We put the DVD in and it says loading and then it says open and spits the DVD back out. We have only used the DVD player about 15 times and this is happening with all DVDs even the ones we watched previous.
  • eric white Mar 15, 2011
    Hi Jd,
    I have a lens cleaner and i tried to do that, but it spat that out too...hahaha I will try opening the back panel of the TV where the DVD is housed and will try your manual bud method, if that fails then i guess the player has broke, if thats the case i guess i didnt get much use out of that...Will let you know, many thanks for your reply..
    Kind Regards...Eric
  • eric white Mar 21, 2011
    Hi JD,
    I have a small problem, im wanting to clean the DVD player manually as you instructed. I have been looking everywhere for my manual on how to remove the DVD player from the TV. I have tried just to do it, i remove the screw on the back of the TV which when removed lets me slide the DVD player about 2cm and no more. I dont want to pull on it in case i break something, but it definately doesnt want to slide out anymore, i must be missing a step, maybe another screw somewhere where i cant see? But yeah thats where im at until i find the manual or you know the secret on how to get it further out? Kind Regards Eric
  • 2,098 Answers
Hi midgeeraker,
If you have a dvd lens cleaner, play it in the player. If not available open the cover of the player then clean the optical lens by soft cotton buds. If the lens has a dust build up, it can't read any disc and will only eject the it.
Let me know if you need further assistance.
Jdvillanueva
Posted on Mar 14, 2011
  • Jdvillanueva
    Jdvillanueva Mar 15, 2011
    Also check the mechanical for malfunction...
  • Jdvillanueva
    Jdvillanueva Mar 21, 2011
    there is an interlocking just below or on the side of it, just find this lock and pull it out while pulling the player.
Eject button is stuck
Get in touch with the manufacturer's product support and ask them.
May 07, 2015 | Televison & Video
Load disc, unit tries to load & play, unit shuts off. Turn power on to set time,etc,machine shuts off.
Laser pickup unit fault. The unit alongwith its flat connecting cable should be replaced. Contact any service technician. Electro help
Feb 23, 2015 | Samsung DVD-V2500 DVD Player
My dvd player just reopens every time i put in a dvd. It wont accept any dics, it used to work fine but has been switched off for about 6 months
A lot of dust builds up in electrical devices in six months. First try using a DVD lens cleaner. If it pops open and you can see the lens, use a tiny amount of alcohol and a cute tip to very gently remove the dust around the lens. My DVD player is an old piece of junk that can read 99% of DVDs because they might have a tiny scratch on them. When it can't read one, it spits it back out.
Sep 03, 2009 | Televison & Video
The DVD player won't work; it spits the the DVD back out
If it is a burnt dvd, it might not play that format. If it isn't, I would take back the tv to where you got it from and get your miney back.
Jun 01, 2009 | Insignia 26 in. LCD Flat-Panel HDTV
Won't load.
try cleaning laser maybe dirty, check all conections thanks jeff......
Feb 16, 2009 | Toshiba SD-1200 DVD Player
SOnt DAV S550
There is a gear underneath the tray that may be broken or possibly the open close detect switch nay be bad. You will have to remove the tray,you will then see that gear.
Aug 10, 2008 | Sony DAV-C770 System
Technical support needed can't get player to eject disc
Huncha,
I had the same problem today.  I got a screwdriver and opened the case from the back.  It was simple, just 3 black screws.  Then I looked in the unit and saw that there were 2 dvds loaded in the unit. Apparently, my daughter didn't realize a dvd was already in the loading tray when she loaded another dvd.  I gently removed the 2 disks by prying the black plastic holder open and sliding the disks out.  Then I put the cover back on and put the screws back in.  Works fine now.  I hope this helps you.  I don't think the unit has a manual eject button, but it sure was easy opening the case and looking in the unit myself.  Good luck.
Dec 27, 2007 | Samsung DVD-P241 DVD Player
No disc
Some stereos have an illumination lead which is normally orrange in colour or its blue & white.
Feb 25, 2007 | Diesel Audio NS-D099 Car DVD Player
DVD loader mechanism
It is called the slider assy. The slider moves the laser assy back to home or start position. It is a small belt underneath or there is gunk or hair in the gear mechanism. A very common problem with CD/DVD players/recorders. Very good though that you saw it was not comming back to home place. I wish I had a manual to assist you but I do not. Im telling you the most common problems with the slider mechanism. Good Lck
Oct 08, 2006 | Sanyo DVW-6000 DVD Player/VCR
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Electro Med Services...
