I have a viziodvx37lhdtv that won't stay on. Its have a blue screen and say no signal doing the little time it on
    New Friend:
  • 3 Answers
Connect a laptop to your TV to get it out of RGB mode.
Posted on Jul 13, 2013
    Problem Solver:
  • 9 Answers
I work with televisions. On the remote have you tried pressing INPUT or VIDEO to cycle through the inputs? if its sporadically turning off on you then your fuse may be acting up and in that case the vizio customer support would have to help you. via email: TechSupport@VIZIO.com or via phone at 877 MY VIZIO (877.698.4946) from 6:00AM to 9:00PM Monday through Friday and 8:00AM to 4:00PM Saturday and Sunday, Pacific Time
Posted on Mar 14, 2011
Blue screen and power button red
protron pltv-27 cm screen lights up then green comes on and turns red no signal.
Sep 27, 2012 | Protron PLTV-32 Television
The projector is stuck on the blue screen. It will let me change the input but it will still stay on the blue screen even though everything else is on and working.
Hello!
"blue screen" means: picture is all blue, but there is a signal coming through? Do you see channel logo? Menu? If so, blue CRT or CRT board is at fault. Depends on the age of the set. If set is fairly new, then try to bang on the neck of blue tube with rubber screwdriver hands. Very gentle! While set is working. If you see the retrace lines and TV shuts down then, CRT is at fault. If not, try to play with blue "screen" control of "focus block". Black plastic module with bunch of thick wires attachad to that. Has 3 "focus" and 3 "screen" controls. For each of the tubes. In many cases you'll be able to adjust "blue" down to normal. Usually, those controls are smeared with white paint and hard to turn by hand. Loosen those with little pliers, then adjust manually or via small "phillips" screwdriver. If nothing helps: CRT board is at fault and must be replaced or repaired. In this case you won't see any characters on blue CRT, just solid "blue".
good luck,
Alex.
Jan 20, 2012 | Sony Televison & Video
The laptop stays on for few minutes and then it turns itself off but before it does that, it shows a large blue scree and some large white text, the text flicks a little but fast to the point where I can...
First of all Turn of your laptop.
Now this time when you turn on your laptop start tapping F8 Key on you keyboard when you Toshiba logo. Tap F8 key for at least 5-6 times.
You will get a Windows Advance Option Menu. You will see lot of options over their written in white text. Your mouse will not work on this screen. Use UP and DOWN arrow keys on you keyboard and highlight Last known good configuration. Once highlighted press enter on it. See if you computer boots. If it boots try doing a restore.
If it doesn't boot.
Turn off your computer and then turn on your computer. On Toshiba Logo screen tap F8 key once again and go to windows advanced option menu screen once again and this time hightlight Disable automatic restart on system failure. Now when you see Blue screen coming up on your computer once again your computer won't restart. Now you can write down the information to trace out the blue screen that is occurring on your computer. Write down the Error code which will be in form of STOP 0x000000XX, you find this error code somewhere at the bottom of the blue screen.
Once you get the reply here, we will see what we can do.
Jun 21, 2011 | Toshiba Tecra M2V-S310 Notebook
When my wow pad boots up it goes thru the infotec screen to a lite blue screen it cannot find E:/ to restore or anything it just stays on the blue screen.
Hi, maybe you can take a try of this rescue program called BootSuite. I came across similar blue screen situaiton on my HP laptop (win 7) and it helped me get rid of it and rescued my data back. It is an awesome toolkit that includes a boot CD and several other data rescue tools that help get your PC going even if Windows won't start or computer won't boot up at all. Good luck.
May 20, 2011 | Computers & Internet
The tv works but i can not get it to receive any signal from any source.the menu comes up perfect.
When you change chanels, do the number just go up or down and the screen stays blue?
Let me know, I think that I can help if you can post back to this comment.
Thanks
asnowman
Dec 07, 2009 | Mitsubishi WS-55613 55" Rear Projection...
Screen stays either black or white
Replace the entire DAC board (board with power suplly going into it) for easiest solution.
Aug 19, 2009 | ViewSonic VA703mb Monitor
Blue screen video
sounds like you have no signal to the tv usually if no signal you get blue screen okay need little bit more info okay do you have cable /air you will have to go in the menu and change okay good luck
May 03, 2009 | Televison & Video
Blue screen
Could be something to do with your channels not tuned in propperly or your signal is being lost.
Sep 30, 2008 | Sony KP-57WS520 57" Rear Projection...
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
