Question about General Electric Washing Machines
Remove agitator from ge washer top loader - General Electric Washing Machines
  • 8,197 Answers
The link below will show you how to remove the agitator.
http://www.wikihow.com/Remove-a-Stuck-GE-Washer-Agitator
Posted on Mar 14, 2011
Lg waveforce top load washer that is around 3yrs old. The agitator plate hold down screw (under the chrome cap) keeps coming loose and at the end of the wash the plate is up with clothes under it.
Remove the screw and look underneath the agitator, GE machines have a correct way to put them back so the agitator sits at the bottom of the machine with virtually no gap. Tighten the screw hard. Perhaps you lost a locking washer at some stage?
We moved to front loaders.
Oct 24, 2015 | LG Washing Machines
My GE Spacemaker wslp1100 top loader is draining very slow causing error code dr. I took black drainage hose off and it seems to be clean. Filters are clean inside washer. I want to know if a coin could be...
You don't reveal full model number. It's not likely that a coin is blocking the water. The pump (part of the motor assembly) may be partially blocked inside or a garment (sock, u-shirt, etc.) may be blocking the water inlet to the pump. It's too early to remove the agitator.
Nov 22, 2013 | GE Spacemaker WSLP1100D Top Load Washer
Model wdss4120aww GE Washer is leaking
If it's leaking during the agitation cycle, and only in 'large' and 'super' water levels, then that's just the way the washer is designed. I got rid of that piece of junk.
Mar 03, 2013 | GE WBSR3140D Top Load Washer
NEED TO REMOVE AN AGITATOR FROM A WASHING MACHINE
  • 1 First you must determine the brand of washing machine you have.
  • 2 To remove agitator on a whirlpool washer, remove top cap from agitator, Next you will find a translucent cap, remove this with your pliers. Then you will see a 3/8 inch nut, Back this nut out and you can then remove the agitator. Be Careful though, inside the agitator where the bolt has been removed is a white piece of plastic that holds the "dog ears". These dog ears are what lets the agitator move in one direction and locks when the transmission moves back in the other direction.
    Maytag and Admiral washers are very similar to remove. General Electric, (GE) is different, To remove a GE agitator simply pull upwards very hard, GE agitators snap on. Be careful not to pop it into your mouth, that really hurts.
  • 3 Remove agitator, repair or replace and reset, GE just push on, you will be able to see the groves to line up the agitator to the hub. For whirlpool place bolt into dog ear guide, and set down on top of transmission post and tighten, be careful that dog ears, do not get out of alignment. That's it.
    Buy F150 parts.
    Jun 03, 2012 | GE Washing Machines
    How to change belt on whirlpool ultimate care plus washing machine
    Top loader? Turn machine up so you can see underneath, remove access panel, belt right in front of you. Fits over motor spindle and base of agitator spider
    May 19, 2012 | GE WBSR3140DW Top Load Washer
    How to remove agitator from GE washer? Model WHDRR418G1WW.
    how to remove agitator from GE hydrowave washer machine?
    Feb 27, 2010 | GE WBSR3140DW Top Load Washer
    How do i remove the agitator on my whirlpool ultimate care II top loader washer
    first you remove the cap on top of the agitator then you remove the inner cap then you use a long extension with a 7/16 socket to remove the bolt the agitator will pull right up
    Sep 21, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
    GE top loader not agitating
    Your agitator splines are probably stripped out.
    Remove the agitator and check the spline grooves.And the agitator coupling on the shaft.
    Mar 04, 2009 | GE WBSR3140DW Top Load Washer
    GE TOP LOADER DOES NOT AGITATE DURING WASH CYCLE BUT DOES SPIN DURING EXTRACTION
    Remove the agitator and check the agitator splines also the agitator coupling on the shaft may be stripped.
    Feb 21, 2009 | GE WBSR3140DW Top Load Washer
    Ge top loader washer agitator does not work
    To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator. If it catches some times or all of the time when pushing down, then then doggets are worn, under the agitator. You`ll have to remove the agitator to see these. If by pushing down on the agitator, nothing changes, Then you probably have a transmition problem. Check this and let me know what you find.
    Nov 27, 2008 | Kenmore 22422 Top Load Washer
    Washing Machines Logo
    623 people viewed this question
    Top General Electric Washing Machines Experts
    Dan Webster
    Dan Webster
    Sal DeAngelo
    Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
