Question about Fisher Dishwashers
What does f1 mean - Fisher Dishwashers
  • 2,335 Answers
The F1 error refers to 'internal flood.'
You may wish to reset the power of the unit, this may clear the error code.
One common cause is too much or 'wrong' detergent causing too many suds. In this case, giving the unit time and a reset is all you need to do.
You may wish to check under the unit to look for a tray with a widget floating in it. If you find such a tray, empty it & cycle the power to reset the F1 error.
I hope that helps.
Posted on Mar 14, 2011
What does E2 -F 1- mean?
It helps to know make and model in such questions.
Whirlpool Oven...what does E2 F1 mean on the clock/control panel ...
https://www.shopyourway.com/questions/1183452
Aug 27, 2012 - The "E1 F1" fault code indicates an Electronic control board malfunction. This means that the control board will need to replaced. I'm not able to provide a part number because there was not a model number submitted.I added an image of from the technical data sheet in reference to the "E1-F1" fault code. Whirlpool Gold Oven Error Code F1 E2
25 Jun 2013
Whirlpool Oven (GBS307PDQ0) Fault Code E3 (amber ...
17 Sep 2012
What does error code F1 mean on my Whirlpool ...
1 answer
14 May 2010
What does E2 F1 mean on a Kenmore electric range ...
1 answer
25 Mar 2009
More results from www.shopyourway.com
Whirlpool Oven...what does E2 F1 mean on the ... - Shop Your Way
https://www.shopyourway.com/m/questions/1183452 Aug 28, 2012 - Control panel for Whirlpool Gold double oven. 2 answers. whirlpool range, clock/oven control goes into alarm. 4 answers. Whirlpool Gold Oven Error Code F1 E2.
Whirlpool Gold Oven Error Code F1 E2 ' Shop Your Way: Online ...
https://www.shopyourway.com/m/questions/1218462 The F1 E2 error code indicates an oven control failure. Try disconnecting power to the range for 20-30 minutes, then restore the power. If this does not help, I suspect that the oven control will need to be replaced.
Whirlpool Appliance Fault Codes ' PartSelect.com
https://www.partselect.com/JustForFun/Whirlpool-Appliance-Fault-Codes.aspx Whirpool Oven/Range/Stove Fault Codes (Including 2 and 4 digit codes). Note: Depending upon the brand of appliance, there can be many different names for the 'clock' component. Electronic Range Control, ERC, Electronic Oven Control, EOC, control board, and clock all refer to the same part. 4 Digit Fault Codes. F1-E0 ...
Mar 24, 2018 | Whirlpool Ovens
Tip
What the F1 code means on your OVEN
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
on Aug 05, 2011 | Ovens
What is f1
if its a whirlpool built product it usually means that the main control board has failed... what brand is it?
Jul 24, 2016 | Washing Machines
WHAT DOES FAULT F1 MEAN?
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced GENE
Sep 08, 2011 | Whirlpool Dryers
Toploader kenmore elite oasis is showing F1 code for error. I do not have an owners manual. What does F1 mean?
Gene
Aug 21, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Stove error f1 kenmore elite model 790.75902990
Aug 12, 2011 | Kitchen Ranges
F1 Error code on fisher paykel softouch dishwasher
F1 means that water is in your basepan--- you can pull the bottom drawer out and soak up the water with a towel... you will have to use a hair dryer to dry underneath the control sensor in the back left corner.
Apr 11, 2009 | Fisher Dishwashers
Hotpoint ultima
F1 means short circuit motor triac.
You need to call an engineer.
Oct 26, 2008 | Hotpoint Ultima WF860 Front Load Washer
What does F1 mean?
F1 means you either need a new touch pad or a new control board. Usually it's the touch pad. Hope this helps, APP tech http://www.AppliancePartsPros.com
Jul 30, 2006 | Kenmore 45702 / 45704 / 45709 Dual Fuel...
Open Questions:
Dishwashers Logo
208 people viewed this question
Top Fisher Dishwashers Experts
Tony Houde
Tony Houde
George Merkley
George Merkley
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Fisher Dishwasher Expert? Answer questions, earn points and help others
