Question about FUJIFILM FinePix J40 Digital Camera
I couldn't find the function for turn ON the flash. thanx
  • 639 Answers
Search for button with "lightening with down arrow" icon, usually near "OK" button, that's flash button.
Hope this help.
Posted on Mar 14, 2011
What does error code r =8 at startup mean? Turned heater on for first time this year. Opened gas valve at tank and shut-off at heater. Pump is running. Turned 220 v breaker on in box and "spa on"...
Mike, I have found what I believe is the correct manual for your heater at http://www.pool-heaters.com/pdf/Pentair-Maxetherm_manual.pdf. I couldn't find an error code list in the manual but I might have missed it. If you call the the StaRite technical support line at 888-782-7483 they should be able to help youfigure this issue out. I hope this helps.
Please vote on this answer. Thank you.
Aug 26, 2011 | Sta Rite Sr200lp Max E Therm Pool & Spa...
My LCD tv turned off and then flashed a red light and then I unplugged it and then tried to turn it back on and it didn't it just had a yellow flashing light. Then I left it unplugged for a little bit...
your power supply need to be check. Some of the capacitor needed to be change for there where worn out or blown on top. The voltage that he need couldn't be attain so the capacitor need to be charge longer. this occasionally happen to all switching power supply
Aug 13, 2011 | LG Televison & Video
My garmin was automaticly flashing differnt modes continously. Now it won,t turn on at all.
whoa, mine just starting doing that too. Today on a run it just started flashing through the 3 screens and I couldn't turn it off. It kept logging the run so I kept going. Then it would stop flashing sometimes during the run and I'd press the up or down arrow and it'd start flashing again. Now it's in the cradle and I can't sync it up but the battery is charging. Any ideas how to fix this?
Aug 10, 2011 | Garmin Forerunner 305 GPS Receiver
My samsung wep 301 will not pair with blackberry 8330. In the desktop manager, the check box to enable bluetooth support is greyed out. Windows 7 BB Desktop 5.0.1 Samsung WEP 301 Blackberry 8330 I'll take...
Please rate. This is how we (advisor/problem solvers) get people to know...we know what were doing. Thanx
1.First make sure your phone is off. Do this by pressing and holding the Multifunction button (the one that flashes blue) for 4 seconds. For "OFF" it will flash blue and red along with a series of 2 tones. Then will stop flashing. For turning "ON" hold multifunction button for 4 seconds and it will flash BLUE 4 times and 1 tone indicating it is on. It will continue to flash every 3 while in stand-by mode and every 8 seconds while on a call. 2.Set your phone in "Discover mode" make sure you look at your manual on how this is done if don't know how. Usually found under Bluetooth settings. 3.Making sure your headset if off. Press and hold the Multi-Function button until the indicator light turns solid blue (hold for approximately 8 seconds). THE MULTIFUNCTION BUTTON WILL BE LITE ONLY HALF BLUE INDICATING PAIRING MODE. 4. You phone will find and ask to pair. Press confirm/OK and enter "0000" 5.If pairing successful, light will flash blue 10x rapidly before going to flash every 3 seconds. IF UNSUCCESSFUL LIGHT WILL REMAIN ON, AND YOU WILL HAVE TO RE-ATTEMPT.
Jan 15, 2010 | Samsung WEP410 Bluetooth Headset Wireless...
Fuji s7000
Thanx to forum input I found a Quantaray qb-350a flash with a single contact on the hotshoe. By turning on "external flash" in the Fuji s7000 allows the Q350 to work beautifully and for about $40 bucks. It also works on earlier Fuji's like the 6200.
Thanx
Frank
Mar 20, 2009 | Quantaray QTB-9500A TTL Flash
Turn signals flashing rapidly
This fast flash is caused by a burnt out bulb in the front or rear.
Nov 05, 2008 | 1998 Oldsmobile Intrigue
Red dye reduction
You can find your manual here....www.olympus.co.jp/en/support/imsg/digicamera/download/manual/zoom/man_c725uz_e.pdf
You find how to disable red eye function on page no: 63 in that manual.
For quick reference i am giving the details briefly,
The flash modes are as follows:
AUTO FLASH:
Automatically fires in low-light and backlight conditions.
RED EYE REDUCTION FLASH:
This mode significantly reduces
the phenomenon of “red-eye”
by emitting about 10 preflashes
before firing the regular
flash. This mode works the
same as the auto-flash except
for the pre-flashes.
To change between flash modes:
1 Press the (flash) switch.
● The flash pops up.
2 Press the / (flash mode) button
repeatedly until the desired flash mode
indication appears.
● The flash mode changes ,
● If / is not pressed within 2 seconds after the selection screen is
displayed, the selection screen disappears.
● To de-activate the flash (Flash Off mode ), push the flash back into the
camera.
3 Press the shutter button halfway.
● When the flash is ready to fire, the
(flash stand-by) mark lights.
4 Press the shutter button all the way.
● The flash fires.
Hope my info solves your problem,
Thanx for using fixya,
Good Luck.
Sep 30, 2008 | Olympus Camedia C-725 Digital Camera
Flash
You can turn flash off via one of the menus, make sure it is enabled. You may have a bad flash is everything looks OK.
Mar 02, 2008 | Olympus Camedia C-4000 Zoom Digital Camera
Sony KP-43HT20 convergence problem
Replace STK-392-110s or 150s upgrade with 180s replace both ics.
Jan 04, 2008 | Sony KP-43HT20 43" Rear Projection...
FUJIFILM FinePix J40 Digital Camera Logo
Top FUJIFILM Cameras Experts
Tony
Piyal Perera
Piyal Perera
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
