Question about Pride New Jazzy 600 Power Wheelchair by Mobility
- The left side of the tire makes noise - When you
- The left side of the tire makes noise - When you move the wheelchair the right side goes smooth whiel the left side makes noise. After the wheelchair moves for a few seconds it stops - The light near the joystick becomes all weird. Before When the battery charges it lights up from red to yellow to green when it was normal and when you stop charging it it stays put where the battery is, but now the lights are different and there's too many problems - Do you know how to fix it? Thank You
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 347 Answers
MORNING,PLEASE DOWNLOAD AS A PDF FILE :SHOPRIDER SERVICE MANUAL 2007 1-800-743-0772 THIS IS A 36 PAGE DOCUMENT,PAGES 19 TO 36 ARE ON WHAT YOU ARE LOOKING FOR HAVE FUN,BE MOBILE AGAIN SOON,IM DISABLED MYSELF.& B4 I LEAVE STORE THIS IN YOUR FAVOURITES :WWW.ALLDATASHEET.COM ITS FREE & ITS WHAT IT SAYS [ALL DATA ON ANYTHING EVER MADE].COLIN.
Posted on Mar 14, 2011
I have a rough rubbing grinding sound from my front wheels its in sync with the rotation, it only does it at lower speeds, what is it??
Are the tires smooth or choppy as you look at the tread?
Run your hand along the tire tread,it should be smooth,no high or low spots.
High and low wear spots make a lot of noise on a tire.
Also,as you drive and hear the noise move the steering wheel slightly left and right,if you can change the noise at all then it may just be the wheel bearings.
Don't forget to make sure the metal inner dust shields beside the rotors are not touching anywhere on the rotors..
Mar 06, 2018 | Cars & Trucks
I have a 2000 ford expedition 4x4 the front right side makes a clicking noise while driving. Any ideas
Clicking Noise From Left Front Tire Area - F150online Forums
www.f150online.com/.../47713-clicking-noise-left-front-tire-area.html
Aug 11, 2001 - I have a clicking type noise comming from the left front tire. It does not ... I can really hear it when I'm driving beside a sound wall or the side of a building. ... the sound. (Yeah right!) ... Almost forgot: 1999 Ford F150 XLT Supercab 5.4 4X4. ... My 2000 4X4 had a ting ting noise coming from the left front wheel. Intermitent Grinding Noise on 2004 F150 4x4 - Page 5
Jan 15, 2010
Popping noise in front end.
Oct 26, 2009
Clicking noise at low speeds.
Aug 7, 2009
Annoying clicking sound in rear of truck?!?!
Jun 8, 2009
More results from www.f150online.com
Jan 05, 2016 | Ford Cars & Trucks
Falcon troubleshooting
One or more of your tires are no good.
How to check this is : hard to explain.. but will try.. Rub your hand on top the tire... If you are on the passenger side of car rub them counterclockwise and drivers side clockwise... If the tread is bumpy, it will make that noise... If the treads are smooth, then the tire or tires ar o.k.
ALOHA
RAY
Jan 25, 2014 | Cars & Trucks
Power wheelchair won't turn right, back tire squeals
Have you completely disengaged the wheel locks? Check for worn wheel bearings.
Apr 19, 2013 | Invacare Health & Beauty
Noise from front drivers side when i break
If it is thunk, Check to make sure the brake caliper can move smoothly on it's mount and check the sway bar link to see if it has broken, and check all of the bushings on the lower arm, also check to see if there is play in the lower ball joint. This you can seen by raising the left side of car with the wheel and tire still on and snug- try move the bottom of the tire in and out- then check by grabbing the tire at the sides, and see if it has any play as you try move the tire side to side. Lower ball joint play will show as the tire moves, it may or may not make noise. Tie rod end play indactes worn tie rod end(s) when you move tire side to side. If you hear noise or have play in the wheel/tire and you know the tie rod is in good shape- check the bolts that retain the flange of the wheel bearing to make sure they are not loose in the steering knuckle. Also check to make sure the axle nut is tight as well.
