Question about Dell OptiPlex GX270 PC Desktop
My dell optiplex gx270 will not boot up it is saying the sata primary drive is not found. your assistance would be appreciated. thanks!
  • 20 Answers
Is your PC running well before? If yes, check the Harddisk (HD) on the BIOS mode. Is it detected? check your data cable & power cable to HD. If you try to add other HD (secondary) check the jumper of your HD. Usualy 'slave' for second HD.
Posted on Mar 14, 2011
Dell optiplex gx270 says drive D: disconected - how do i reconnect it
Unplug the power. Open case. Unplug and reconnect cables at drive. There are only two. IDE / SATA and power.
Oct 06, 2012 | Dell Optiplex GX270 Desktop Computer -...
I am trying to upgrade to a 1tb SATA HDD on my Dell Optiplex GX270. It does not recognise my new drive in my BIOS, I have updated BIOS to A07. Am I missing something? Is it compatable with SATA?
I have the same model PC with a 250gig Sata HDD and dont have any problems. If a PC can read 250g it should be able to read 1000g. This may sound silly but is Sata turned on in Bios
Mar 25, 2011 | Dell OptiPlex™ GX270 PC Desktop
Can gx270 use SATA internal hard drive ?
1. You can refer to your device motherboard user manual to find it our if the SATA HDD is supported or not.
2. If you dont have motherboard manual, just remove the screws behind your computer and remove the cabinet side cover and look onto the motherboard inside it. If you find SATA slots, then you can use SATA HDDs in your machine.
3. If there is no SATA slots in your motherboard, you can still use a SATA HDD to your system by getting a PCI to SATA convertor card.
I Hope this is helpful to you
Thanks
Apr 27, 2010 | Dell OptiPlex GX270 PC Desktop
Dell optiplex will not recognize hard drive
Is it SATA or IDE? Have you tried another cable? If it's IDE, have you checked the jumper settings (usually Cable Select is easiest)?
Feb 19, 2010 | Dell Optiplex GX60 PC Desktop
Installed new hard drive and dell will not reconize it as primary drive
make sure that the jumper setting of your harddisk is properly mounted in master and connect the IDE cable to IDE 1 or SATA 1 connector...
Feb 08, 2010 | Dell OptiPlex GX270 PC Desktop
When turning on, all I get is a balck screen w/ a
Your hard drive may be dead, the partition/boot sector is damaged or the motherboard seiral ata chip is bad. If it is one of the first two you will need to delete the partition, re-create the partition and format the drive. Take the drive out and install it in another computer as a slave and see if the drive is recognized and files are all there. If it works in the other computer try backing up the drive and then re-install it in the problem computer and try to format and re-install the system either using the installation discs that came with the computer. If the system utility to restore the computer is located on the drive you might have an issue. You can try using that utility if you have it and it may or may not work.
Sep 25, 2009 | Dell OptiPlex GX270 PC Desktop
Hey, My Dell Optiplex GX270 will run for a quick second, beep, and then a light with a barrel looking icon lights for a second too. How do I fix this? Thanks so much!
I would run diagnostics. Here's how you do it if the utility partition exists on your hard drive:
Starting the Dell Diagnostics From Your Hard Drive
  1. Shut down and restart the computer.
  2. When the DELL™ logo appears, press <F12> immediately.
NOTE: If you see a message stating that no diagnostics utility partition has been found, run the Dell Diagnostics from your Drivers and Utilities CD.
If you wait too long and the Microsoft® Windows® logo appears, continue to wait until you see the Windows desktop. Then shut down your computer through the Start menu and try again.
  1. When the boot device list appears, highlight Boot to Utility Partition and press <Enter>.
  2. When the Dell Diagnostics Main Menu appears, select the test you want to run.
Aug 11, 2009 | Dell Optiplex GX270
Problems putting window xp on my rebuilt dell gx 270
can you be more specific? do you have a sata drive ? more info plz
Feb 24, 2009 | Dell OptiPlex GX270 PC Desktop
Dell OptiPlex GX270 PC Desktop Logo
173 people viewed this question
Alun Cox
