Question about Frigidaire Gallery GLEFM397DS Electric Kitchen Range
Heating coil I had the baking heating coil blow out and had to get a replacement. When I installed the replacement, the bake coil does not work, but the broil does. where could the problem be?
  • 5,911 Answers
The oven features on electric ranges are controlled by the Electronic Oven Control (EOC) board. Commonly referred to as the clock assembly. Each function (bake or broil) is usually controlled by a separate circuit. If you have installed the new element, and can rule out the possibility that you may have received a defective part, the EOC may be a likely culprit. Before you go tearing the console apart, however, double check your wiring on the element you just replaced and take a resistance check of the element. Measure on the element terminals with the wires removed. The reading should be in the K ohm range (resistance will vary between manufacturers). Then measure from one of the element terminal to the outer shell of the element. If it reads a short (0 ohms) you have a grounding problem and probably have a bad element. If you are confused by any of this, please post back with any questions you may have. I hope this helps you.
PS There should be a tech sheet inside the operator console to assist with troubleshooting.
Posted on Aug 01, 2008
My oven will not heat in any of the settings - bake, bake covection or broil. The fan and light work. Also, the self cleaning function worked blowing hot air for 3 hours
Sounds like you need to change the heating element in the oven. comes out with two screws in the rear of oven. good luck
Oct 21, 2017 | Ovens
How do I check heating elements?
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced.
May 19, 2014 | Frigidaire GLEB30T8A Electric Double Oven
Larger heating element not working on outer
The bake element
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
Apr 21, 2014 | Whirlpool Ovens
Kenmore electric oven will not bake
The bake element
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
Apr 04, 2014 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore electric range oven baking element does not go on eveything else works
The bake element
Jan 30, 2014 | Kenmore Ovens
I was baking and heard a pop sound and saw a spark before the oven lost all power? What happened?
OOOPPs - not good , If you saw or heard a pop noise + spark then something blew or shorted.
If the 'loss' was quiet then a fuse or circuit breaker can blow without noise or sparks.
This oven has 4 Heating elements (2 on Grill) 2 inside oven , as you were baking it sounds like a heating element.
As this is a US model I'm assuming you are close to a SEARS somewhere, because they advertise parts made for Kenmore -- try this link http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Evaporative-coil-Parts/Model-867813350/0582/1610510/00007536/00001
Ray
Jan 19, 2011 | Kenmore 94210 / 94211 / 94212 / 94214 /...
Oven on RF263LXTT2 does not maintain a constant heat. Oven heats, but doesn't seem to continue heating at a constant heat during the baking process. Both coils heat up during the preheat. Seems like once...
The problem looks like a faulty electronic control. When you select baking, the broiling element should not come up.
Before replacing control assembly, test the temp probe located inside the cavity, check the wiring harness to temp probe and elements, and ensure that the fan is working if the oven is fan assisted.
Sep 18, 2009 | Whirlpool Ovens
My Jenn air SVD48600P heating element dose not heat
Hi. I believe this info. may assist you in getting your bake and broil up and running:
When your heating element burns out, you have to replace it because they are not repairable. If, when the heating element burns out, the infinite switch that controls it also fails, you have to replace it too.
May 31, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Frigidaire Gallery GLEFM397DS Electric Kitchen Range Logo
213 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