If all bushings look good, check angine and transmission mounts and bolts, as well as the bolts that hold the transaxle to the engine bolts as well as the cradle bolts that hold the cradle to the body.
If the noise is a scratching sound, or a screech, the brake pads may be worn out, pads may be contaminated with oil, or "chill spots" fret cracking on the brake rotor may be appearing. Check to see what the condition of the rotor face is- it should be relatively smooth and bright. Any bluing is an indication of heat and you may have a brake caliper not retracting or binding on the mount.
May 12, 2012 | 1996 Mazda Protege
2002 eldorado makes a loud noise when I'm driving. If I'm parked and pressing the gas I don't hear it but as soon as I begin to drive and I get around 15 mph I hear it coming from the passenger side. I...
If the noise doesn't change when you turn left or right while you are moving than The first thing I would look at is the tire. Check for uneven wear or cupping. The tread should be worn evenly and smoothly all the way around the tire. Something you can try to at least eliminate the tires as the problem is to rotate the tires. If the noise changes, stops, or moves from the front to the rear than you know its the tires.
If the noise still persists after rotating the tires than we will have to think of something else.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Oct 01, 2010 | 2002 Cadillac Eldorado
My car makes a bad growling noise. Everyone said that it was a front wheel bearing because that tire was worn down really bad on the outside. I replaced the passenger front wheel bearing, and it is still...
WHEEL BEARING USUALLY STARTS MAKING A ROARING TYPE NOISE WHICH USUALLY GETS LOUDER THE FASTER YOU DRIVE, SOMETIMES THEY WILL BE LOOSE , TO CHECK JACK UP THAT WHEEL AND GRAB TOP AND BOTTOM OF TIRE AND SHAKE, IF THERE IS MOVEMENT, TRY TO GET SOMEONE TO ROCK TIRE FOR YPU AND WATCH WHERE AXLE GOES INTO CENTER OF BEARING AND SEE IF AXLE IS MOVING WITH TIRE MOVEMENT AND SPINDLE REMAINS STATIONARY, THEN IT IS BAD BEARING, OR SOMETIMES THERE WILL BE NO MOVEMENT, THEN BLOCK REAR WHEELS AND RUN CAR WITH THAT WHEEL IN AIR AND SEE IF YOU HEAR NOISE, GOOD LUCK.
Mar 20, 2010 | 2001 Chevrolet Cavalier
The car makes a howling noise while driving it
well did the noise start after the tires were rotated?could be choppy tires,,,if not ,i strongly think it sounds like a bad wheel bearing,,,,if you drive and while its making the noise turn left and right quick and see if the noise gets louder and which way turning makes it louder,,if you turn leftand it gets louder its usually the right wheels bearing as you are putting load on it, if it makes the noise louder while turning right its the left wheel bearing,,,got it
Oct 08, 2009 | 2000 Pontiac Grand Prix
I own a mpv-4 hoveround,when iam moving forward it wants to pull to left.i have to hold joy stick a little to the right to go straight.is there a adjustment that i can do myself?i have very low income!
Make sure that your tires are both inflated to 45-40 psi, have good tread and are not leaning on or out of the frame. Were both of your batteries replaced at the same time? Is there any noise or vibration coming from the motors that may indicate one has less power than the other? You may want to check the bearings in the casters to ensure they can move freely. I hope this helps!
Sep 23, 2009 | NRS Hoveround MPV 5 - Used Power...
Scraping pulse noise r front merc sable
Check the condition of the wheel bearings, front and back side if the brake rotor, and the back side of the rim. Everything should be clean, rust build-up can throw everything out of true. The hub or wheel-bearing should be tight and smooth when spun.
May 12, 2009 | Mercury Sable Cars & Trucks
Pride New Jazzy 600 Power Wheelchair by Mobility Logo
259 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
