Question about HP Compaq DVD Drive
My laptop couldn't detect my dvd drive as if it was not installed, i've been using it before this thing happened.
  • HP Master
  • 27,725 Answers
Make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope thishelps
Posted on Mar 14, 2011
Laptop will power on but hdd led goes out and screen is black, b4 this happened it was asking for windows files. Then I plugged in my dvd drive and put my xp disk in from my dell but it couldn't use...
Call customer support 1 (800) 204-4427 (Toll-Free) if you would like our friendly agents to help you resolve an issue with your order. You'll find the phone numbers for our support teams ...
May 31, 2017 | ASUS Eee PC 1000H Laptop
I have an emachines e442-v634 w/ Windows 7 Home Premium installed. I tried to remove the bottom cover when the machine stopped working with a blue error screen and, I think a cable or wire got...
I would suggest you check the BIOS if everything is detected properly. Like the hard drive and the memory. If both are working properly and being detected by BIOS properly, then you just might need to install your Windows 7 thru USB. You might need to use a different computer to convert your Win 7 OS DVD to USB installer.
1. Use a different computer w/ DVD 2. Use ISO software to convert the Win7 DVD to ISO 3. Download the converter from this link click here or directly from this link 4. Make sure you have an available USB Flash Disk that has a capacity of 4GB or higher. 5. Once you're done converting the Win7 DVD to an ISO file, use the tool above to convert the ISO file into a USB installer.
This will only work if your hard drive is properly detected. Bootmgr error means 2 things, either the hard drive is not detected or corrupted windows installation.
Hope this helps!
Sep 21, 2011 | Computers & Internet
Today I formatted my C drive and install win XP.............after completion of the installation I've installed all the dirvers and softwares which were there in the driver CD provided by ASUS with my...
You need to start WinXP in Safe Mode. Safe Mode does not load the drivers... you can then open the device manager and delete/uninstall the camera. Press F8 during the boot process (after the hardware logo and before the WinXP logo).
Aug 12, 2011 | Computers & Internet
RE-INSTALLATION PROBLEM
it doesn't seem to be cpu. have you tried to update bios? download usb bootable latest version of your bios and give it a shoot. if it does not help, try use external cd drive to reinstall os. press f9 at startup and choose usb hard drive. oh, one more thing-this may be memory corrupt, but not likely. test it in the bios.
Sep 09, 2009 | HP Compaq 6735s Notebook
How i install window in MM10-PC sharp laptop
Installing windows in Personal Computer are needed Bootable at CD/DVD Drive. Your problem is you don't have any CD/DVD Drive.
Use a Portable External CD/DVD Drive.
It's available in the market.
Aug 23, 2009 | Sharp Actius MM10 Notebook
Vista can't detect de DVD rive LG gh22ns30
If u are using vista then do not install any extra driver for any removable drive. In vista one cannot install any drivers other those already in its database. I hope your DVD drive is Vista compatible, otherwise it will behave the way you mentioned it..................sodeep
Jun 28, 2009 | ASUS P4B533-VM Motherboard
DVD/GD Rom not detected by system under my computer, device mmanager or in BIOS.
having that the PC could not configer the dvd rom then you must install it with its drive software .the thing is that the operating program has no drive for it
May 25, 2009 | Computers & Internet
I"ve lost my (E:Drive)
Welcome to Fixya
This can happen due to Three problems.
1) Might have disabled the DVD rom. To check this, Goto control panel->DeviceManager->CD/DVD Rom. Where you can enable/disable the device.
2) The Drivers for the DVD rom may not be installed or may be corrupted. Please use the drivers cd or visit the dell site to update the drivers.
3) The CD DVD Drive may be loosely connected. If can risk at opening the chasi and try connecting it properly
The system may need to be restarted if you perform any of the above activities.
Rate the solution appropriately.
Feb 07, 2009 | IBM ThinkPad T23 Notebook
DVD R/W is not getting detected on my laptop
try to run a repair on your OS. What happened there was that your virtual cd software replaced some default drivers from the OS.
Hope this helps.
Apr 30, 2008 | Dell Inspiron 6400 Notebook
Laptop CD/DVD drive won't detect CDs but will detect DVDs
sure..go to my computer..and see what disks are there?
if there are none, go to control panel, system device manager, and look at dvd drives and see that there is no marks on it(meaning that it's installed)
if not, remove that drive, click on actions/scan for hardware change, and go
you may need the install vista disk to make that happen, but that's unusual.
check for printer drivers here
Mar 16, 2008 | Computers & Internet
HP Compaq DVD Drive Logo
95 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
