Question about Memorex Products - External DVD Recorder, 24x Write Speed, Black/Silver - Sold as 1 EA - External DV... Burner
Why do dvd burn so slow it take a hour for one movie
  • 475 Answers
  1. Go to Control Panel>System>Hardware>Device Manager>IDE ATA/ATAPI controllers.
  2. From there, right click on each of the channels and choose 'Properties>Advanced Settings'. All drives should be DMA mode. The 'Current Transfer Mode' for Hard drives is usually DMA 4-6 and DVD burners DMA 2-4, DVD ROMs usually DMA. If you see any in PIO mode, that can slow things down.
  3. If you find a PIO mode drive, changing them back may be easy or complicated. First see if you can change them in that window using the drop down menu.
  4. If not, uninstall the channel the drive is on and let the OS reinstall it. This will usually take a reboot. This will not damage any files on the computer. Now your burner should be back to normal. Check the drive settings again when computer restarts & burn your files in peace.
Posted on Mar 14, 2011
    Novelist:
  • 134 Answers
It takes awhile because the USB interface in between the drive and your computer is a good deal slower than the interface an INTERNAL drive has connected with the motherboard, especially if you're using USB 1.0 interface. Don't worry, they are implementing USB 3.0 right now in new computers and in a few years Intel will have an interface called "light peak" which will be much faster because it is fiber optic instead of electrical.
For now you'll just have to live with it, or replace your motherboard with one that has USB 3.0.
2 Suggested Answers
Noggin
  • 944 Answers
SOURCE: DVD - Slow burning speeds
Unlikely that there is a problem with the drive itself, most likely cause is software settings - which burning software are you using? if it is nero 6 then once you click burn after arranging the files for burning, the burn info page should pop up. click on the burn tab and make sure that "determine maximum speed" is checked and that write speed is set to maximum. hopefully this should solve it, if not try setting write speed to one of the slower settings listed and see if you get a better result. Sometimes dvd drives can slow right down when you are trying to push them to go at maximum. if you want to check what it should be able to do, try http://www.pcpro.co.uk/reviews/87363/sony-dru820a.html also worth trying is updating the drivers http://drivers.softpedia.com/get/FIRMWARE/Sony/Sony-DRU-820A-10b.shtml to make sure you have the most recent version. Another thing worth trying if you haven't already is try a different brand or type of disc - just occasionally there can be clashes with certain types and burners - if this seems to solve it, don't throw your pack of discs away, give them to someone with a different burner. The final possibility is a power supply problem. If your PC's power supply unit has spare connectors for a drive then try a different one - possibly your supply doesn't have enough guts to run a more modern drive - take the drive out and try it in another pc with a higher power supply wattage rating. Hope this helps :)
Posted on Feb 28, 2007
HP dvd1170e DVD Writer It now take an hour to burn a movie says it's not connected to high speed hub, work for a year fine. have searched for firmware and can't find any. Any ideas would be...
scroll to the bottom toolbar (bottom of screen) right click you will see task manager application you will see whats running on your computer at the time you are burning also if you are connected to the net when you are burning this might be slowing the burn process
hope this helps
Jan 05, 2011 | HP dvd1170e DVD-RAM Burner
Program shuts down during the burn process.
reinstall the program again and make sure your drivers are properly working
Dec 02, 2009 | Ulead DVD MovieFactory for PC
Im trying download a movie that say it 2 hours 15minutes long so i got a double sided dvd to try to download it but it keep said will not fix so could i shrink the movie even if the dvd has 120 minutes on...
yes... Nero Vision which is part of Nero will allow you to do this by reducing the quality of the movie. It will tell you the overall burn quality that the movie will burn.
DVD Shrink will allow you to backup movies that are over 4.7GB on to a 4.7 GB DVD by doing the same.
Hope this helped you!
If you need further help, reach me via phone at https://www.6ya.com/expert/hugo_f827544e52871d36
Nov 04, 2009 | Dell Computers & Internet
Hi,is it me or the Toshiba Burner slow,there seems a few ways to Burn (movies)but the one that I have chosen comes up with a small field stating Encoding tthen gets going,evem old movies are taking 1 to...
If you write a movie the settings or format of the movie is change to the user define format. In writing your movie first is the computer will reformat the movie file format to some standard format. If you were writing cd the format will be mpeg and if in dvd the format is avi. So if your movie file is not the same format as mentioned above then the computer will automatically change the format to the format standard requirements. That is why it takes time to reencode the movie file format. Then if you unit is not the same as specs with the latest gaming specs today then it takes time to re encode the movie file format. So the hardware specs is something to do with this. If you want to speed up your unit then add memory.
Thanks
Jul 14, 2009 | Toshiba Satellite P300-ST3712 Notebook
Poor video quality with windows movie maker
Windows movie maker is just a generic xp add on that I am sure was an after thought and never will give you good quality movies it does alright and should give acceptable results if you have a good graphics card and vga card but try useing nero to burn movies the burning speeds can be slowed right down to give exellent quality and if you just want a reasonable quality dvd you can turn the burn speed up to burn faster but you always sacrafice quality for speed on any dvd burning program unless you go get a profestional one and upgrade to much higher quality graphics and vga cards you also need a good deal of ram to
Jul 26, 2008 | Computers & Internet
My internal dvd recorder
The movies that u are burning are being copied to your computer, even in a compressed format that will take up space. Are u loosing h/d space. Are u using a copy program that uses the h/d as a temperary storage?
Apr 26, 2008 | Toshiba SD M1712 Internal DVD Drive
I WANT TO BURN MY DOWNLOADED MOVIES ON DVD-R &PLAY THEM ON A DVD PLAYER
I always use Aimersoft DVD Creator, it can easily convert all popular video formats (AVI, MP4, MPG, MPEG, 3GP, WMV, ASF, RM, RMVB, DAT, MOV, FLV, etc) to DVD and burn DVD movie played on portable and home DVD players, that's very good, you can check it out here for free:
http://www.aimersoft.com/dvd-creator.html
Apr 14, 2008 | Ahead Software Nero 6.3 Reloaded (60096)...
Memorex Products - External DVD Recorder, 24x Write Speed, Black/Silver - Sold as 1 EA - External DV... Burner Logo
61 people viewed this question
Top Memorex Computers & Internet Experts
Jax Planet
Jax Planet
Jose Velazquez
Jose Velazquez
Gbenga
Are you a Memorex Computer and Internet Expert? Answer questions, earn points and help others
