Where i can buy water pump for hoover 620 washing machine
  • 3 Answers
If you are in Sydney I will buy the machine off you for $100. Erik 0410 501 491. Cheers
Posted on Mar 16, 2011
My hoover 350m stopped at the end of the cycle but was still full of water. Could it mean a new pump or something else?
Could be just a blockage in the pump. Take pump off and clean it out. If still no drain then probably needs new pump but really needs pump tested first to make sure.
Dec 04, 2015 | Hoover Washing Machines
HI We have a Hoover 700LD washing machine that wont fill or wash. Will drain and spin. Any ideas? thanks
Thanks for choosing FixYa and welcome. You need to check your water inlet valve and make sure it is not defective. Check your water pump and make sure it is working right. The pump pumps the water into the washer.
Feb 05, 2011 | Hoover Nextra HNT 2135 Top Load Washer
Hoover Nextra HNF2127 washing machine. Lights flashing at finish
Hi
Thanks for using FixYa. The start and pre-wash usually flash due to a clogged drain hose or the water pump. You’ll need to drain the water out of the base and also check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine). If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 18, 2010 | Hoover Nextra HNF 2137 Front Load Washer
Hoover hpe 236. water not draining, stops mid cycle, lights flash
Have you checked the pump filter, and or that the pump is actually working. if it spins o/k with no water in, then I would suspect a draining problem.
If filter clean and pump o/k, then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Hope this is of some help to you.
Jan 16, 2010 | Hoover Washing Machines
My hoover washing machine wont spin and is full of water. model number is hnl 9146-z
It's a safety feature that doesn't allow the machine to spin when there's still water in the tub. The drain pump has probably failed and you would need to replace it (there are some good places online where you can buy appliances spare parts). Try to set your machine on a 'Drain' cycle and see if the pump works.
Nov 02, 2009 | Hoover Nextra HNL 3166 Z Front Load Washer
Hoover 620 washing machine - low water rate
Hi there, how's the machine? Something else you might want to look at are the filters in the connections to the taps - these are the first point of call when checking for debris - it is true that there are filters further in, however check the tap connections first.
Nov 24, 2008 | Washing Machines
Hoover 620 water not pumping out, motor working i think
hello zorro,
you can check your water pump filter assembly for debris and dirt or socks or small clothes.
sometime they do stuck in there and water pump i running but not pumping water out.
tnx 4 using fixya,
drcool
Sep 13, 2008 | Washing Machines
HOOVER 500MB WASHING MACHINE
the pump hose has to be above tub level or the water will run out
the dial control unit is faulty and if the parts are are available will cost up to $150.00 aud approx to buy
the leak under the machine could be from a tub to pump hose or water level hose up to sensor
how new is almost new as it seems you have inherited a lemon and not a working machine
Jul 17, 2017 | Washing Machines
Hoover Commander 7kg (about 9 years old) not working. It does not spin in any wash cycle, although it can be done manually with ease in the 'spin dry' cycle. There was a strong rubber smell before. Any...
I have a Hoover Commander Model 2045LOAUS. The machine washes OK but will not spin (ie pump the water out). Could it be a burnnt out spin solenoid or motor??
Apr 26, 2008 | Hoover Washing Machines
HOOVER LOGIC 1300
you need to access your drain pump and check it for an obstruction but when you pull the hose off keep in mind it might have a lot of water in it i usually use a shop vac and pull all the water out through the drain hose before removing the hose or opening the pump sorry i cant be more specific but ive never cleaned the pump on a hoover
Mar 23, 2008 | Hoover AAA140 Front Load Washer
Washing Machines Logo
46 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
