I have only just acquired a computer and I cant seem to access one of my disk drives. It has little buttons which needs to be depressed and it slides open. The top drive works okay but the second one wont release. Just wondered if you can suggest something before I spend MORE money on getting an engineer out? Thanking you
    Master:
  • 518 Answers
The only thing i can think of is for you to check the back of the drive and make sure the power cable is plugged in all the way (or at all). It's usually a white 4 pin connector.
If the drive is getting power, it should eject the tray. If not, then it's an internal problem with the drive, like a bad motor, or gear.
Hope that helps,
Geno
Posted on Aug 01, 2008
I have a acer aspire one laptop (notebook). i cant seem to switch it on. ive checked the connection to and from the power supply, but when i hit the "on" button, nothing happens! i need to get an...
Maybe, the ON/OFF switch is broken.
You can remove the disk-drive, and temporarily connect it as a "slave" disk-drive in a desktop computer, and access all the files on that disk-drive.
Jul 19, 2011 | Computers & Internet
Player seems to have eaten the DVD. Will not release it so can be ejected
If it's a desktop, you can manually eject the disk. Turn off your computer and press a paper clip or other small object into the little hole on the front of the DVD drive. You need to apply a little force, but the tray should slide out far enough for you to remove the disk.
Jul 18, 2011 | Computers & Internet
How to I run the back up disk on my everex desk top to restore my hard drive
Components check
1.Acquire the backup disk required to perform the function restoration
Observe the back disk for damages either as scratches or dirt particles. Any oberavable dirt particles would require cleaning with disk device cleaner kit acquirable at retail.
2. Acquire time to accomplish the task activity. Restoration process takes time to intitate, thereafter requiring time for the computer system to install known as restoration.
Restoration process
1.The disk software is places into the computer DVD/R driver.
a. computers would have several different driver compartibilities.
b. the most significant is the driver that would accomodate the restore backup disk
2. power off completely the computer soon after inserting backup restore disk in driver and closing firmly.
3. Power on shortly, the computer should recognise a disk medium in disk driver making possible display instructions from which to initiate the backup process.
important notes
1. the computer may power on without recognising any disks inserted in driver.
a. an alternative procedure accessing the disk at the storage location.
procedures of accessing a disk at the storage area on a computer.
1. select the my computer icon on the desktop. The display menu should provide a list of storage areas the computer is capable of performing
2. clicking in the disk driver location display should open up the backup programs area.
3. the options provided makes possible alteration of the computer, including restoration.
Dec 20, 2010 | Computers & Internet
My Dell 531S will not boot past the BIOS (Dell logo) screen. At first I thought it was the hard drive, since it wasn't recognizing anything connected to SATA port 1. Since then I have purchased a new...
It seems like you have multiple problems:
1. DVD-ROM drive not accessing the disk
2. unable to "disable" the "floppy" drive in BIOS SETUP
3. not recognizing anything connected to SATA1 port
It's time to take your computer to a qualified technician, for professional trouble-shooting.
Is your DELL computer still under warranty? If so, exercise the warranty.
Or, maybe you should just remove the "new" disk-drive, the RAM, the DVD-drive, and then responsibly "recycle" the old computer, and purchase a brand-new system, repurposing the disk/RAM/DVD components.
Sep 01, 2010 | Dell Inspiron 531s Desktop Computer
On belkin surf router clicked on set as access point. then i tried to change it but my computer cant get internet from the router so i cant access the belkin homepage. can u help
the only thing you need to do is reset your router to go the IP address original 192.168.2.1
because when you setup it as a access point the router change the Ip Address.
restore the router to factory default settings, please do the following:
1. Unplug the router's power supply
2. Press and hold the reset button on theback of the router
3. Keep the reset button depressed and, at the same time, plug the power supply back in
4. Keep the reset button depressed for another 10 seconds
5. Release the reset button
do this for 3 times and you will acces your router.
Good luck
Please rate me techbelkin
Aug 02, 2010 | Belkin Wireless Surf Router (F7D2301)
I've been using my WD external for a while with no issues. Yesterday turned it on and it isn't recognised by any of my computers, is there anyway of fixing this without losing data?
