Question about Samsung ML-2855ND Laser Printer
I have replace my samsung ML 2855 toner but red led stil turn on and the message still apear replace toner please help me sorry for my english
  • 217 Answers
1. Check inside of printer for pieces of paper (papaer jams)!
2. Replace toner cartridge, maybe your printer doesn't recognized electronic chip on your new cartridge!
Posted on Mar 14, 2011
My samsung ml-1666 printer problem is while i'm push the power on button the printer LED (RED & Green) lite goes on and its consist continue. what couse this problem.....
Two reasons I could think of
Low toner.
Pre-set counter on cartridge reaches limit.
Try removing the toner cartridge and powering the unit on.
While unit is plugged in, re-install cartridge.
Not knowing how old the printer is a the amount of use, it is had to answer
Apr 30, 2014 | Samsung ML 2010 Laser Printer
If the orange light is on and remains on does that mean that the toner is out of ink and needs to be replaced?? When you press print it makes noise but won't print anything and then the orange light is on.
Per Samsungs website:
When the toner cartridge is near the end of its life:
Feb 28, 2011 | Samsung ML 2525 BW laser Printer
Red light on all the time will not print Samsung ml-1640
Depends which LED light is red. The upper one with two symbols is the error LED, while the lower one is the toner LED.
If it's the top LED, then it could be a number of issues, such as an open cover or some software problem. Could be an LSU error. Try updating the driver and firmware.
If it's the bottom LED, then your toner is probably finished (or has hit the 2100 mark). Try redistributing the toner by giving it a little jiggle, or just change the whole thing.
Apr 05, 2010 | Samsung ML-1640 Monochrome Laser Printer
In samsung ML 1640,when the toner i refilled not
You can replace toner for that printer only with genuine Samsung toner because refilled toners are not working.
Feb 23, 2010 | Samsung ML-1640 Monochrome Laser Printer
I have replace the toner in ml 2855 but it is
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Hope this help. Please Rate My Response! Thanks!
Aug 24, 2009 | Office Equipment & Supplies
ML-1640 Series + Toner exhausted.+ how to reset the printer.
Jun 09, 2009 | Samsung ML-1640 Monochrome Laser Printer
I have a samsung ml 2851 nd that won't print, and says the toner cartridge is low - I replaced with cartridge 209 (which office max said would work) and it still flashes the red light and says there is...
The counter needs to be reset most likely. I can\t locate a reset code & steps for you. Try calling samsung and ask about the toner reset you replaced the cartridge and its still showing the count from the old cartridge.
Apr 23, 2009 | Samsung ML-2851ND Laser Printer
ML1640 not working after toner refilling
Download the firmware from here http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=in&CttFileID=2238869&CDCttType=FM&ModelType=N&ModelName=ML-1640&VPath=FM/200904/20090416100856890/ML-1640_V1.01.00.83.exe
run the software and this will reset the page count to 0. Samsung printers generally do not support a refilled cartridge and thus the red light.But resetting the page count to 0 makes the printer detect the cartridge as an intoductory one.
Mar 23, 2009 | Samsung ML-1640 Monochrome Laser Printer
Samsung printer ml 1510 red light flashes after self test
Red Error Light Stays On The following conditions can cause the On Line LED to glow solid red:
  • Printer paper is jammed inside your printer.
  • A cover is not be closed properly.
  • The toner cartridge is not inserted properly and needs to be reinstalled.
  • The toner cartridge is running low.
  • There is no paper in the paper tray.
  • The paper inside the paper tray is not be installed correctly.
Red Error Light Blinks If your printer's On Line LED is blinking red, your printer's toner is exhausted and needs to be replaced. On Line and Error Light Blink Simultaneously
If your printer's On Line and Toner Save LEDs blink simultaneously, your printer requires service.
You can go to samsung online service request http://www.samsung.com/us/support/repaironline/supportOnlineServiceRequest.do
Mar 21, 2009 | Samsung ML 1510 Laser Printer
HELP!!! Samsung ML 1640
http://www.fixyourownprinter.com/forums/printer/59558
Oct 13, 2008 | Samsung ML 1610 Laser Printer
Samsung ML-2855ND Laser Printer Logo
545 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
