Question about Maytag Kitchen Ranges
F1 code on model cre8600acw - Maytag Kitchen Ranges
Summit error code F1 ..what problem
Shinning, Unplug your appliance,wait 10 minutes and plug back in to see if error goes away. F1 could mean a defective touch control pad. You may have to find a good repair Tech. to diagnose and estimate repair. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Fix an F1 Error On Kenmore or GE Range
Range Stove Fault Codes
What does the F1 error code on an Amana oven model number AOCS3040ww mean...
Summit Commercial TTM7212KW WTM7212KW Gas Single Oven f1 beeping Questions
Jul 12, 2016 | Kitchen Ranges
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Stove error f1 kenmore elite model 790.75902990
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
Aug 12, 2011 | Kitchen Ranges
I get F2:E0 F2:E1 and F2:E3 as well as the continuous beeping. Unplugging does not resolve the problem. I can turn on the oven, sometimes, but it goes off by itself. Sometime the controls don't work at...
Kitchen Aid Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0 EEPROM communication error 1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Note: Applies to all F1-E... codes except F1-E3. F1 - E1 EEPROM checksum error F1 - E2 UL A/D error(s) F1 - E4 Model ID error F1 - E5 Calibration shifted F1 - E6 Latch signal mismatch error F1 - E9 Stack overflow F1 - E3 Wiring harness cavity size does not match previously stored value The "Cavity Size Select" jumpers in the wiring harness indicate a cavity size different from that which the control was previously configured for. Check the jumpers in the harness to make sure they agree with the actual oven size.
F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock). F2 - E1 Keypad cable unplugged F2 - E5 Cancel key drive line open F2 - E6 Cancel key drive line openfrom what this says you could have a bad touch pad,it says to press cancel,if the code comes back after a minute you have a bad touch pad.there's a tech sheet on you machine with all the codes on it,look behind the top console taped to the back.make sure you put this back,if someone comes in to work on your machine and that paper is gone it will be hard to work on it,all machines are different.
Apr 21, 2011 | KitchenAid KGST307 Gas Kitchen Range
Oven door is locked and its flashing f1 and beeping how do i stop this im not sure what my model number is
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 15, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
Frigidaire Classic Range, Model # FEF366CCB, F1 error
^%$RF
Jun 12, 2009 | Frigidaire FEF366BC Electric Kitchen Range
What is F1 on my maytag range model mer5570acw I
$%^Y
Apr 22, 2009 | Maytag MER5775Q Electric Kitchen Range
F1 flashes on range modelfefl77ase
$%$ERF
Mar 06, 2009 | Frigidaire FEF366 Electric Kitchen Range
F1 flashes on range
@$#%$TRG
KitchenAid KESS907 Electric Range E1 F1 Error Code
F1 E1, replace Electronic Range Control.
In other words, the controller board has failed.
Jan 29, 2009 | KitchenAid KDRS807SSS Dual Fuel (Electric...
Kitchen Ranges Logo
70 people viewed this question
Top Maytag Kitchen Ranges Experts
gbob59
freddyfox
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
