Question about Fisher and Paykel DD605SS Stainless Steel Dishwasher
Machine displaying f1 - Fisher and Paykel DD605SS Stainless Steel Dishwasher
  • 2,335 Answers
The F1 error refers to 'internal flood.'
You may wish to reset the power of the unit, this may clear the error code.
One common cause is too much or 'wrong' detergent causing too many suds. In this case, giving the unit time and a reset is all you need to do.
You may wish to check under the unit to look for a tray with a widget floating in it. If you find such a tray, empty it & cycle the power to reset the F1 error.
I hope that helps.
Posted on Mar 14, 2011
  • 77 Answers
F1 means that your dishwashers have flooded. You can download the video in the link below to see how to get rid of the error and fix your dish drawer for numerous other problems. If your drawer is noisy you may want to replace the rotors at this time as well.
Appliance Repair Video
Order Fisher Paykel Rotor in this link if needed
Posted on Mar 23, 2011
  • Fisher and P... Master
  • 3,247 Answers
Thsi means the flfood switch at the base of the dishwasher has cut in.
There is water leaking into the base under the bottom drawer.
Turn the power off, pull out the bottom drawer and use towels and hair dryer to dry out the base.
Bauses are leaky lid seal, kink in inlet or drain hose or too much foam in detergent.
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    F1 PROBLEM ON VACMASTER VP540?
    I found this information related to a different model of the Vacmaster:
    If you see F1 displayed on the LED screen and the machine will not function, make sure the lid is open and turn the power off. Turn the machine back on and it should return to working order.
    Mar 25, 2013 | Vacmaster Vacuum Pack Machines: VP540C...
    F1 error code
    Call Whirlpool at 800-688-9900.
    Let them know you have a Bravos or Oasis washer and you are getting a F1 error code.
    They will send someone out to replace the controller board for free!
    If not, here is a link to the control board you need.
    Oct 16, 2012 | Maytag Bravos Top Load Washer
    Fisher & paykel fault "F1" is displayed on the top
    hello
    F1 means the flood sensor senses water at base of machine at PC board.
    You need to take out bottom drawer and check for water puddle under where the drawer was.If there is water you can get the machine going again by comletely drying it out(F1WILL CLEAR),but it still means you have a leak.With bottom drawer out you can really see whats going on.Once F1 is clear you can actually run upper drawer and see if it leaks.Most likely culprit are the lid actuators.Replace all 4 . It'll run like new.Don't overload drawer .That can cause lid leak too.Also the PC board may be damaged and may start to go crazy giving fake F1 codes.$80 easy fix.
    good luck
    Jul 27, 2011 | Fisher and Paykel 23 in. DD603H SS...
    Machine goes through the wash cycle then stops before it rinses and spins . Machine displays F1 OR F5 which indicates an error has occured , have to empty manually but cant get it to spin at all .....
    Hello
    F1 is usually a low water code.Check your hoses and water supply inlet screen for any bulid up of dirt or sediment.
    Also the water inlet valve may need to be replaced.
    F5 is a water temp fault.Possible bad heating element or thermostat.
    The F1 code could be causing the F5.
    Due to low water.
    May 04, 2011 | Indesit Washing Machines
    I have a Whirlpool Cabrio top load washer. When I load the clothes and start the washer and it begins to run I hear an alarm, it stops and a F1 flashes on the display. What does this mean?
    F1 (F60-68)
    Primary Control Failure F then 1 flashes when there is a primary control failure. Replace the machine control assembly.
    See Accessing & Removing the Electronic Assemblies.
    F1 flashing on the display indicates a primary control failure.
    "F then 1 flashes when there is a primary control failure. Replace the machine control assembly."
    The link below lists Cabrio failre codes.
    http://www.advantagesupplyfl.com/WhirlpoolCabrioWasherFaultCodes.html
    Dec 16, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    I've been getting the display 'F1' and the machines stops. I can restart and sometimes it's fine and sometimes it's goes back to F1.
    Your machine control board in the conrol panel is bad. You need a new one, about $200.00. If you have a service guy do it it's about 400.00 or more if you hire sears. :->.
    Oct 10, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    My washer keeps shutting off and F1 shows up on the display.
    The "F1" error code on the Whirlpool cabrio is quite common, and generally has to do with the control board. Replacing the control panel may resolve this issue. However, I believe Whirlpool is aware of the F1 issue with the Cabrio, and is fixing some machines for free. Please call 1-800-253-1301 for more details and see if you are eligible for a free repair.
    Thank you !!
    Aug 12, 2010 | Kenmore Oasis 27042 Top Load Washer
    Open Questions:
    Why does my Fisher and Paykel DD605SS stalls midway through wash cycle? I'm not sure if the following incidents are related but my Fisher and Paykel DD605ss now stalls part way through the wash cycle. A few nights ago I loaded the dishwasher hit timer and left it to run in the wee small hours. When I got up the next morning the circuit breaker had tripped on the circuit with the dishwasher. Once I reset the circuit breaker I started the dishwasher. I almost always run it on Normal (Eco) 154 minutes. It ran and then started beeping which I presumed was it finished. It continued to beep and was displaying an E4 error. After searching the E4 error I took the most popular solution and unplugged the machine and left it without power for about 10 minutes. After that plugged it back in and hit the start button again. It seemed to run well and when I walked into the kitchen late in the cycle it was displaying 28 minutes to go with a scrubbing brush flashing in the LCD. I left it alone and went about my life and returned to the kitchen about an hour later and it was still on 28 minutes to go. I hit pause and had a look, there was water and foam in the bottom of the draw. I took the wet plates out and hit the rinse option to see if it was a pump problem. The rinse option ran and the draw was almost empty. I then took the rack etc out of the raw and cleaned it all out. There was a little gunk but not much. I put a light load of dishes in the machine and ran it on the Normal wash mode. It started up and made all the right noises so I left it. I came back to the kitchen and it was stuck on 94 minutes with the flashing scrubbing brush. I paused it, took the dishes out and again ran the Rinse option which drained the draw. So my question is are the three events linked? Circuit breaker tripping, E4 error and random stoppages during the wash cycle?
    Feb 27, 2017 | Fisher and Paykel DD605SS Stainless Steel...
    See all Fisher and Paykel DD605SS Stainless Steel Questions
    Fisher and Paykel DD605SS Stainless Steel Dishwasher Logo
    311 people viewed this question
    Top Fisher and Paykel Dishwashers Experts
    Brian Coughlan
    Owen Barnes
    Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