If your PC will recognize the drive and give it a drive letter, you can run chkdsk (Check Disk) from the Run prompt to verify that the drive does not have damaged sectors. many times chkdsk will fix minor errors allowing you to access the drive again.
Click Start, Run CMD, enter, then type: X: (X being the drive letter of the Seagate) then type chkdsk /r and hit enter. If it completes 100% try accessing the drive again.
If you cannot acquire a drive Letter when you plug in the WD External try going to Disk Management and assigning a drive letter.
Click Start, then Right click on My Computer and click Manage, then click Disk Management. See if your WD drive shows up in the list. If it does, right click on the larger box on the right and see if it will allow you to assign a drive letter.
Another option you may have is taking the hard drive out of the WD External enclosure and either connecting it as a secondary drive in a desktop PC, or installing it into another external enclsure USB device, and try again to access the drive.
If none of these options work, your last option is to contract a Disk Recovery Service to acquire your data. They are usually very expensive.
Jun 15, 2009 | Computers & Internet
My laptop does not recognize WD3200ME
If your laptop will give your WD a drive letter, you can run chkdsk (Check Disk) from the Run prompt to verify that the drive does not have damaged sectors. many times chkdsk will fix minor errors allowing you to access the drive again.
If you cannot acquire a drive Letter when you plug in the WD drive, try going to Disk Management and assigning a drive letter.
Another option you may have is taking the hard drive out of the WD enclosure and either connecting it as a secondary drive in a desktop PC, or installing it into another external enclsure USB device, and try again to access the drive.
Jun 14, 2009 | Western Digital Elements powered by WD 320...
How to use my external USB hard drive
IF you want to back it up
in the above list you made, click view all files in folders
then highlight all the files and to the left it should say Burn To Disk
click on the burn to disk and follow the on screen instructions
Hope this helps
if not write what other trouble it has
Thank you
Fixa fan
Oct 30, 2008 | Computers & Internet
Downloading to computer
Cliff notes version: Try it with the "Solution Disk" in the drive.
Detailed version: I had the same problem, but when I re-installed the "Solution Disk", it said, LEAVE THE DISK IN THE DRIVE. I turned my camera on -- connected to the computer and with the disk in the drive -- and the program started automatically, instructing me to click on the Upload button, which looks like a printer with a cable coming off it (it's to the right of the Delete button and underneath the slide-control that shifts from Camera mode to Preview on my A570IS; it will light up when it's ready).
Before uploading . . . Click on Menu (on camera) to verify your Direct Transfer options. Mine was set on Wallpaper, so it only uploaded the one image and automatically set it as my computer wallpaper. (A neat feature, but not what I was looking for.) Set it to "All images" or "New images" and click on the Upload (lit up) button on the camera.
Note: If it doesn't come up automatically, start the ZoomBrowser program and click on Tasks (to show the menu options below it). The first option is Acquire & Camera Settings; click on that. Then click on the appropriate item (Connect to Camera, Connect to EOS Camera, or Acquire images from Memory Card). You can set it to automatically launch by clicking that option on the main software page.
Finally . . . After it's working, confirm/modify your Preferences in the ZoomBrowser and Utility programs; even if you don't change anything, this will let you know how it's set up.
Jun 15, 2008 | Canon PowerShot A570 IS Digital Camera
Computer face removal
Hi, In order to be able to remove the front panel cover, you must remove both side cover of the computer (remove rear screw and slide back). To remove the front panel: 1. Depress and hold the top square button (left side, top front) of the panel cover; 2. Depress the lower left tab; 3. Press on the right tab; 4. Front panel may then be removed. This is better explained in the service manual. It is available on line from the Compaq site/Product Information/Manual file name c00311113.pdf All other information and manuals on the same page with no charge. Hope this be of some help/idea. post back how things turned up or should you need further information. Good luck and kind regards.
Sep 29, 2007 | Panasonic RR-US360 Digital Voice Recorder
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
