotoSmart computer indicates "open door"
Open "Devices and Printers" in start menu.
Right click printer with green arrow - click see whats printing.
Delete all documents.
Restart computer - then restart printer
See if that clears your error messages.
Mar 12, 2014 | HP PhotoSmart C4345 AllInOne InkJet...
Printer only prints top and bottom lines on page
All web based documents, especially bank statements, require a COLOUR cartridge, so if your cartridge is empty, it will print blank pages. Although the font may look black... it is normally NOT. Altentaively you may also need to instruct your printer to print "background images".
Jul 08, 2012 | HP Deskjet D1000 J110a Printer Catalog...
I have a canon pima mx340 printer/fax machine. How do you get a stored fx to print out
Printing a Memory List or Specified Document in Memory
1. Load paper.
2. Press the FAX button, then press the Menu button.
The Fax settings screen is displayed.
3. Use the button to select Memory reference, then press the OK button.
4. Print a specified document or memory list.
· To print a memory list:
Use the button to select Print memory list, then press the OK button.
The memory list is printed.
· To print a specified document:
1. Use the button to select Print specified doc., then press the OK button.
2. Use the Numeric buttons, or the button to select the transaction number (TX/RX no.) of the document you want to print, then press the OK button.
3. Use the button to select Yes, then press the OK button.
If you select Yes, only the first page of the document will be printed. If you select No, all the pages of the document stored in memory will be printed.
To print other documents, repeat the procedure from steps 2 to 3.
Nov 08, 2010 | Canon PIXMA MX340 Wireless Office...
How do I get a meter reading of number of copies?
Here you go.
  1. Press the [Reports] button on the Control Panel
  2. Press the [Up] or [Down] arrow until 'Systems Data' is displayed on the Display Screen.
  3. Press the [Enter] button.
    The System Data list will be printed with the following information:
    • Total Page Counts: Total number of pages printed
    • CRU Prints: Number of pages printed using the current Toner (Dry Ink) Cartridge
    • Replaced Toner Counts: Number of new Toner Cartridges installed in the machine
    • Replaced Drum Counts: Number of new Drum Cartridges installed in the machine
    • Current Drum Page Counts: Number of pages printed using the current Drum Cartridge
    • Platen Scan Page Counts: Number of pages scanned using the Document Glass
    • ADF Scan Page Counts: Number of pages scanned using the Automatic Document Feeder (ADF)
Feb 10, 2010 | Xerox WorkCentre M15i Laser Printer
Lexmark 5400 series printer won't grab paper for printing
Whenever the printer doesn't pulls the paper please pull the pack of papers, browse through the papers with your finger and put them back gently.If it doesn't work it means the wheels that pull the paper are worn and you need to replace them.
For the second problem, this is not a printer problem but a software problem, please specify which software do you use so we can help you, as each software has individual options to print multiple pages. It will also be more logical to post the problem in the specific software area.
Good luck,
GetAFix99
Nov 17, 2009 | Office Equipment & Supplies
When the recied it alway prined two pages event they send only one
If I'm understanding your statement correctly, you are sending a single print and receiving two pages?
Look at the document software setting first. Do a "print preview" to see if the document is planning to send two pages.
Sometimes the way the page is actually set-up (be it margins outside printer range etc.) will cause a second page. This would be my first investigation to try to solve your problem. I hope it helps. Good luck!
Aug 27, 2009 | Sharp AM-400 Digital Multifunction Printer
Xerox 5400 missing letters
Go to the Xerox website go to support and drivers and DL the newest Driver for the Product
Dec 26, 2008 | Xerox Phaser 7300DN Laser Printer
Right Margin Does Not Print
This one work for me...on top left of the page click on file then click print. A box print with option opens...... click options then select or put a check on left bottom box that says print all linked documents....good luck!
2nd option or
Last option and 100% will print the entire page even allows you to select what you want to print inside the page. Its called webcollect and here is the link.......http://www.web-collect.co.uk/
Mar 21, 2008 | Canon PIXMA MP470 All-in-One Printer
Lexmark X5470 All-In-One InkJet Printer Logo
54 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
