The marine cb radio turns on but you can't here noboby talking nor can u talk out from the cb
    Master:
  • 518 Answers
Sound like either an antenna problem, or a mic problem.
The mic on most cb's also serve as transmit/receive switching. A broken wire or bad switch in the mic or cord can cause either or both to fail.
If you have a bad antenna (or cable), you should still hear squelch noise on receive (maybe lower in volume) and be able key the mic and get a transmit light on the unit. Visually inspect the connector, cable and antenna. If need be use an swr meter to prove the antenna system is bad.
Hope that helped...
Geno
Posted on Aug 01, 2008
I talk on my cb no one talks back
you could have ten people talking to each other and if no one wants to talk to you then you will be talking to no one.Now if its a radio problem then I would say turn up the variable for your modulation , make sure your RF GAIN is wide open and turn your SQUELCH all the way to the left then go to different channels and ask for a radio check or have a friend drive far enough away and with his radio give you a radio check.
Feb 22, 2015 | Uniden Radio Communications
I have a cx-366ce cb cannot hear talking what is wrong
Is squelch turned too high that it is blocking too many signals?
Otherwise, it could be a faulty cable on the mic as the PTT button disconnects the speaker on the CB and a broken wire can cause the speaker to be disconnected.
Jun 28, 2014 | Connex Cx-366ce Night Runner 40ch Cb...
Ranger vr 9000 how to turn down the talkback
First , is this radio new or used ? If it is new I see no dial for talk back and if it is used then was talk back added to it ? Open the radio so you can check out trace side of the radio and look to where the speaker jacks plug in. If you see a resister soldered across them then disconnect it and your talk back is gone,unless you still want it then solder a 220 ohm resister in place of the one you removed. if the radio is out of the box new then it should be adjustable but as I look at the face I see no knob marked as talk back.If you ordered this radio and asked for talk back on a seperate switch then which one ? look at it and make the call as to which wires to cut and do it .
Feb 25, 2012 | Ranger VR-9000 Base CB Radio
When i talk people they can hear me but i cant hear them talk back to me
Turn up your RF gain. If that isn't the issue, then the mic may be damaged. Try a new mic.
Jan 09, 2011 | Uniden GRANTLT 40-Channels Base CB Radio
My cb has to be has to have to be on pa with external speaker pluged in on pa side to hear people talk. to talk it has to be switched to cb
Take the cover off, and get a can of contact cleaner,make sure its turned off,and spray the PA switch from the inside of radio,spraying into the switch, flipping it up and down as you spray several times,may need to replace the switch. hope this helps..
Mar 26, 2010 | Cobra 29 LTD CB Radio
I Cant Pick Up Any Signals On my Cobra 25 LTD 40-Channels Base CB Radio all i hear is nothing. no truckers saying stuff. i just get white noise i do have an antenna. it is a tv antenna w/ bunny ears :) i...
Your problem is probably the rabbit ears. They are for tv in the 54+
Mhz and CB is 27 Mhz. For simplicity, go to Radio Shack and get a back of the radio indoor antenna. They run under $20. If you want to get more; try a roof antenna or a 1/2 wave cb marine antenna outside.
Hope it helps.3
Tom
Jul 19, 2009 | Cobra 25 LTD 40-Channels Base CB Radio
I just purchased a uniden solara dsc.I HOOKED IT UP AND THE NOAA WORKS BUT I TRIED TALKING AND NOTHING HAPPENED.(I have a tractor with a radio and neither of us could hear each other).
The Uniden Solara is a MARINE RADIO not a CB. Marine (boat) radios operate in the VHF-Hi range and CB is in the VHF-Lo range. You also need a license to operate a marine radio, or you can identify yourself with the name of your boat but you MUST be in the water.
Jun 20, 2009 | Uniden OCEANUS-DSC-BK Base CB Radio
I can hear people talk to me but they can't hear me talk to them
could be a number of things but the one thing thing it could be is turning up the modulation. If someone clipped your radio diode then get another one and solder it back in. There is a variable to turn up the modulation ,one way turns it up the other shuts it off.
May 19, 2009 | Cobra 29 LTD CB Radio
Connex 4600 turbo the talk back
THE TALK BACK VOLUME IS CONTROLLED BY THE MIC GAIN, TRY ADJUSTING YOUR TALK BACK VOLUME ABOUT TURNING THE MIC GAIN FROM 12 OCLOCK TO 6 OCLOCK, DO NOT WORRY YOU WILL NOT LOSE ANY OUT BOUND POWER UNLESS YOU TURN THE MIC GAIN BELOW 11 OCLOCK
Mar 29, 2009 | Connex 4600 Base CB Radio
Midland model 1000
turn squelch all the way off , if you still get nothing you have a bad mic
Nov 21, 2008 | Midland Radio Communications
 Grubhead
Grubhead
