Question about Whirlpool AWM8103/1 Front Load Washer
Drum outlet hose assembly
On removal of the main hose from the bottom of the drum, a plastic ball and rubber cup fell out, these are definitely parts of the hose assembly, Can you please advise the correct assembly sequence or provide a schematic view or cross section drawing showing the correct assembly sequence of the main hose from the drum to the pump drain. Many thanks
AWM 8103/1
8570 81015303
Hi trevor it is just a eco ball it is not needed it will cause you more problems when it is in the machine dont worry just leave it out
Posted on Dec 19, 2008
I can't locate the filter on my wmd940a to clean it
You are NOT going to like this. To access the debris trap/filter on this machine, you need to tip it on its back. The trap is UNDERNEATH the drum. A rubber hose comes from the drum to a rubber trap bout the suze of a cup, then on to the pump.
The cup device is held in place by a spring clip that you will need to compress with pliers.
Once the trap is off, you will find a hard plastic cup with a ping pong ball inside. Remove the ball, remove the cup, clean out and re-assemble.
ont you love hotpoint for making this so user unfriendly!!
Feb 28, 2011 | Hotpoint Washing Machines
I wouold like to know where the filter is on the Hotpoint Aquariaus WF100
Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting.
And rate me nice pl for the free help!
Mar 13, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Really bad smell from drum?
Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the hose to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting. Being the first time you shd note what you doing, what goes where. You certainly don't need techs for this; and techs who come are useless anyway.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Pl give me a ‘very helpful’ rating for the free help, thanks!
Mar 08, 2010 | Hotpoint WMA64 Front Load Washer
Wahing machine washes but will not spin Hotpoint auquarius extra wm836 cant find filter
Feb 17, 2010 | Hotpoint Aquarius WMA56 Front Load Washer
MY Hotpoint WD 640 washing machine is not drying clothes is there a filter to clean or a reset
Feb 15, 2010 | Hotpoint Aquarius WD640 Front Load...
MY Whirlpool AA1400 5145 I had remove bottom drain and there is some blocking then I don't know whow comes first the ball or the rubber. Regards, OA
Hi
I hope I understood your question properly.
When you take off the drum drain pipe, you have a plastic ball and plastic ring inside the cup shaped hose which fits on the bottom of the drum.
When putting it back on, first put the plastic ring inside the cup-shaped hose. Then put the plastic ball on top of it.
Secure the hose to the bottom of the drum with the metal clamp. Make sure it is on correctly and will not pull off.
Also make sure there are no kinks in the hose leading to your drain filter.
Start a quick cycle and monitor the machine to make sure there are no leaks.
Best Regards
Ash
Nov 15, 2009 | Whirlpool AWM5145/2 Front Load Washer
WATER LEAKING FROM POWDER TRAY AND AROUND DOOR
There is a ball return valve that wants cleaning. Disconnect the appliance from water and mains. Turn machine on its side and look underneath. At the bottom of the white plastic drum you should see a black rubber hose about the size of a mug fastened by a hose clip. Remove hose clip and extract the hose from the drum and look inside. You should see a white plastic cone about the size of a paper cup with a plastic ball inside, remove and clean of any debris and replace. Be careful when reattaching the black how to the drum or you will get a flood if not properly attached.
Hopefuly that will solve your problem.
Apr 27, 2009 | Washing Machines
No spin
And rate me plz……………………….
Apr 10, 2009 | Washing Machines
E15 water is draining but clothes still sodden,
The problem is your pump or filter is blocked.
Mar 21, 2009 | Hotpoint Aquarius WD640 Front Load...
Cycle is stopping at 9 mins left and not spinning on my lg drive 7 washer/dryer
A common solution for filter cleaning, might help you. You should check your pump too. (another Hotpoint model)
The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. In side is a white molded cone and a big white ball which floats in side. You will find a lot of junk here, clean out. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip.
May 27, 2008 | Hotpoint First Edition FEW10P Front Load...
Whirlpool AWM8103/1 Front Load Washer Logo
259 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
